xB fitment 15x7 0 offset
Old Apr 14, 2005 | 02:32 PM
Bull's Avatar
Default xB fitment 15x7 0 offset
So will it work without rolling the fenders . . . 15x7, 0 offset on an xB?
Old Apr 14, 2005 | 08:44 PM
Bull's Avatar
And the answer I got from Van at OneTonGarage . . . just in case anyone was interested:
"With 15s, your fender clearance is also determined by how low you run your car, and what size tires you go with. But with 0 offset wheels, even at 7" width, you will most definitely have to roll the rear fenders a bit. The fronts should clear with no real problems (though they will have the appearance of sticking out a few mm past the fenders).. though if you run a 205 or wider tire, and lower the car more than 2.5" or so, you'll have to remove the two bolts that hold the bracket between the front fender and front bumper. Rolling the rear fenders isn't a problem though, as they are extraordinarily easy to roll, and you usually have to end up rolling them once you get wheels that are anywhere near flush..usually 12mm or lower on a 7" wide wheel."
Old Apr 15, 2005 | 07:47 AM
tinybigrig's Avatar
ganster is all i have to say, if you drop that _____ on the ground itll look super hard
brent
Old Apr 15, 2005 | 01:17 PM
RuntoxB's Avatar
thank you for sharing the info
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
gqdabien
Jul 22, 2015 10:30 PM
