BEAT-BOX
04-15-2005, 07:09 PM
I am looking at a wheel that only comes in 45 & 38 offsets. I know the 38 offset is good for the rear but how will the 45 on the front do? These will be 18 x7.5 with 215/35/18. If the 45 up front is no good will a 3mm spacer do the trick? Need input ASAP. Thanks
BEAT-BOX
04-15-2005, 07:25 PM
Just spoke to the wheel guys and they no longer have 45 offset so will a 38 offset work on the front? Thanks
boostedscion
04-15-2005, 07:57 PM
get some pics up when you get ur rims thanks
if this is for a xB.....+38 will be good all around. to be flush the xB is best with a +35 front and +25 rear
BEAT-BOX
04-18-2005, 11:50 AM
So I wont be sticking out in the front? Ishouldnt have any rubbing issues right?
18x7.5 +38 with35 series tires.
JDMxB
04-18-2005, 05:08 PM
+38 is fine up front as well as in the rear--you shouldn't need any spacers at all to fit them.
And no, they won't stick out past the fender.
BEAT-BOX
04-18-2005, 06:34 PM
Cool :clap:
I just dont want to have to worry about rubbing issues with this being my daily driver.
JDMxB
04-20-2005, 05:13 AM
Unless you go down about 3-3.5 inches in the front you don't have to worry about it. Or you get some really high profile tires. Or both.
BEAT-BOX
04-20-2005, 11:56 AM
What do you guys think is the biggest profile I can go with if I lower it about 2"?
JDMxB
04-20-2005, 05:20 PM
I've heard that 40's rub with lock to lock steering, so I'd just stick with 35s.
boxanne
04-20-2005, 05:26 PM
I've got the 35 series tire and the 45mm offset and haven't had one rub. You should be fine with the 38mm.
BEAT-BOX
04-20-2005, 07:56 PM
Thanks but do we know the tallest tire we can run?
04whtbox
05-07-2005, 01:17 AM
T he 35 series tires suck if u drive alot . With the bumps on the roads and highways . I have 40 's on my wrx and she rides sweet. But 35's on my xb and the ride is totally diffrent. There exactly the same set of tires . i put on about 100miles a day
