thefoth
04-20-2005, 11:43 PM
Steps for installing gauge pod
http://www.scionlife.com/tech/images/epod_gauge_xb/pod1.jpg
1. OOOH new gauge pod
http://www.scionlife.com/tech/images/epod_gauge_xb/pod2.jpg
2. Insert 2 screws into two holes in base of pod
http://www.scionlife.com/tech/images/epod_gauge_xb/pod3.jpg
3. Place into receiving hole on replacement top column piece with adjusting nut facing notch (see picture 22)
http://www.scionlife.com/tech/images/epod_gauge_xb/pod4.jpg
4. Push screws through, hand thread on nuts
http://www.scionlife.com/tech/images/epod_gauge_xb/pod5.jpg
5. Tighten screw to nut with screw driver and provided wrench
http://www.scionlife.com/tech/images/epod_gauge_xb/pod6.jpg
6. BE CAREFUL not to strip out the plastic wrench that is included. You may opt to use your own.
http://www.scionlife.com/tech/images/epod_gauge_xb/pod7.jpg
7. Rotate steering wheel to left 90˚ from center to remove left screw and right 90˚ from center to remove right screw
http://www.scionlife.com/tech/images/epod_gauge_xb/pod8.jpg
8. see number 7
http://www.scionlife.com/tech/images/epod_gauge_xb/pod9.jpg
9. see number 7
http://www.scionlife.com/tech/images/epod_gauge_xb/pod10.jpg
10. see number 7
http://www.scionlife.com/tech/images/epod_gauge_xb/pod11.jpg
11. Locate and remove screw from bottom steering column cover, its best that you either tilt the wheel up or down depending on which way you have better access to where you’re working
http://www.scionlife.com/tech/images/epod_gauge_xb/pod12.jpg
12. Use flathead screw driver or narrow headed parts popper to wedge between the upper and lower halves of the cover near the front on the left and right side, take care not to mark up the plastic
http://www.scionlife.com/tech/images/epod_gauge_xb/pod13.jpg
13. Turn screw driver 90˚, again careful not to scratch the plastic
http://www.scionlife.com/tech/images/epod_gauge_xb/pod14.jpg
14. Pull and push apart cover carefully, do not bend, force etc either part to move, take time to prevent damage to other parts, when pulling the top out its best to pull towards yourself and then up
http://www.scionlife.com/tech/images/epod_gauge_xb/pod15.jpg
15. see number 15
http://www.scionlife.com/tech/images/epod_gauge_xb/pod16.jpg
16. see number 15
http://www.scionlife.com/tech/images/epod_gauge_xb/pod17.jpg
17. its naked
http://www.scionlife.com/tech/images/epod_gauge_xb/pod18.jpg
18. see number 17
http://www.scionlife.com/tech/images/epod_gauge_xb/pod19.jpg
19. see number 17
http://www.scionlife.com/tech/images/epod_gauge_xb/pod20.jpg
20. Align tabs on side of cover
http://www.scionlife.com/tech/images/epod_gauge_xb/pod21.jpg
21. Connect together, make sure everything lines up and goes together smooth
http://www.scionlife.com/tech/images/epod_gauge_xb/pod22.jpg
22. Tighten allen head
Finished pictures with guages coming soon.
Manufactuer website
http://www.autotechinteriors.com/products/product_epod.php
8. see number 7
9. see number 7
10. see number 7
15. see number 15
16. see number 15
17. its naked
18. see number 17
19. see number 17
Manufactuer website
