View Full Version : FYI Tire rack now has the xB picture loaded
TSiAWD 02-19-2004, 09:23 AM You can now see the rims on an xb.
even better they have hot lava as a color for the xB so you can even check which color you like better!
Munch 02-19-2004, 11:08 AM That's cool, but Tire Rack dosen't have a good selection of wheels. They have good deals on tires though :D .
TSiAWD 02-19-2004, 11:43 AM But any thing is better than nothing!
DJ_X_Trodinaire 02-19-2004, 12:49 PM werd[/img]
1sikxb 02-19-2004, 02:08 PM Try this
http://www.tirerack.com/upgrade_garage/WheelSearch.jsp?&autoMake=Scion&autoModel=XB&autoYear=2004&autoModClar=
To bad you cant alter the height
xBguy 02-19-2004, 02:34 PM Try this
That is such a cool feature!!!! Just think if we alter the height and then put the wheels in motion!!!!!
All wheel/tire sites should have that!!!
CBSIMONSEZ 02-19-2004, 09:23 PM That's cool, but Tire Rack dosen't have a good selection of wheels. They have good deals on tires though :D .
I concur, i was looking at this site for wheels when i first started, but i have found many more styles i like, and better prices other places. Im going to end up getting my wheels from a dealer in Ebay, $750 for everything.
George 02-19-2004, 10:04 PM Try this
Not to mention having the correct number of lugs! :)
EL_PAALO 02-19-2004, 10:53 PM Tirerack actually test fits everything, so you know when you order from them there will be no issues. SSR and OZ does tend to be more expensive than other commonly available brands, but they're worth it. Tirerack carries some less expensive stuff too. They tend to be a little conservative on their sizing and offsets though, so you're less likely to get a "flush" fitment because it's likely to rub under certain conditions.
rattmobbins 02-19-2004, 11:10 PM Tirerack actually test fits everything, so you know when you order from them there will be no issues. SSR and OZ does tend to be more expensive than other commonly available brands, but they're worth it. Tirerack carries some less expensive stuff too. They tend to be a little conservative on their sizing and offsets though, so you're less likely to get a "flush" fitment because it's likely to rub under certain conditions.
Huh? I thought you said they check evrything so there are no probs.... then you say they might rub cuz they aren't flush???? I'm lost :?: :?: :?:
TSiAWD 02-27-2004, 06:54 AM No, otherway around.
Tire rack is conservative, meaning the rims generally tuck under/behind the fenderlip, whereas a lot of folks here are looking for FLUSH which is even with the fender lip.
With a FLUSH fitment, if you dropped it enough and hit a big pothole etc or had a lot of body roll the fender would hit the tire.
xdorkx 08-11-2004, 12:25 AM Theres another site similiar to this, where u can lowe the car, etc. anybody know this one?
signalxB 08-11-2004, 12:45 AM Motegi Racing has a better one. you can even slam the car.
http://www.autowaretech3.net/swonline/motegi.htm
but of course, only motegi wheels. not a bad selection though. check it out.
RogerTTR 08-11-2004, 10:19 PM Check this link to see and example of lowering. Unfortunately, it's not the xb shown, but it will give you a good idea of the visual effects of lowering!
http://www.tirerack.com/suspension/lowering/golf.html
xdorkx 08-12-2004, 04:42 PM Okay, that's sweet Roger, really shows the diff a 2 inch drop with bigger wheels can do! i'm planning on getting wheels and dropping my box this weekend, if all goes well, i'm pretty stoked on it... :) woot woot!
