Visor Tint - Windshield Curvature - Straight Line?
Question for Tinting Experts; I want a tinted visor that has a straight line across the windshield rather than a bow. Because of the curvature of the windshield, the center of the bow gets way too narrow and in my opinion looks bad, wide on the edges, narrow in the middle. The problem is that I can't figure out how to cut the film so that it ends up a straight line. I took it in to have it done by a so called experienced tinter and he had no clue. Anyone encountered and/or solved this? Thanks!
Music City Scions
Run a tape line straight accross the window on the out side and use it as a guide to trim the tint the way you want. Personally I like the way mine curves down towards the outer edge of the windshield. It gives you better coverage where you need it. IMO
i am a tinter. there's not much you can do. if you try and cut a straight line, you will fail. i have great hands and am very precise with my cuts but woud't be able to do that. just leave it or tint the whole windshield. and there is no guide that will make a straight line on that windshield; it's too curvy.
Make a Pattern with some kind of Paper.
OUTLINE the TOP of Windshield
Using a Mesuring Tape/String/straight edge Draw across that line , from one point on 1st side and equal length down on Other side .
It WILL "look" Straight
ON THE Windshield - but on the floor it Wont .
Put the Pattern on the Floor or Table , ADJUST and DRAW the LINE better , Then CUT OUT the Pattern and TAPE it to the FILM and CUT it OUT .
As long as you DONT follow the the TOP LINE of the Windshield , it will be as CLOSE as you can get to STRAIGHT .
What I've seen others do before:
* Take a roll of freezer paper or poster paper and unroll it on the windshield. Cut it a little bigger than the width of the windshield, then tape it in place.
* Take a chalk line (like carpenters use) and pop a line from one side of the windshield to the other in a straight line wherever you want it, say 6" down from the top of the windshield (you'll need someone to hold one side of the line for you).
* Trace the top curve of the windshield and the sides onto the paper, then take it off the windshield and cut it out along those lines and the chalk line.
There's your template!
Tape the tint down? Paper patterns? Chalk lines?
Jesus, you people make things complicated. I'm really loving the folks who say (in so many words) there's nothing you can do about the "wide on the side - skinny in the middle" look.
Not only is it perfectly doable, it's faster to do than a regular visor that you have to triple check side to side to make sure it's 'level.
Here --> but keep in mind, what you're seeing is an illusion... it's impossible.
that is just an ilusion. they only cut the corner to give the round look. and that why it look strait. from the outside it look straight. from the inside it will look curvy.
whe i do banner that what i do. i just cut the corner to make it look like that. but is an ilusion.
well , i know what you mean , and here is the easy and best way to do IMO , line up the bottom edge of the film to the top molding of the windshield, cut the film to follow that , slide down to desired visor thickness , and trim ...
When I got my done, the guy showed it to me both ways and let me choose. I like the tapered look but doing either was equally easy. Here's how they did it:
They sprayed the window with water or whatever they use. they took a roll of film and put it across the top edge of the outside of the window. Adjust it to where you like the look, straight or tapered. When it's positioned how you want it to look, take a sharpie and trace the outer edge of the top and sides of the windshield. You want to go along the edge of the glass as seen from the inside. Take it off, cut it to the sharpie line and then apply it to the inside of the window. It seemed really easy watching them do it. Hope it helps.
The only "curve" is in that it follows the glass contour - JUST LIKE FACTORY -. There's no "illusion" about it. I used the word to poke a little fun at tinters who say it's only possible to make visors that are fat on the side and skinny in the middle (which is completely incorrect) - but alot of tinters also incorrectly tell you you have to leave gaps on the top edges of doors, that you have to leave windows rolled up for X-amount of time after tinting, that cut up rubber seals on 1/4 glasses is the only way to hide edge gaps (like on the back doors of an xB) - or that edge gaps are even neccessary, etc etc etc.
As far as
Looks sweet BUT... How is it done??? You forgot to mention that part
yea Ratpack, you totally threw me dude
windowtint is one of the most knowledge people on this board. and not just on window tint. id go with him on this. what diff. would it make if the inch sides curve? we're talking about the arch that curves in the MIDDLE of the windshield here. how can that be an illusion? is it like magic? we'll call him "houdini windowtint" from now on i guess. the ignorance is killing me. anyways, nice xB windowtint, i hadnt seen pictures in awhile.
and for those wondering how to do a straight line, make sure you PM windowtint and only him, i think you'll get the best results and best answer that way!
Originally Posted by claybo1708
Tape it off and spraypaint your brow on the inside with flat black spray paint!!!
An interesting side point - there are a few "tinters" (notice the qoutes) that do do just that on the BACK glass on some cars. Cars with a wide area of dots (like what's in the middle of the xB's windshield) such as Mustangs, 2dr Accords, Maximas/Sentras, Camaro's, etc etc. They paint that dotted area because they don't know how to tint over it and make it look good also. I got a whole photo album on the front counter of those and other cars - cover on the album says "What Not To Do To Your Car".
oh - sorry - almost forgot - spray paint is damn near next to impossible to remove 100% from glass. Even with some good-for-your-health solvents like MEK and Xylol. It gets down into the pores of the glass and you can scrape and wipe most of it off - but you always have these little black specs peppered all over the formerly painted area
