Tire Inflation Reset Button
Old Apr 24, 2005 | 08:47 AM
llgotscionll's Avatar
Default Tire Inflation Reset Button
I rotated my tires today and I noticed that my tire pressure light suddenly came on. I went to the gas station to put air into my tires and saw that the pressure lights were still on. So I decided to read the manual and it said that once I filled up the tires with air, I need to press the tire pressure reset button. Does anyone know where it is??
Old Apr 24, 2005 | 09:24 AM
TurboMe's Avatar
inside the glove box there should be a little button on the top left corner
Old Apr 24, 2005 | 03:50 PM
boostedscion's Avatar
lol... that's easy
Old Apr 24, 2005 | 04:23 PM
thanks.
Old Apr 24, 2005 | 04:48 PM
Lonely_Raven's Avatar
Wow, I didn't know the tC was so diagnostic. That's pretty cool.
Old Apr 25, 2005 | 06:00 AM
I pressed the reset button inside the glove box and the light goes away. Then 15 minutes later, it comes back on. What is wrong with my tC??
Old Apr 25, 2005 | 06:03 AM
hejustlaughs's Avatar
Kiss it first... j/k. Hmm That's weird. Your tire pressure sensor works off your abs... it should've calibrated itself. Did you drive around for 10 minutes and the light came back on or did you wait 10-15 minutes then the light just came back on?
Old Apr 25, 2005 | 06:24 AM
dsmith5237's Avatar
You should check the tire pressure of all of your tires. If one side is different by more than a couple pounds it'll trigger the light.
Old Apr 25, 2005 | 07:25 AM
Thats what I did. I was at the gas station and all the tires were around 39 psi. Maybe my friend rotated my tires wrong??
Old Apr 25, 2005 | 07:57 AM
Boobala's Avatar
IF you have the standard 215/45ZR17 tires, you're setting the pressure too high, they should be inflated to...
Front - 32psi (31.9psi to be precise)
Rear - 29psi
1) Adjust tire pressure as indicated above.
2) Turn ignition switch ON. If the tire pressure light comes on, press the reset switch (in glovebox) and release it.
3) Press and hold the tire pressure reset switch until the low tire pressure warning light blinks three times.
4) (Re)Initialization is completed after driving on smooth, dry, straight roads at a speed of 19mph to 62mph for an hour. (Max two people in car, including driver)
Old Apr 25, 2005 | 08:44 AM
DouBLeJ16's Avatar
I rotated my tires yesterday and the light never even came on. kind of weird.
I don't understand how it works if nothing is actually connected to the rim or tire.
Old Apr 25, 2005 | 09:07 AM
Boobala's Avatar
Each wheel (hub) has a speed sensor, and as the outer diameter of the tire changes with inflation pressure, the speed of the wheel changes in relation to the other wheels. The ECU measures the difference, and if one wheel is out of whack with the others, it throws a tire pressure warning light.
Old Apr 25, 2005 | 05:21 PM
Rear - 29psi
Aite thanks...I'll try adjusting the tire pressures.
Old Apr 26, 2005 | 08:28 AM
DouBLeJ16's Avatar
what does the tire pressure light look like and where does it show up? I want to make sure it's that and not the CEL.
Old Apr 26, 2005 | 08:54 AM
sorta like this ( ! )
Old Apr 26, 2005 | 09:00 AM
DouBLeJ16's Avatar
oh, ok.. it's definately my CEL then
afoulk
Dec 31, 2016 02:53 PM
okduffer
Scion xB 2nd-Gen Wheel & Tire
Apr 28, 2015 11:44 AM
idriveanxa
Mar 8, 2015 12:03 PM
DerekMarq
Jan 27, 2015 02:38 PM
BV19869
Dec 11, 2014 06:05 PM
