xB Factory Stereo Removal
I performed a search but it turned up nothing. I need to know if anyone has removed their factory stereos.
If so could you give me some insight on how to go about it. I know it couldn't be hard but I don't want to break anything.
Thanks
Thanks
the center panel pops out it has a few clips around it then you unplug the a/c and hazard lights switches when you pull the center out and the center piece can be put aside and there are 4 screws holding the radio in place.
pull off the climate controls,there will be two screws,after that just pull off the panel that covers the radio and climate controls ,everything else just pops off,then u will see the screws for the radio
yeah forgot about the screws... here is what i was looking for
https://www.scionlife.com/forums/viewtopic.php?t=23214
all you need to know to remove
heres a pictorial i used to take my radio out i hope it helps
https://www.scionlife.com/forums/viewtopic.php?t=11283
Originally Posted by jdmrider
Okay thanks, does the factory radio have AUX inputs? I want to hook my ps2 up to it so the sound will go through the speakers when I'm watching my screens.
Originally Posted by Logjam Electronics
The PIE TOY03-AUX Auxiliary Input Converter converts the CD Changer port of your factory radio into an auxiliary input. With this converter installed, you can connect any device that has RCA outputs directly to your factory radio without using an FM modulator. The TOY03-AUX works with most 2003-2005 Toyota vehicles that are equipped with a radio that has CD changer controls...
$70 + S&H
RPM
wiltonhall
Jun 23, 2025 10:09 PM
NewBox06
Feb 3, 2015 12:36 PM
poppyljg
18
Feb 13, 2004 01:35 AM
