AVN2454 Problems. Please help.
Old Apr 27, 2005 | 09:20 PM
jjf112's Avatar
Default AVN2454 Problems. Please help.
Hello, I bought an AVN2454 in February and have only been really using the navigation in my tC. When I installed it, I tested the dvd player to make sure it played but I didn't test it past the title screen.
I tried to use recently and noticed that I can't get past the title screen. If I try to press play or skip to the next chaper it says: "This function is currently disabled". I thought it was a parking brake grounding issue so I switched the ground from the screw behind the unit to the black/white wire that is connected to the cigarette lighter. Still the same problem. Still if it was the grounding issue, wouldn't the unit just not play the dvd at all?
Anyone have this problem and know how to resolve this?
Thanks
Old Apr 27, 2005 | 11:37 PM
Jonesi's Avatar
Default Maybe try this
Won't swear to it, but put the ground back to the deck ( the factory wire) THEN follow it down & move it from the emergency brake. I was told that the factory has some "special" bullcrap. My buddy moved mine after the same prob & now mine works fine. Best of luck!
Old Apr 28, 2005 | 01:22 AM
thefajitascandal's Avatar
ive gone through 2 screens and both i just wired to my dimmer ground and never had a prob, u might wanna try that. But im pretty sure it would say parking break or something and not even show the menu, but i guess its worth trying.
Old May 19, 2005 | 06:08 AM
HughDTX's Avatar
Default Re: AVN2454 Problems. Please help.
Thanks
You may or may not find this funny, but you aren't using it correctly. I just got mine running today and was having trouble too. I realized that you can't use the touchscreen on the actual DVD menu. You have to use the blue buttons, and before you play or skip chapters, you actually have to start playing the movie by using the MENU button and then use the arrows that appear to select the DVD menu option. I hope this helps. but I know it's confusing. Just read your manual and know that it's not a hardware issue.
Old May 19, 2005 | 10:19 PM
RanmaP's Avatar
Default Its one of the downfall
The AVN2454 has a poorly made DVD navigating menu. Sometimes those damn blue buttons would cover up the title menu on some DVD movies and you can't even see what your selecting.
The unit can be used with remote which is good, but only works with audio (mp3, CD, etc.) which sucks since you can't navigate when playing DVDs.
Old May 19, 2005 | 11:02 PM
jjf112's Avatar
Yup, thats what support told me. I finally emailed them and thats what they said. Kinda retarded that i couldn't figure that out.. and it definely is a poor user interface..
Old May 20, 2005 | 08:02 AM
Eiso's Avatar
Same for AVN5435! I knew its not about the grounding issue! Also, please read the manual! I read them for hours before I drive out the shop!
Old May 20, 2005 | 08:04 AM
kris79's Avatar
i had the same questions when i first got mine, but i figured it out.
yupinmytC
22
Jul 27, 2024 07:08 PM
yhwhdesign
Jun 11, 2021 03:34 PM
KSwag
Jan 24, 2016 07:52 AM
MeDizzy
Oct 8, 2015 03:31 PM
Andrew75
Jul 27, 2015 09:37 AM
