chrome or no......
Old Apr 29, 2005 | 12:39 AM
bballplayer0968's Avatar
Default chrome or no......
Ive searched on the website and cant find anything about this so here it is...........................do chrome wheels really wheigh u down that much, and if they do how much of a difference do they make
P.S. im getting 17's with a 45 profile so i should be good right??
Old Apr 29, 2005 | 01:07 AM
any one know if chrome makes a difference?????????
Old Apr 29, 2005 | 01:23 AM
NHGrafx's Avatar
Yeah chrome rims can get kinda heavy, but it shouldnt cause a problem.
Old Apr 29, 2005 | 01:24 AM
dgHotLava's Avatar
moved...
Old Apr 29, 2005 | 01:25 AM
xB_Nutt's Avatar
It's not the chrome plating itself that weighs you down, but typically chrome plated wheels tend to be very heavy due to their construction and spoke pattern. They are more for bling than performance.
Old Apr 29, 2005 | 02:45 PM
THE_DON's Avatar
Only if you get a "fat" chrome wheel. Most wheels, even the so-called "racing" brands, offer their designs in chrome. And even if they don't, you can have ANY wheel chrome plated.
I have Motegi Racing MR3s in chrome, it only added like 1-2 pounds to the wheel, which was already classified as "lightweight".
-THE DON
Old Apr 30, 2005 | 08:13 PM
bump
Old Apr 30, 2005 | 08:25 PM
scionspecialistvegas's Avatar
watch the offset when going with 215\45\17's. could run into inner fender wall rubbing. Bill
Old Apr 30, 2005 | 08:44 PM
marcs_xb's Avatar
You will want a "lightweight" chrome rim, so check out the Kazera rims at www.tirerack.com. My 17"s weigh in at just under 20 lbs each. Many 17" chromes weigh as much as 25-26 lbs. Check out the weight before purchasing. I'm running a 215-40 tire with no rubbing whatsoever and they are the same diameter as the stock rubber.
One pound of unsprung weight is equal to 8 lbs of sprung weight. Five pounds per wheel would be the same as adding 160 POUNDS to your box!!!! Think about it.
Old Apr 30, 2005 | 11:40 PM
Kremtok's Avatar
Please explain this. How is the mass of the wheel multiplied?
Old May 1, 2005 | 07:05 AM
M-Flo's Avatar
http://www.answers.com/topic/unsprung-weight
Amazing what 10 seconds on google can do.
p.s. Though I'm unsure of the math behind it, there are MANY factors that affect overall performance, weight is one of them.
Old May 2, 2005 | 11:01 PM
RogerTTR's Avatar
FYI, as an example, on a 17 X 7" wheel, "Chrome Plating" will add approximately 2.0 pounds to the weight of the wheel if compared to the same wheel with a painted finish!
Old May 2, 2005 | 11:27 PM
LauderDog's Avatar
Hey DON,
JEEZUS do those rims look good. Excellent taste.
--Matt
BSP xB, Fort Lauderdizzy
Old May 2, 2005 | 11:40 PM
YRDaddy's Avatar
I say B.S.!!!!! Where did you get these numbers?!?! I work as an inspector in a sheet metal and machine shop. I deal with all types of plating (chrome, zinc, anodized, etc...). I'd like to know who started this ridiculus notion that plating adds "pounds" to its parent part! Plating does not add significant wieght to anything, only significant style points! Go with chrome!!! Later! :D
Old May 3, 2005 | 02:59 AM
THE_DON's Avatar
Originally Posted by LauderDog
Hey DON,
--Matt
Thanks!
Motegi Racing MR3 18x7.5 Chrome
-THE DON
airmankevin1
Nov 17, 2015 05:44 AM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
umnitza
Sep 1, 2015 08:06 PM
rvascion
Scion xB 2nd-Gen Wheel & Tire
Aug 16, 2015 02:26 AM
archangel
Apr 12, 2015 01:33 AM
