HELP ! ! !
Old Apr 29, 2005 | 04:49 PM
tybox04's Avatar
Default HELP ! ! !
I removed the system i had installed in my car so that i can rebuild it. trust me it was a mess or else i would have left it. the problem is that now in the process of rebuilding it, i have no time to work consistently on it, but for some reason i dont get any sound now. my radio turns on but no sound??? PLEASE HELP !!! I NEED MUSIC...
Old Apr 29, 2005 | 04:56 PM
ack154's Avatar
That could be a million things if you're "in the process" of rebuilding or whatever. But what are you "rebuilding"? And what does it constitute? Wiring? Physical locations? What?
240SXtoTC's Avatar
sounds to me like you need professional installation. you need to be more specific if you want anyone to be able to answer.
jmiller20874's Avatar
Umm, could you be a little more specific? What exactly did you remove? The stereo, speakers, sub, amps, all of the above? If you're running an amp to your speakers, double-check all fuses and grounds.
Old Apr 29, 2005 | 04:58 PM
tybox04's Avatar
haha, my bad.. yea it is the audio system... removed subs and amps...
Old Apr 29, 2005 | 06:07 PM
SCI_TC_GUY's Avatar
did you take the amp out that were running the mids/highs???? perhaps that's why you don't get any sound....cause you took it out.....
Old Apr 29, 2005 | 08:23 PM
tybox04's Avatar
i had taken it out, i figured that was the problem, so i put it back in, im positive the wires are in correct, but still no sound...? ? ?
Old Apr 30, 2005 | 06:18 AM
tybox04's Avatar
can i BUMP my own thread?? anyway, i need help any1 have this problem??
Old Apr 30, 2005 | 02:46 PM
riccochetrabbit's Avatar
Check your inline fuse(s) and check the fuses in the car. Check your ground(s). Check the remote wire (make sure it is free of cuts, nicks, breakages in the wire, connected to the amp, etc). Check your speaker connections. Check every component of the system /install.
Old Apr 30, 2005 | 02:57 PM
UBOW's Avatar
One thing to note here, when working around the dash, disconnect the battery. If you are only working on the dome light or tail lights it may not be that critical, but in the dash is it necessary.
As riccochetrabbit suggests, check your fuses. Hopefully it is as simple as this.
Old Apr 30, 2005 | 05:08 PM
tybox04's Avatar
o man, i dont think it is the fuses, because the radio turns on, but it may be a fuse that the amps run off of ? ? ?
Old May 2, 2005 | 02:32 PM
SCI_TC_GUY's Avatar
yeah......check the fuses IN-LINE with the amp(s).....you probably forgot to put one back in.....
Old May 3, 2005 | 02:10 AM
tybox04's Avatar
whats an in line FUSE? ? ? the fuse in the amp is fine, and the fuse in the car that connects to the radio is fine...
