AMP wiring KIT Question: 2 Wires ?
Old Apr 29, 2005 | 10:54 PM
CyRaX2007's Avatar
Default AMP wiring KIT Question: 2 Wires ?
Maybe I'm confused, but I have wired amps to cars before,
I recently purchased a Rockford Fosgate Amp Wiring Kit and it says something about having two different Power Gauge wires.
I think it says there is 4 gauge Power wire and 8 gauge Power wire, why would they give me two different types of power wire.
I only have ONE 1000w amp to wire, so should I just go ahead and use the 4 guage wire ??
Old Apr 29, 2005 | 11:16 PM
-Keith-'s Avatar
does that cuz you should run the 4 gauge from the batter back.. to a distributuon block then it reduces down to 8 gauge.
Old Apr 29, 2005 | 11:21 PM
CyRaX2007's Avatar
wot do u mean distribution block, so i hook 4 up to battery, and then when do i switch to 8 ??
Old Apr 30, 2005 | 02:29 AM
-Keith-'s Avatar
if u bought a amp kit should of came with a distribution block like a fuse block... 4 gauges comes in on the other side 8 gauges goes out
Old Apr 30, 2005 | 04:57 AM
riccochetrabbit's Avatar
For the current draw you're going to have, I'd have to recommend that you run the 4 gague all the way into the amp (assuming it accepts that large of an input gague. The reason that it comes with a distro and the 8 ga is because lots of amps don't accept that large of gague, and lots of people like to run a larger gague for upgradability issues. The 4 ga to combat line loss then the 8 because their amp only accepts it.
Old Apr 30, 2005 | 05:32 AM
CyRaX2007's Avatar
here comes a major nubstick question, how do i tell if the AMP will accpet the 4-ga line ??
Old Apr 30, 2005 | 05:49 AM
chadfo's Avatar
Just check the size of size of the terminal compared to the size of the wire. With 1000W amp I would be surprised if it wouldn't accept a 2 Ga. wire.
Old Apr 30, 2005 | 06:18 AM
CyRaX2007's Avatar
looks like i get to use the fuse block -- thanks for the help all
Old Apr 30, 2005 | 08:49 PM
CyRaX2007's Avatar
Another Question, since I have a fuse block and I am only using ONE 1000w amp, should i put a larger fuse in the fuse block:
This is the current set-up:
{Battery}====4GaugeWire===[60a fuse]=======4GaugeWire=======[FuseBlock:30a fuse | 30a fuse]------8GaugeWire------<1000w Amp>
i guess the block is designed to split between two amps, but i only have one amp so should i be putting a 30a fuse in that block, or should i get the 60a or what ??
Old Apr 30, 2005 | 11:54 PM
-Keith-'s Avatar
Just so you all know not many amps take 4 gauge straight in......
Old Apr 30, 2005 | 11:55 PM
-Keith-'s Avatar
The point of having the one fuse up front is to not back feed... Which is so unlikely to happen... Then the last one is just incase it would spike.... and fry the amp... 30 is a little low... for a 1000 watt amp I would think 60 - 100
Old May 2, 2005 | 02:18 AM
TCRS193's Avatar
some advice about past experiences, Place the a fuse as close to the battery as you can. If for some reason your power cable rubs through or gets punctured and gounds out, having the fuse close to the battery will will allow the fuse to blow without the risk of causing a fire or melt down of whatever is in the way.
And the Amp itself should have a fuse built in it. Find out the amp rating and match it on your fuse block. Just dont go any higher than the recomended rating of the amp.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
streetracerr
Jul 11, 2015 09:52 PM
randode
44
Jun 29, 2004 04:19 PM
Besk_one
Nov 17, 2003 09:28 PM
deathcabforme
Oct 16, 2003 04:02 AM
