June 2005 Import Tunner
Old May 1, 2005 | 03:01 AM
SGall's Avatar
Default June 2005 Import Tunner
While flipping through the new issue I came across the power pages with a 2004 Scion tC (thought it was a 2005) they did a dyno on the AEM CAI and showed a 3.9hp and 2.3 lb-ft of torque. I am glad I did not wait, and went with the K&N.
Also the power gains on the DC Sports Exuast is minimal for the cost 3.2hp and 2.9 lb-ft of torque.
They also did the a dyno with the DC Sports header which showed good gains 8.5hp and 7.8 lb-ft of torque.
Just thought you all should know
Old May 1, 2005 | 03:18 AM
DevoTek's Avatar
Thank you! Now this makes people think twice (https://www.scionlife.com/forums/vie...r=asc&start=25)
what i said about intakes dont make what AEM and other intake companies claim, you know that 6.1+ hp bs. Hahahaha
Dont Believe that 30hp gain just a Header alone
Dont Believe that 6.1hp+ gain just a Intake alone
Dont Believe that 15-20HP+ gain just a Exhuast alone
Thank you for posting this.
Old May 1, 2005 | 03:32 AM
hejustlaughs's Avatar
They forgot to put on the decal, duh!
Old May 1, 2005 | 03:40 AM
DevoTek's Avatar
bahahaha put i heard putting the decal infront of your bumper will increase that 6.1hp gain.
Old May 1, 2005 | 03:52 AM
tckurt's Avatar
N.G.S.O.
Yea i saw that issue as well but you forgot the most important part of the article it was dynoed on 19"s so dont get to cocky b/c its probably the same as the k&n CAI
Old May 1, 2005 | 04:00 AM
DevoTek's Avatar
19"s
Old May 1, 2005 | 04:11 AM
daewonder's Avatar
i'd never believe the dynos in IT.
Old May 1, 2005 | 04:16 AM
DevoTek's Avatar
why?
Old May 1, 2005 | 04:22 AM
TurboMe's Avatar
its possible to get those numbers from a FI car but a NA car, no way!
Old May 1, 2005 | 06:00 AM
SGall's Avatar
actually they were 18s[/quote]
Old May 1, 2005 | 07:04 PM
boostedscion's Avatar
sounds good.. thanks
Old May 1, 2005 | 08:39 PM
metalranger33's Avatar
woot i dont feel so bad haveing headers now
Old May 2, 2005 | 12:27 PM
tckurt's Avatar
N.G.S.O.
Well the issue I read it in said 19s maybe a misprint... either way the AEM makes around the same as all the other CAIs no of them are gonna be much better than another.
Old May 3, 2005 | 04:46 AM
DevoTek's Avatar
Well in my issue it says 18. But you're right about ALL Intakes are all the same, its just a matter of the "NAME".
Old May 3, 2005 | 01:37 PM
slowpoke's Avatar
The size of the rim has nothing to do with numbers on a dyno
Old May 3, 2005 | 01:43 PM
wyldkard's Avatar
I'm gonna have to grab a copy of IT the next time I see it.
-Z
Old May 3, 2005 | 08:56 PM
gwtc's Avatar
Yeah, I read that too, but at least it will be carb street legal.
Old May 4, 2005 | 03:51 AM
kwc5811's Avatar
Or, maybe it does? If I had 15" rims then I could get the 205hp without buying the SC! Yeeah, I dont have to wait till spring/June/mid-summer/August/fall/by the end of the year to get the SC!
Old May 4, 2005 | 03:57 AM
Joe_Dezod's Avatar
It doesn't affect crank horsepower but it may have a small effect on the dyno.
A larger wheel is usually heavier, and because it's greater diameter, this is a large increase in rotational mass. This means the engine has to work harder to overcome the inertia and make the wheel spin faster. The engine is making the same power, but some of that is lost in energy put into making the wheel spin to begin with. Now it's not MUCH, but it's enough that higher hp race cars only use larger wheels if they need more rotor/caliper space, as well as filling out the space to keep a low profile tire (which helps for steering response and agility).
If I'm racing, I'd much rather use 16s or 17s than my 18" wheels. You can feel the difference if you push your car enough.
-Just my 2 cents, not trying to get off topic...
Old May 5, 2005 | 11:53 AM
tckurt's Avatar
N.G.S.O.
You dont know to much about how cars work with dynos do you...
Yea thats what I said and maybe if you get 10" wheels you can have 300hp... Let s all be jackasses! The wheels on a car can change results of dynos by a few hp which is what it probably did as the dc header has dynoed higher than what it did for them...
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Bimfi
Sep 4, 2015 08:15 PM
umnitza
Sep 1, 2015 08:06 PM
formerpraetorian
Jul 22, 2015 01:05 AM
