View Full Version : Koni adjustable shocks and TRD springs installed
jackmott
02-22-2004, 01:29 PM
Installed these yesterday. The Konis I got from spy engineering, for around $600. They are single adjustable, you can adjust the rebound rate. The front struts are easily adjusted from the top, just lift up the hood. The rears you have to unbolt at the bottom to adjust.
Overall I am pretty pleased. I think at times I would prefer some linear rate springs instead of progrssive, but I would probably regret it a lot on houston roads too. The car definitely has more grip now and is a lot more fun to toss around. H ave the shocks set just short of full stiff and the ride is perfectly comfortable still.
dinkjs
02-22-2004, 02:37 PM
When did Koni bring out struts for the xB???
jackmott
02-22-2004, 02:47 PM
Ive got an XA, but I presume it would work on the XB as well.
Spy Engineering had some made somehow. The fit is perfect, even has all the bracketry and everything.
Scoobyslack
02-23-2004, 03:19 PM
are they available in Japan?
they might have just got a set from there since the car has been out there for a little while
