xB Amp Mounting Locations
Old May 3, 2005 | 07:22 PM
wooky1976's Avatar
Default xB Amp Mounting Locations
1. I tried to place one in the back of the rear passenger seat but the child seat stuff is blocking it. Where else is a good place. How about under the driver or front passenger seat. How about if I have a 2 ft long amp like a 5/6 channel amp.
2. I have been searching, but I haven't found what speaker can be fitted in the front doors without a spacer. Is it just a depth problem or the diameter because I have a midbass speaker that is 6.75 in. I really hate it if I need a spacer.
Old May 3, 2005 | 09:26 PM
HawkWolf's Avatar
You can just stick it under the passenger / driver seat. I put mine under the passenger since that's the side of the car my sub is on and where I ran the cables. I don't think you even need to really mount it to anything.. you could just make little lifts to keep it out of wetness and give some more air circulation, and put some traction-improving things on the bottom of the lifts to keep it stuck on the carpet.
You need a spacer for the front speakers. 6.5" is the stock size... if yours are bigger you probably need a thicker spacer. Jigsaw + MDF = your friend.
Old May 4, 2005 | 03:14 PM
Notacop's Avatar
I have 2 amps and my sirius radio tuner all mounted under my passenger seat, I had a local machine shop make a metal bracket to fit it all.
Eclipse 3640 amp is mounted to the floor, MTX 2150 is above that on the bracket, sirius tuner is above that on the bracket.
Old May 4, 2005 | 03:43 PM
neckbonenick's Avatar
The amps do mount nicely under the passenger seat. You can even stack them. Also you can put it in the rear storage compartment.
Old May 4, 2005 | 04:11 PM
nilus's Avatar
Got mine under the front passenger seat, too.
Nilus
Old May 4, 2005 | 04:28 PM
LowProMofo's Avatar
Mine is there now, but it'll overheat when it's played for so long and in hot weather.
Old May 4, 2005 | 04:53 PM
drew05xb's Avatar
Nilus
Nice Mac!
Old May 4, 2005 | 08:06 PM
nilus's Avatar
Thanks, man. Recently got it for $200 from an authorized dealer (it was an old demo)!
Only 2x40 but it's surprisingly powerful (running a set of Dynaudio 240GTs).
Nilus
Old May 4, 2005 | 08:25 PM
Lonely_Raven's Avatar
Wow Nick, that is such a nice clean install!!
Did you do it yourself, or is it a shop install?
Must have been a long run of speaker wires for the crossovers, looks painful, but
VERY clean and well laid out!
Old May 4, 2005 | 09:14 PM
LaVa~NyC's Avatar
wooky, i have a zapco ag 650 6-channel amp..this thing is 36 inches..i slapped it to the bak of the box...it looks plain,,but thier was no way i was gonna get rid of a 1000 dollar amp for 2 smaller 1's
Old May 4, 2005 | 09:19 PM
rcstprez's Avatar
If you dont need the child seat deals, they just pop right off. Then, technically, you could mount a thin piece of wood to the structure of the back seat, and then mount the amps to that, and route the wires under the black carpet stuff that covers the back of the seats..
Old May 4, 2005 | 09:26 PM
djct_watt's Avatar
Team Sushi
If you mount in the compartment, you can also place in a couple of 12 volt computer fans. . . it will get rid of your overheating issues
Old May 5, 2005 | 02:11 AM
LaVa~NyC's Avatar
Nilus
hey niles..i was gonna do that,but ur from nyc,,what happenes when it snows and ur bottem carpet gets all slushy from peoples feet...i was gonna do that,but then i thought about it....audio forms makes a amp rack that replaces ur back window panel,that looks hot,if u got decent size amps
Old May 5, 2005 | 03:01 AM
djct_watt's Avatar
Team Sushi
Yeah. . . I get worried about people tracking in water
Old May 5, 2005 | 12:09 PM
Lonely Raven
Yeah I did install it myself. Took about a half a day and the wiring was a major piece of work. The hardest is getting wire through the grommets to the doors. But yeah I think I will be installing some fans or a better amp with fans in it or that just doesn't get hot to replace this $14 ebay jensen amp.
Old May 5, 2005 | 01:52 PM
nilus's Avatar
Simple solution, Lava--nobody rides in the back.
Actually, my doberman is generally the only passenger in the backseat, but even if people were back there, I think the amp is far enough out of the way to not be a problem. I guess I could always get/make something to cover it.
Also, I have thick plastic mats in the car to trap all the water, snow and sand from my surf and snow adventures.
That audioformz enclosure is really sweet...if I had a bigger Mac, with the wattmeters, I'd definitely go that route. But I was looking for a concealed install...too many thieves in our neck of the woods.
Nilus
Old May 5, 2005 | 02:31 PM
FrankenScion's Avatar
A club member has his amps mounted in the headliner in the rear.
Old May 5, 2005 | 02:34 PM
you could also do a raised floor like ikonXone did. Can't find pics. sorry.
Old May 5, 2005 | 02:37 PM
Probably becuase he is selling everything.
Xaphoon
Scion tC 2G ICE & Interior
Apr 22, 2015 02:36 PM
stillcole
Apr 6, 2015 03:42 PM
KILLER
Mar 29, 2015 05:32 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
