tC Tech and DIY Info for the Scion tC
Mirror Turn Signal Change
Old May 7, 2005 | 12:34 AM
Kaeon's Avatar
Default Mirror Turn Signal Change
Tools Needed:
Philips head screw driver
Flat Head Screw driver
Dremel
Cut Off Bit
Silicone
Switch Blade
Safety glasses
Clear Silicone
Sand Paper (Or Sanding bit for Dremel)
Plyers
Led's (I used Item Number 840556011262, Search for that ID at http://www.coolerguys.com
First off you need to get access to the lens we do this by removing the pop on cover.
The Cover is held in by 4 plastic clips (Purple)
Get your nail between the Cover and the Mirror and pry it off.
Take your flat head and wedge it between your lens and the plug, Pull upward to pop the plug out, Be careful you can see where I broke mine. You could also give the wires a good tug to get them out...
Plug out
Now your going to remove the (2) screws
Remove your lens
Your first part is done!
Now your going to need your Dremel and cut off bit
^Cut Off bit
Now your going to cut the lens off using the Cut Off Bit, Cut right above the lip where the lens and housing meet. Be sure to ware safety glasses!
When your cutting the plastic will melt itself back together, take a razor like so and go around the whole housing breaking the little plastic joints.
When you cut it all, the lens will come out like so.
Now we will need to remove these Leds
Take your plyers and get them under the base of the LED and break the (LEDS) off.
You need to sand the parts you plan to solder, The solder will not stick to it if you don't sand it.
Item Id: 840556011262 (I used there 5mm the 2nd time around)
Take one of the LED'S and cut a little bit off the shortest leg.
Now use that leg to bridge these together (What this is going to do is make the LED's Use the same + and -, meaing brighter LED's))
Now your going to solder in the LED'S(Green) The + Is on top(Red) and the - Is on the bottom(Purple), The Bridge is also in red.
* + Is the longer leg on the LED - Is the short leg*
Now put your lens on and seal it up using the Silicone, Let it dry for a good 8-12 hours. Recheck it for any holes, fill them in if needed. *Note* Id place a little bit of silicone under each led for extra strength.
Your all done! final finish is good except you can see the gold where it was sanded. It doesnt look bad just looks like a reflection. Led's are pretty bright, they are Ultra White so they have a hint of blueish'purple to them.
Old May 8, 2005 | 09:56 PM
tcsciontist's Avatar
Great write up Mr. Kaeon!!!
I salute you...
-PSYCHE!!!
Old May 8, 2005 | 11:17 PM
Kaeon's Avatar
Why thank you Dick. (Haha this is his name guys)
Old May 8, 2005 | 11:19 PM
TimO's Avatar
dude thats flippin awesome, its about time someone figured this out. thanks bro! ... to bad I'm selling my tC remember? lol
Old May 8, 2005 | 11:24 PM
Kaeon's Avatar
I give credit to The Instigator, He did it before me, just didnt write a DIY, Great member he even took apart his to show me how to wire it so its bright, The Instigator is Kaeon Approved!!!
Old May 9, 2005 | 01:12 AM
hotbox05's Avatar
pictures of finished results? I'll be doing the same to some of the xb led ones , somewhat soon. neat write up
Old May 9, 2005 | 12:40 PM
Kaeon's Avatar
Heh, Its looks no different just lights up white, I will get some night shots tonight gotta head to work right now...
Old May 9, 2005 | 06:24 PM
The_Instigator's Avatar
Allow me to show pics Kaeon.
*Thanks for the image* ~ Kaeon
Old May 10, 2005 | 08:56 PM
taek's Avatar
nice DIY. looks complicated lol
Old May 10, 2005 | 09:14 PM
Kaeon's Avatar
Not at all with Basic soldering skills your fine its just alot of simple steps.
Old May 30, 2005 | 09:41 AM
mokenso's Avatar
dang, very nice post!! pretty complicated tho..
hopefully therez gonna be aftermarket parts coming out soon so I don't need to do any cutting, soldering or sealing...
Old May 31, 2005 | 04:58 AM
Its really not that bad. The first one I did took about an hour..the second about 10 minutes. I have done another car since and it really is not a big deal. If you have any questions, you can PM me. As far as I know, I was the first one to do this mod and I helped Kaeon write up the FAQ.
Old May 31, 2005 | 04:59 AM
Heres another shot of the finished product
Old May 31, 2005 | 02:44 PM
Kaeon's Avatar
Actually 2 other people beat us to it lol!
Old Jun 3, 2005 | 09:22 AM
zero01's Avatar
that looks nice, I really wanna do that but afarid i might screw up really bad. How hard is it to take the top cover off ? Can i use a flathead to pry it off ?
Old Jun 5, 2005 | 07:46 PM
Are you talking about the painted part of the mirror? If so, you can pull it off with your hands. Get your fingernails into the gap at the top of the mirror and give a little tug...it comes right off.
Old Jun 14, 2005 | 04:35 PM
shin0bi's Avatar
does it go back in ok when you pull it off ?
Old Jun 14, 2005 | 07:07 PM
Kaeon's Avatar
Yes it goes back in fine...
Old Jun 14, 2005 | 07:38 PM
David616's Avatar
What kind of bulbs did you use for your front turn signals? Where did you get them from?
Old Jun 14, 2005 | 07:49 PM
toastbox's Avatar
FYI....as good as that looks, it's also illegal. Side markers are *required* to be amber/orange. Some states might fail your safety inspection, so be cautious.
It does look sweet though! Great job guys!
