View Full Version : Hydrolocked Engine?
DenZinz
02-24-2004, 07:55 AM
I noticed that with the Injen intake the filter is right behind the fog light section of the xB and can be clearly seen from the top grille.
Is anyone worried about Hydrolocking their engine by sucking water in the rain?
mikochu
02-24-2004, 09:50 AM
how deep are the puddles that you drive through? :shock:
dchan8
02-24-2004, 12:57 PM
in think the only way to hydrolock is to submerge the whole filter into water, if you were to do that i'd be more worried about getting the car out of the water/pond/lake, etc...
DenZinz
02-24-2004, 03:39 PM
So noone is a little bit concerned that when you drive water collects on the filter?
Regardless of driving through a puddle or not, the filter is collecting water.
Maybe the Injen guys on the forum could shed some light on how much water the filter actually breaks down before it reaches the throttle body.
rattmobbins
02-24-2004, 03:47 PM
let me tell you all a little something about how aftermarket air filters work. The filter is oiled to collect dirt and debris. Oil and water DO NOT mix. Rain is NOT going to get sucked up into your engine through your filter. Even with a cold air setup, the only way water is gonna get in through the intake is if the filter is submerged in a puddle (or lake :D ) for an EXTENDED period of time. Even driving through an occasional puddle will not damage your engine!!!
projxB
02-24-2004, 03:57 PM
i have my concerns at times, but we do live in souther california where we get a minimal of rain a year unless el motha f'n nino hits again. I do sometimes trip, like the other night coming home from BJs pizza it was pooring once i got off the 605 and I have pretty bad eye sight so i was a little uncertain if the street was flooded or i was just seeing things, and i was just seeing things. but i guess as long as you arent going through lakes and you have a grill like the stock grill that has the backing on it, you should be relatively OK.. :wink:
iy0ga
02-24-2004, 04:07 PM
ditto
squirrel
02-24-2004, 04:20 PM
denny, I've driven thru some pretty nasty downpours up here, and I haven't had any problems. infact, it was raining so hard one night, I had to slow down cuz I felt the xB getting ready to hydroplane! you know that feelin when you hit a deep puddle and it makes that thud sound and you slow down quite a bit?
TheRedBox
02-24-2004, 04:24 PM
I like driving through puddles.
:wink:
DenZinz
Brad,
And you have the Injen intake? Thats pretty impressive..
I guess im looking back to the old HKS Foam Power Flo days. :D
but if everyone says its good, then i guess its good. I just wanted to hear back from people that have an Injen intake and not the AEM with the bypass.
jdaniels
02-24-2004, 04:50 PM
The AEM bypass doesn't remove moisture/water from the intake. The purpose of it, is for if/when/why you drive into a large puddle of water that SUBMERGES the filter, it bypasses the flow through the filter to prevent suction from pulling the mass of water up the intake.
rattmobbins
02-24-2004, 05:17 PM
again I say.....
George
02-24-2004, 05:20 PM
Lots of misinformation in this thread!
1. Water will pass through an oiled gauze filter, through exactly the same passages that the air uses. Ask any off-road motorcycle racer that has dropped his bike in a river crossing.
2. It takes a fairly large slug of water to hydrolock an engine. You could put a liter of water into an engine in a minute without any ill effect. Hydrolocking is caused by putting a large amount of water into a cylinder in one stroke. A constant flow of water, such as that caused by rain droplets passing through a filter won't cause a problem.
3. There are two ways to hydrolock an engine. One is to submerge the filter. The other is to accumulate water in a low bend of the intake and then have it pushed into the engine when the accumulation is enough to block the intake. It's unlikely that the injen short intake will do either of these unless you are into fording rivers.
George
DenZinz
02-24-2004, 05:53 PM
George
Thanks, thats the answer I was looking for.
scionxb04
02-24-2004, 07:01 PM
ever heard of water injection? little bit of water is good....cleans out the carbon build up etc....like george said....whole bunch bad
Orataro
02-24-2004, 07:06 PM
If I recall, I read on Injen site that this intake should not be driven in wet condictions. That's why I haven't bought one. Also, I heard that oils from the filter can cause your "Check Engine" light to come on. :roll:
Just something I read and heard.
gulp35
02-24-2004, 07:24 PM
Wow this topic has a whole different tone since the last time it was posted. (Stupid noobs reposting topics)
Then I was the minority saying that water in the engine isn't something you have to worry about in normal driving.
DenZinz
02-24-2004, 07:30 PM
when was this topic brought up? Can you send me the link? I must of missed it.
ShadowMage
02-24-2004, 07:33 PM
Usually this is caused when you over oil a filter, at which point some of the oil from the filter gets sucked into the intake and lands on the MAF Sensor and can cause this. It can be cleared up by cleaning it with a little carb cleaner though.
NemoBronsky
02-24-2004, 07:51 PM
George
hmmm....First two are good points, no you won't hydrolock the engine from getting small amounts of water in the intake but lets get off hydro-locking and into the "small droplets don't harm anything" placing water in the combustion chamber can cause seriously damaging effects to the engine. Water cannot be compressed so that story about a liter of water is crazy- if you put a tea spoon of water into the tiny 1NZFE combustion chambers your going to bend/snap valves/connecting rods- blow piston rings- something. Something will have to give and it won't be the water. Also isn't anyone worried about rusting in the inside of the combustion chamber/exhaust from the eventual possible accumulation? Water will get into the filter, and it will get into the intake, and eventually into the combustion chamber if your driving through extremely wet conditions and not armed with something to slow it down or prevent it. Any water in the combustion chamber isn't good. The best way to prevent this is go to K&N's website and look for a drycharger- they go over the filter element and help channel out moisture, if you pick up the new K&N Typhoon intake(The best one available for the xB right now :D ) for the xB you automatically get a dry charger for free. Sorry it got so long- But I've been working on "everyday" cars for years and have seen just about everything possible go wrong- and water and engines don't mix unless it's in the cooling system. Thinking "minimal amounts don't hurt" is just asking for trouble in the long run.
Orataro
02-24-2004, 09:21 PM
Again I checked Injen's web site and it's disclaimer states that their intakes should not be driven in wet or rainning condictions. Failare to remove the intake will cause serious damage to your car.
Check for yourself.
www.injen.com
randode
02-24-2004, 10:10 PM
Check for yourself.
www.injen.com
A note regarding Cold Air Intake systems and Cold Air Extensions:
*Injen Technology Cold Air Intake Systems should be removed in any wet climates or on any wet roads or highways. Failure to comply with the above warnings may cause water to be absorbed into the engine through the filter causing serious damage to your motor. Injen Technology Co., Ltd. assumes no liability for damages toy your motor due to water entering your engine through the Injen intake system. Although a bypass valve may be used on most systems, it will void warranty and the C.A.R.B. EO# at this time.
Please remember to drive safe, and drive smart.
scionxb04
02-24-2004, 10:15 PM
George
used to run 10.8 to compression in a b16a2 with jackson racing supercharger and their water injection kit.....a small amount of water is a good thing.....raises compression...cools the cylinder....allows for more timing advancement and more boost......larger amounts of water will raise the internal cylinder pressure to high and will cause problems.....now that im N/A in the civic i use the aem cold air intake witht eh filter right in front of my front right tire behind the hole for the oem foglamps....i pulled out the plastic insert for the oem foglamp and can see the filter right behind it....i have driven my car through some hell storms of rain....no problems...no CEL....nothing..... as for "Any water in the combustion chamber isn't good" thats just not true....the 500cubic inch v8 block we run in the drag boat on alcohol and methanol pushes 1,800hp and uses water injection to allow us the kind of boost levels we run and the timing advances we run.... here is the kit for the civic i ran http://www.jacksonracing.com/Shop/ViewProducts.aspx?PlateIndexID=37417
bBist
02-24-2004, 10:33 PM
Disclaimers are used "in case" something happens. This doesn't mean that it will happen. I've driven in the rain with no problems what so ever. Most intakes for the xB that are for sale are safe to use in the rain.
pmpnxb
02-24-2004, 10:44 PM
now im all sketchy bout my injen short ram... especially since i we are supposed to get 3-4 inches of rain tomarrow... i wanna sell it and get a K&N...
NemoBronsky
02-24-2004, 11:56 PM
your 10.8 compression b16 and your 500ci big block have a "water injection" kit- therefore you are running a modified engine, have a kit installed on the engine and the fact that water will be used has been brought into consideration- In otherwords there is a purpose-proper installation-need whatever you want to say to warrant placing the water there. Noone here is talking about that- were not racing and were not installing water injection kits. WATER IN THE ENGINE IS NOT GOOD when we're talking about an umodified 1.5liter engine with skimpy stock internals- that was never meant to have any water injected into it- with nothing to control the amount of water getting in the engine- blah blah blah. Simply put if your running a cold air setup where your worried about moisture getting into the engine when it rains your concerns are completely valid. Either take it off when it rains or spend the extra money to keep the moisture to a minimum by putting a dry charger over your filter. If you run a cold air setup and you don't have a problem good, and I hope it stays that way, but the fact that your 15 thousand dollar big block uses water injection doesn't mean its cool to let water get into your 15 hundred dollar stock toyota engine through an intake system when your engine was never designed for it. I'm not trying to challenge anything you just said because you make valid points, but it's apples and oranges.
George
02-25-2004, 12:03 AM
George
Really? Consider this:
At 3000RPM, the engine has 6000 intake strokes per minute (1 stroke every two revolutions, four cylinders). Break a liter into 6000 pieces and you get 0.16 cm^3 of water per intake stroke. One cylinder is 375cm^3 in displacement, which at 10:1 means that the combustion chamber volume is 35.5cm^3. 0.16 is .004 or 0.4% of this volume.
You're going to break something by putting an incompressable object in the combustion chamber that accounts for less than 1% of the combustion chamber volume? I think not! Even if the distribution varied so that one cylinder got all the water, it would only take up 1.6 percent of the available volume.
No. One teaspoon is about 5cm^3. This would only be about 14% of the available volume. This would translate to putting 36 liters of water into the engine in a minute!
Water is a natural product of combustion. Ever see the water dripping out of cold exhausts in the morning and the steam condensing from the pipe? You are already passing a considerable amount of water through the systems mentioned. You don't see it after the exhaust warms up because it is emitted as vapor, as will any raindrops taken in through the filter.
In that case, we had better stop driving in the fog. Fog is suspended water droplets and they stay suspended in intake air! Even when it isn't foggy, there is considerable water dissolved in the air. Ever notice how a cold drink gets wet on the outside?
I'm not suggesting that one should intentionally run water through an engine (although it is common in the car and piston engine airplane racing biz), but the idea that a little rain on the filter will cause any preceptable problem is a product of an overactive imagination. Anything that will pass air in the quantities needed for the engine will be hard pressed to exclude entrained rain droplets, including the K&N widget.
NemoBronsky
02-25-2004, 12:06 AM
:lol: nevermind
rattmobbins
02-25-2004, 12:09 AM
OH MY GOD PEOPLE!!! RELAX. Injen's website states that their disclaimer only applies to the cold air intake and cold air extension. The only intake available for the xB is the short ram. You have no reason to be so freakin paranoid!!! Millions and millions of people have intakes on their cars. Millions of people have COLD AIR INTAKES on their cars, and VERY VERY rarely does somebody ruin their engine because water gets in there!
its_ikon
02-25-2004, 12:49 AM
i am not worried about it since most of the water is blocked by the wheel well plastic.
Educatedthug
12-08-2005, 12:16 AM
My wife like to wash are xb alot and we have a after market to grille which lets more air in also lets lots of water in we have the aem with the filter that is suppose to let air threw if water gets into bend but this filter also lets water in car kept stallin took 30 minutes to go 3 blocks got home took filter off full of water...... oopppsss
Educatedthug
12-08-2005, 12:18 AM
cant spell tonight ..... anyway
squirrel
12-08-2005, 05:20 PM
I just took off the INJEN SRI after two + years of service and I never had the engine hydrolock. No too bad for 40k+ miles. I've had it on since it was first released.
Got something a bit nicer now.
Simplyscion
12-08-2005, 11:47 PM
I had the injen on my car for a real long time and never ran into one problem...now if I can only get Fujita F5 to start making me an intake for my supercharger I will be back in business :lalala:
squirrel
12-08-2005, 11:49 PM
:lalala: :lalala: :lalala: :lalala: :lalala: :lalala: :lalala:
whatmovesu
12-09-2005, 12:31 AM
Although the experts have chimed in with very good answers maybe this noob can help. This is my first venture into purchasing a CAI had a SRI on my REX for the very reason. I puchased the AEM CAI because it had the bypass valve. Several people with injen intakes on thier hondas were farting around the parking lot at school and one hit into a puddle . . . nothing happened. . . of course the puddle wasn't deep so he stopped to check it out said it was fine. Of course being nosy I asked to see under there car and the damn intake was exposed yes exposed.
On our xB's we have all that plastic material under car and the intake is inverted up unless you hit a really deep puddle (i.e. pond) you should be fine. So on the AEM CAI I took the bypass valve off and replaced it with a connector from pep boys for $8.00. To this day nothing happened including hitting some potholes filled with water this week :pray:
p2filz
12-13-2005, 04:39 AM
ok im still not reasurred as much as id like to be cold aqir intake still scares me allittle i want the most power out my little engine but i dont wanna crack it ive heard of those dampeners or what ever in the track of sum cai but do they work?. also what i a dry charger i missed the exp of that.. id feel alot more at eas with just a norm short ram im also curious which give best power/ mpg? :relief:
