Nology Hot Wires Installed
I just installed the Nology Hotwires. also installed some Iridium spark plugs. My impression is that with the new plugs and wires car does rev up a bit smoother. The idle does become smoother. I would recomend the wires for sure, and it gives the engine bay a trick look.
Here is a link to my photos of the installed wires. Sorry didnt know how to post the picks.
http://pg.photos.yahoo.com/ph/cee_du...bum?.dir=/4114
From what i understand the Nology wires Have a built in capacitors in the wires which allows time for the small coil packs to charge up and give a stronger spark to increase spark to the plugs. My original spark plugs were the regular NGK plugs. so going with the Iriduims i feel a bit of improvement.
You cant be serious... There are no gains to be had with wires and plugs UNLESS you had a problem with the set you replaced. You are only experiencing the "performance improvement wishing" syndrone.
These engines are designed to meet very tough ULEV requirements. A strong spark is already there .. capacitors in wires ? seems more like marketing than engineering... there is a rise/fall time for caps to function properly... less is more, no wires are best, direct spark which some cars use... having longer wires with caps or whatever seems counter productive..
Originally Posted by hotbox05
mcbain these cars come with ngk plats. but i do agree with most of your post
Hotbox: i just looked at my old plugs and they were the regular ngk "R" v-power spark plugs . Are they really suppossed to come with Platinum plugs. If so why were my Oem only the regular plugs?
yeah i looked at mine and they weren't plats either... maybe another 04-05 changeover?
wasnt this brought up in the past when they were fitted on the xA?
for about 200$ i'm dubious of the gains...
I bought them from WWW.mmrusa.com for $189.95 in the kit is everything you need to install the wires. 4 wires/coil bracket/ nuts and bolts/ extra ground strap/ and insturctions. it is even CARB exempt. big plus for california.
