Bulge in one tire
Old May 12, 2005 | 03:33 PM
dragosca's Avatar
Default Bulge in one tire
Guys, I've got a bulge on the side of my front-left tire and I'd like to know if I can make a point with the service dept. to replace it within warranty. The affected surface is about 2"/1" with the bulge sticking out maybe a quarter of an inch or so.
I am going in for the first oil change tonight and I'm gonna point this out to them. As I see it, it is a defect that the tire developed, I did not hit anything I can remember or anything like that.
What do you think?!
Firestarter
Old May 12, 2005 | 03:37 PM
taek's Avatar
its a bad wheel wear. something must be wrong with how your car was bolted on.
Old May 12, 2005 | 03:42 PM
VIP_tC's Avatar
That usually happens when you hit a pothole or curb, I doubt they will do anything for you since tires are a wear and tear item, but maybe they will step up and help you out. Either way, it is no longer a safe tire and should be replaced.
Old May 12, 2005 | 03:46 PM
dmikon's Avatar
It's probably the Tire Papilloma virus, aka tire warts.
Old May 12, 2005 | 03:52 PM
dgHotLava's Avatar
moved...
Old May 12, 2005 | 06:15 PM
SciFly's Avatar
If you have a quality tire maker warranteeing your tire they'll replace the tire gratis. The tire makers are very aware of tire safety issues. Cheaper for them to replace a dicey tire (it's relatively new?) than to have a lawsuit roll in if the tire were to blow and cause an accident.
(my opinion, not from personal experience)
sidebar:
eighty and more years ago tires were run on dirt roads almost full time. The tires were high pressure, narrow, like cycle tires. The canvas plies were prone to separation. The compound was easily cut. A cut would let sand get into the wound, making a "sand blister", as it was called. Those old tires needed lots of repair work. They lasted 6,000 miles on average if you took really good care. Tires in those days cost the equivalent in today's money, about $200 and up for even cheap, poor tires.
Things were much more costly then than today.
Old May 12, 2005 | 06:24 PM
SCI_TC_GUY's Avatar
If you have the factory bridgestone Potenzas, they might be covered under warranty at a Bridgestone dealer....I know mine have a warranty on them......
Old May 12, 2005 | 06:29 PM
valeriecason's Avatar
DeepSouth Scions
Whew, glad I got the "Tires for Life" thing. You definitely need to not be rolling on that...very dangerous. Good luck at your dealer.
Old May 16, 2005 | 02:11 AM
firesquare's Avatar
GET to the dealer. are you on an alloy wheel? sometimes if you hit a pothole it will bubble. the tire cannot be repaired. it needs to be replaced. most of the time it wontbe covered. good luck!
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
love2accelerate
May 9, 2016 10:19 PM
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
Jan 18, 2016 08:41 PM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
