Tein WAGON dampers
Old May 14, 2005 | 04:07 PM
driftersil80's Avatar
Default Tein WAGON dampers
I was looking into getting some JDM Tein Type WAGON Dampers for my xB. But, on all the application lists, there is nothing for the bB/xB. The closest thing is the Toyota Echo. Will the coilovers for the Echo wit without problem on my Scion??? Please help if you have any clue!!!
Old May 15, 2005 | 04:08 AM
Dewmerz's Avatar
I believe the Tein Wagons from Japan are the same setup as the Tein Basics available here. Check with squirrel on the exact differences as he has the Wagons from Japan on his xB.
Old May 15, 2005 | 07:55 AM
hotbox05's Avatar
The are similar I beliveve the wagens and basics have different spring rates. and yes they will fit.
Old May 17, 2005 | 05:13 AM
BUMP......can anyone comfirm the Echo-xB fitment thing? Will they coils fit and work perectly? Will the ride feel wrong?
Old May 17, 2005 | 03:57 PM
squirrel's Avatar
Man, I wish this was posted up friday before I left. The WAGON coilovers I have, have softer spring rates than the Basics. But, I now have a full set of custom TEIN sporings for my xB so the ride is not as cushy as some know when they rode in my xB.
I was at TEIN yesterday and could have asked them if the Echo fitment would work on the xB.
If there is a difference, it'll be in the shock/strut length and spring rates.
Old May 17, 2005 | 07:03 PM
NISMOZ33's Avatar
if you want a different spring rate you can always get different spring rates for the Basics...
Old May 19, 2005 | 02:57 AM
Ivan's Avatar
what spring rates are you running now?
Old May 19, 2005 | 04:12 PM
squirrel's Avatar
I'm running 5kg in the rear on a shortened spring, and 3.2 kg up front, also on a shortened spring. I can now go an inch lower than what I was at and have a firmer ride in back for better handling since there was no way I was going to find a true rear sway bar.
Old May 26, 2005 | 04:21 AM
jeffsbox's Avatar
Default tein wagon dampers
I have the basics and they are as low as they can go but the rear sits higher than the front how can i get the car level without lifting the front
Old May 26, 2005 | 05:27 AM
hotbox05's Avatar
Custom springs or remove the rear locking perches so you can get that extra .5 - 1 inch.
Old May 26, 2005 | 05:46 AM
jeffsbox's Avatar
i did remove one of the collars that did help but i am still a little off
Old May 26, 2005 | 11:20 AM
hotbox05's Avatar
remove the other collar too?
Old May 28, 2005 | 02:47 AM
squirrel's Avatar
Default Re: tein wagon dampers
I removed the smaller of the two rear collars to get more of a level "sit" when I had the original springs in. I put both collars back on when I got my new springs.
Old May 28, 2005 | 02:58 AM
aireck's Avatar
damn i want some coilovers bad!!
Old May 28, 2005 | 03:46 AM
squirrel's Avatar
Aireck, I can go lower now, but the fenders will sit on the rims and won't be drivable.
Schmohey
Oct 4, 2015 02:53 PM
jnesselroad
Sep 15, 2015 06:57 AM
SouthernCaliTC
Sep 15, 2015 01:58 AM
Itgb
Sep 2, 2015 05:18 AM
