3rd Brake Light - tc
Old May 16, 2005 | 02:09 AM
etli's Avatar
Default 3rd Brake Light - tc
****** Revised 6/30/05****************
Hi everyone.
I've just about finished my modification for the third brake light of the tc; you know, the one where only the center 6" of a 2' length lights up. Without further ado, here are the before and after shots.
BEFORE
AFTER
OK, finally got around to getting pictures of the revised tailights. Here you go.
Bright huh
NOTES;
- Instead of using the normal LED's, I used LED's from LS-diodes.com.
- They have red LED's that put out 14,000 mcd vs. the normal 5000 mcd most LED's put out.
- I used 5 LED's per side for a total of 10 LED's for the light.
- I used a 1/2 Watt 22 ohm resistor instead of the standard 1/4 Watts resistor to keep from burning out the LED's and resistor.
- Credit to Tim (ScionTim aka, EvilScionDude) and ScionJohn for helping me out with the wiring of the lights.
***DANGER, WILL ROBINSON, DANGER********
DO NOT TRY TO REMOVE THE TAIL LIGHT BY COOKING IT IN THE OVEN! It doesn't work because the 3rd tail light uses special glue that has a much higher melting temperature than the plastic the light is made out of. I have accidently warped the original prototype tailight I'd made while cooking it.
Tools / Material Needed
Soldering Iron
Solder
Knife / razor blades
Phillips head screwdriver
10mm socket wrench or equivalent
Drill with drill-bit 5mm in diameter
10 X 14,000 mcd LED's 5mm. I strongly recommend the THC3 LED's from LS-diodes.com
2 X 22 or 33 ohm 1/2 Watt Resistors
Wiring - I would say 24-26 gauge stranded wire is fine. I would also recommend several different colors to avoid confusing yourself.
Clear silicone sealant caulk - the stuff you normally use to seal the grouting in a bathroom.
Tools/ Equipment STRONGLY recommended
Wire Strippers
A big woodworking/ metalworking clamp bolted to a table.
Here's a picture of the back of the light....
I drilled through the back of the light with a simple cordless drill. The plastic is just ABS on the back and is fairly soft.
I made 10 holes in the back of the light, 5mm in diameter.
I put the LED's in the holes that I drilled. I recommend that you place them in the same orientation, with the + side all facing the same way so you don't get confused. I glued them in using Loctite.
I then soldered the appropriate legs to each other in serial. NOTE: I think this would be real easy to screw up if you had the LED's loose in the light because the LED's might rotate. If you feed power through an LED backwards, it will just burn out or the circuit won't work. I can't remember.
I then just spliced in power and ground to the existing wiring that goes to the third brake light. Incidently, Green is POWER and White is GROUND. Although, if you try this on your car, I would say you should check it yourself with a multimeter.
So the whole thing lights up now. If I had to build it a third time, I would drill the holes for the LED's a little higher on the back of the light. Drilling them exactly in the middle kind of mounts them in a funny place. There's still plenty of reflection but I think I could have made it look even brighter.
Ed
Disclaimer: I and Scionlife make no guarentees of the safety, efficacy, workability, practicality, or point of attempting to do this modification. Sueing me will get you nowhere because I have no money. Sueing Scionlife may net you enough for cab fare. Maybe.
Old May 16, 2005 | 02:12 AM
the_butcher's Avatar
THe picture links are not working for me ?
Old May 16, 2005 | 03:35 AM
tekniq's Avatar
host those pictures somewhere else... was only able to download the first one before they returned forbidden.
Old May 16, 2005 | 11:21 AM
SCI_TC_GUY's Avatar
Right on....been waiting for this mod 4 a while...
Old May 16, 2005 | 02:36 PM
garfull's Avatar
need to see the pics.
i was actually going to cut the rear half from the front shell apart and put in a led strip from a spoiler then reweld the two pieces together. but this seems a lot easier
Old May 16, 2005 | 03:20 PM
KINGxOFxSKA's Avatar
Unique Scionikz
cant see pictures..... :/
Old May 16, 2005 | 05:19 PM
etli's Avatar
Ok guys, I moved the pics from imagestation to photobucket. Hopefully, it works better now.
Ed
Old May 16, 2005 | 05:24 PM
crayonBOX's Avatar
that's an awesome write up, kudos, i havent gotten a chance to take the light off my gf's tC, but this is def. the next mod.
Old May 16, 2005 | 05:28 PM
crayonBOX's Avatar
+ id love to see a comparable pic of it when installed; again, great job!
Old Jun 21, 2005 | 02:19 AM
TCAV8R's Avatar
Bump
Any update on the new LEDs and/or the mounting?
Old Jun 23, 2005 | 11:45 PM
etli's Avatar
Oops, yes,
it is DONE!
Not terribly difficult after alll...
I re-did the whole thing using my original tailiight. It looks pretty tight. The bubls are nice and bright, However, I do think that I placed them too low on the light, so all the light doesn't go exactly out the back. But the whole thing lights up now like crazy.
I will post pics when I get some time. I used LED's from LS-diodes.com, the ones called "THC3" which put out 14,000 millicandelas of light (which is about equal to the stock lights on the tc 3rd brake light),
Old Jun 24, 2005 | 12:00 AM
Saleen0296_at_aol_com's Avatar
Default Any new pics?
Looks good from the early pics. Thanks
Old Jun 25, 2005 | 07:35 AM
idriveatC's Avatar
if anyone is interested in doing this mod i got the parts for it. I never got a chance to do it and brought a g35 spoiler with a brake light on it. So i blacked out my rear instead.
Old Jun 26, 2005 | 06:50 PM
Boricua's Avatar
They look kind of dim, tho. Any way of getting them as bright as the stock lights?
Old Jun 27, 2005 | 12:44 AM
DynomyteSW's Avatar
i wanna see the final product installed i think its a good idea i hate how only a small amount lights up!
Old Jul 1, 2005 | 12:12 AM
etli's Avatar
Ok gents,
The new LED's look as bright as the old ones. I have also revised the instructions slightly.
Your results may vary. If you have questions, PM me or just post here.
Ed
Old Jul 6, 2005 | 03:35 AM
WOW looks awesome now i know i wouldnt be lookin all wak when i brake... i need to do this for shizzle!!!
Old Jul 30, 2005 | 02:35 AM
Limey's Avatar
OK I just received 18 THC3's from http://www.lsdiodes.com/THC3/ my plan over this weekend was to basically duplicate this mod but with more LED's on each side - it's an attempt to get a uniform strip across the back rather than individual dots.
Does anyone electrically minded have any input on this many LED's in this setting. Should it affect things at all?
Also, does anyone know if the new wiring is kept away from water, or do I need to look into waterproofing or sealant?
Anything else to addd before i start drilling holes in my 3 week old car.
:D
BTW: I just touched an LED to a 5v square battery (you know the regular clock battery ones) and boy do these throw off a lot of light, I'm planning on taking photo's of the whole install, so maybe have some up tomorrow, or Sunday.
Old Jul 30, 2005 | 02:38 AM
taek's Avatar
isntead of doing that i just got rid of it *shrug*
http://img.photobucket.com/albums/v7...cleantrunk.jpg
i hated that 3rd brake light
but thats godo though very nice
-taek
Old Jul 30, 2005 | 02:40 AM
hotbox05's Avatar
ed stop posting this. don't you want to make money ? lol. ...
