View Full Version : Headlight Film Install (Rockblocker)
Kaeon
05-17-2005, 02:33 AM
Tools Needed:
Razor Blade (Maybe)
Windex
Paper Towel
What you get:
Applier
2 Covers
Free Samples
Other Rock Blocker Material
http://www.scionlife.com/tech/images/headlight_covers_tc/01.jpg
http://www.scionlife.com/tech/images/headlight_covers_tc/02.jpg
First separate your light covers (They should be stuck together)
http://www.scionlife.com/tech/images/headlight_covers_tc/03.jpg
http://www.scionlife.com/tech/images/headlight_covers_tc/04.jpg
Clean and dry your headlight thoroughly with some Windex or glass cleaner. Once you have done this dry fit the cover over the headlight to make sure its the right one.
http://www.scionlife.com/tech/images/headlight_covers_tc/05.jpg
http://www.scionlife.com/tech/images/headlight_covers_tc/06.jpg
Start off at the inner corner peal back about an inch off the inner corner of the cover, and set it on the light. Use your blue applier to apply the corner to the headlight firmly. When you get the corner on put the headlight cover against the headlight to make sure it’s going to line up. You may have to remove the corner and angle the Cover up or down.
http://www.scionlife.com/tech/images/headlight_covers_tc/07.jpg
[img]http://www.scionlife.com/tech/images/headlight_covers_tc/09.jpg
Once you think you have it right, peal back about half inch to an inch of the paper, and once again use the blue applier to apply the film firmly. Your going to peal back an half inch to an inch each time and apply it all the way back to the paper. If you get a bubble pull the film back and re-apply it.
http://www.scionlife.com/tech/images/headlight_covers_tc/10.jpg
Once you have gotten it all set cut any extra off.
http://www.scionlife.com/tech/images/headlight_covers_tc/11.jpg
Once you have finished that go around the corners with a hair dryer pressing down firmly to seal it up. Also the tC headlights have lettering on them so turn on the brights and let the film heat up once it heats up go over the letters with the applier.
Here are the final pictures, I fixed the driver side headlight.
http://www.scionlife.com/tech/images/headlight_covers_tc/12.jpg
http://www.scionlife.com/tech/images/headlight_covers_tc/13.jpg
http://www.scionlife.com/tech/images/headlight_covers_tc/14.jpg
Most of the tools you need to do this come in the package along with some samples of Rock Blocker's other products. Instructions are good very detailed. The film is pretty thick and should hold up well. I choose Blue for mine being Chad informed me smoke will have some effect on the headlights brightness. All and all very good mod for the price great looks great Protection.
RockBlocker
05-17-2005, 02:49 AM
Paul,
That is a very nice write-up on the headlight protection installation for the tC. Thanks so much doing it for members of this site. I am sure anyone can install the product with these instructions.
Chad
purpled_out_tC
05-17-2005, 03:27 AM
Nice write up, wil try.
mikochu
05-17-2005, 03:46 AM
These overlays remind me of the ClearGuard Protective overlays JINSU sells. How thick is the film? I'm guessing they are thicker than the film BlueBatmobile uses, but the ClearGuard ones are pretty thick... Is the material breathable?
Also, is it just me or do the overlays not cover the headlight completely? ...or is that an install error? :P
Pictures in question:
http://www.palmbaynextel.com/misc/100_0965.JPG
http://www.palmbaynextel.com/misc/100_0963.JPG
bloo
05-17-2005, 04:12 AM
I was thinking about applying painted eyelids to my headlights. Should I apply this overlay before adhearing the eyelids? Or would i need to trim the film?
Any suggestions?
Also, I've heard some states don't allow colored lens? Anyone have any problems with this?
Kaeon
05-17-2005, 01:10 PM
Miko,
For some reason I couldn't get the Driver side to line up. The pass side went on 123 and covored most of the light. The driver side still covers up most of it there is about a half inch or smaller edge where the film ends and the headlight continues. In that picture it looks weird because the tC has those chrome Eyelids. Non the less im going to buy another set and try that headlight again.
RockBlocker
05-17-2005, 02:23 PM
For anyone look for our Light Protection please visit our site here
http://www.rockblocker.net/store/35505.htm
PS. We choose not to call them overlays since the film is not just tint, but actual light protection. I noticed the driver side being a little short, But as Kaeon said he ran into a little of trouble for the drivers head.
If we cen help with anything else please feel free to let us know.
Other color pics are available here
http://www.rockblocker.net/scionlight.htm
Chad
sciongirl81
06-09-2005, 12:04 AM
here are pics of mine "installed." :clap: :clap: :clap:
http://i4.photobucket.com/albums/y144/sciongirl81/firstpicsevo169.jpg
http://i4.photobucket.com/albums/y144/sciongirl81/firstpicsevo172.jpg
http://i4.photobucket.com/albums/y144/sciongirl81/firstpicsevo171.jpg
http://i4.photobucket.com/album//y144/sciongirl81/firstpicsevo170.jpg
RockBlocker
06-09-2005, 12:49 AM
Nice job :) :clap:
its_ikon
06-09-2005, 03:22 AM
is it ok to use water with some soap when applying this as normal vinyl or does the thickness effect that?
RockBlocker
06-09-2005, 04:05 AM
We recommend water and alcohol, but you can use soap and water if you want too.
purpled_out_tC
06-11-2005, 01:42 AM
You can't post photos from your computer you must host them first
Try this link for some help http://www.scionlife.com/forums/viewtopic.php?t=60323
There's mine. I used alcohol to clean the lights. I'll take better pics at a later date. The install took me about 45 min. Very easy and highly recommended.
I know the mask is not favored, but in this world of SUVs, Trucks (especially the ones with big tires and no flaps) and Big Rigs everywhere it's staying.
Oh and yeah, yeah I know I should of used a tripod. Don't have one, but I'll get one at some point in my life. Thank you though.
~ Edited: By Kaeon
purpled_out_tC
06-11-2005, 01:59 AM
http://photobucket.com/albums/v690/freedomsoul/?action=view&current=a031d53b.jpg
http://photobucket.com/albums/v690/freedomsoul/?action=view&current=b719369c.jpg
purpled_out_tC
06-11-2005, 02:01 AM
okay so my pics aren't posting, and it won't let me edit. But the links for photo bucket work.
RockBlocker
06-11-2005, 02:30 PM
Thats all good. Thanks for the pics. We will be posting pics of our new car soon.
goingcarcrazy
06-11-2005, 06:21 PM
I went on to rockblockers site the other day and was snooping around and I came across a disclaimer. I'm sure that its just a mandatory requirement but it said to check with your local law enforcement to make sure they're legal in your area/state. now I'm wondering, anyone in Florida have the blue tinted ones and if so, have you had any problems with the cops?
RockBlocker
06-11-2005, 06:25 PM
That is correct please check with your local law enforcement laws for your state if you are unsure whether or not you can have these on your cars.
BTW, I wouldnt call that "snooping" I would call that doing your honework. We have not had or heard of any complaints in the two years that we have been carrying this product. We even have blue on our cars. People are right you can see better at night with them.
Kaeon
06-11-2005, 06:46 PM
I live in FLA no problems yet and I have those little blue daytime lights in my headlights so during the day they are really blue. Im sure if your just driving normal and not causing any attention to yourself you will be fine. Of course if your hauling butt racing and the cops pull you over im sure they will say something about it.
its_ikon
06-18-2005, 04:33 PM
when you mis the water and alcohol, what should the mixture be?
RockBlocker
06-18-2005, 08:09 PM
50-50
sciongirl81
06-19-2005, 10:07 PM
Bump for RockBlocker.net!! :clap:
...on another note, Tova is now rocking her new decals!
http://i4.photobucket.com/albums/y144/sciongirl81/firstpicsevo214.jpg
RockBlocker
06-19-2005, 10:27 PM
Thanks Tova!!! I heard you have been a busy bee on ScionGirls
sciongirl81
06-19-2005, 10:32 PM
I'm all over the place!! :clap: Counting down the days till I get the coil overs on. :clap:
Tomas
06-20-2005, 03:11 AM
Chad, I have questions about the light protection kits available for the xB (since I want breakage protection, not color).
(1) How thick is the 'film?'
(2) What does the "Light Protection Kit for Scion xB, Head Light Protection Kit and turn Signal Kit" cover that the "Light Protection Film for 2004 - 2005 Scion xB - Headlight Kit" doesn't, since it is all one plastic lens?
(3) Is it urethane or vinyl?
Thanks!
RockBlocker
06-20-2005, 02:20 PM
It is 20 mil,
The headlight kit is just that. Then there is a headlight and fog light kit.
High impact resistant vinyl. Urethane only goes to 14 mil.
epitek
07-20-2005, 01:00 PM
kinda side tracking here.. but i know that this is for damage against rocks.
any chance this will help gets bug guts off my lights as well? easier? is it safe? how do you clean these?
RockBlocker
07-20-2005, 03:36 PM
it could depends how often you wash your ride. You wash wand wax them like the rest of the car.
purpled_out_tC
07-24-2005, 05:16 PM
yes it protects against bugs as well, if you wash your car regularly (i wash mine weekly) then yes it's also easier to clean your headlights. as far as safety they're completely safe but note that your light output with the stock light bulbs is cut alot if you get the smoke. i'm put luminics in this week so i'll be posting up comparsion of the smoke in different light output.
