Sid_xBicious
02-27-2004, 12:17 AM
how do i take off the ends? not the whole grille but just the sides that don't have holes.
thanks,
sid
thanks,
sid
View Full Version : xB lower bumper grille Sid_xBicious 02-27-2004, 12:17 AM how do i take off the ends? not the whole grille but just the sides that don't have holes. thanks, sid toybox1 02-27-2004, 12:05 PM i know for sure that the driver side comes off .... the screw for the tow hook is there ... just pull Sid_xBicious 02-27-2004, 04:14 PM yeah, i look under, and i even see a thin black plastic(like tag holder) that i think is suppose to hold it in case it was remove. but i don't want to apply too much force pulling it(might break something) thats why i'm asking here if there is a special way to remove it. thanks, sid DjFrOsT 02-27-2004, 04:21 PM how do i take off the ends? not the whole grille but just the sides that don't have holes. thanks, sid you can take both off...just apply enough pressure from the back...and they pop right off...or you could take off the bumper...and push those pieces off... hope that helps... Sid_xBicious 02-27-2004, 04:24 PM yes i got it off. thanks!, too bad theres not enough depth to put a plush mount foglights. my idea down the drain :cry: sid o4_USDM_bB 02-27-2004, 05:17 PM i just top-mounted mine in that same opening, just inside of those covers. Sid_xBicious 02-27-2004, 05:26 PM i just top-mounted mine in that same opening, just inside of those covers. do you have any pics, did you screwed it on the bumper? what kind of foglight did you use? i was kinda thinking of installing a rectangular 5x3(close to) but will have problem on the depth, so i might go different route. thanks, sid o4_USDM_bB 02-27-2004, 06:16 PM yeah, i just drilled into the top of that bottom opening.... i think that's where the real bumper is, because it seemed like it was hitting something hard when i drilled in. i used really shallow screws tho, so it was ok. i used cheap autozone foglights with an amber coat, that don't really light the road up at all, but i like the look anyway. mine do bump out a little bit, but i don't mind. if you want it flush, its really small in there, so it might be kind of hard. |
