anyone try this yet?
Old May 20, 2005 | 03:29 AM
yellot00tr's Avatar
Default anyone try this yet?
i have the bottom grill from when they put in the fog lights. has anyone tried to use that as the top grill?
Old May 20, 2005 | 04:01 PM
Undecided_Fate's Avatar
a little off topic but i dont like the way the scion fog lights look on the tc. to each their own of course but i would have liked to see the lights on the side holes of the front bumper.... much like the 6gen civic fog lights.
Old May 20, 2005 | 04:08 PM
SCI_TC_GUY's Avatar
I have a lower grill as well and am going to be fabricating it to fit the upper grill possibly this weekend.....I"ll probably make a tutorial on it in the process.....I was going to do it about a month ago...but I've been super busy with work and other projects.....
Old May 20, 2005 | 04:39 PM
DTRUONG_112's Avatar
just post pics when u do
Old May 20, 2005 | 05:56 PM
TCRS1_0's Avatar
I agree with the suggestion about putting the fog lights in the lower openings under the headlights in the TC . Fogs just dont look right in the lower center grill
Old May 20, 2005 | 11:28 PM
5h3rW1N4051's Avatar
ok thats kool
Old May 20, 2005 | 11:52 PM
yellot00tr's Avatar
i was going to get an company online to make me a grill for the tc. i just don't have the dimensions of the stock upper grill. anyone know by any chance what it is? if not, i guess i gotta go take it out and measure it this weekend.
Old May 22, 2005 | 04:20 AM
spectre1138's Avatar
I was looking at getting a bottom grille to cut down for a top grille replacement too. It may end up looking a little odd however.
The upper grille is installed in a slanted back position. The cut of the "walls" in the grille pattern is slanted down. The end result is that these "walls" are horizontal in respect to the ground.
The lower grille is more or less installed vertically. The cut of the "walls" in that grille pattern is perpendicular to the grille so that they too are horizontal in respect to the ground.
If you install the bottom grille in the top position, it will be slanted back which means the "walls" will be slanted up instead of horizontal. It may not be enough to be immediately obvious, but I suspect it will be one of those things that you look at as "something's just not right there but I'm not sure what".
Old May 22, 2005 | 05:50 AM
EnderSavesTheDay's Avatar
yes it's been done. It's floating somewhere around here... I don't think in the drag coefficient section... did a pretty good job, a little crooked but ::shrug:: Go for it, I'd like to see more of this done =D
Old Jun 14, 2005 | 08:40 PM
05silvertC-'s Avatar
The position the scion has for the fog lights is horrible I was originally going to get hte fogs but then I saw a pic and absolutley hated it..I was assuming that it was going to be in the same position as th EK civic..I wonder if they will make some that go in the side vents in the future?
Old Jun 21, 2005 | 09:22 PM
rhythmnsmoke's Avatar
Music City Scions
The lighting and the camera flash drowns out the black mesh grill, but it looks 10 times better in person.
