**How Do I Remove Rear seats**
Old Feb 27, 2004 | 10:53 PM
Vegasscion's Avatar
Default **How Do I Remove Rear seats**
Im trying to take out my back seats and only see the 3 bolts in the back of them whats my next step?? Someone please help i cant figure it out
Mark
Old Feb 27, 2004 | 11:38 PM
usdmbB's Avatar
Alrighty first pop up front of rear seat bottom. Next place hand thru seat nest to middle seatbels on pass. side there is a metal hoop coming out of seat bottom, which
goes over a small metal tap on seat bar. Once this is removed you will find the rest of the bolts under the seat. you can also remove cover on back of seats which will expose 10mm bolts on seat backs remove these aswell, then you can remove bar tha seat att. to hope this help.
Old Feb 28, 2004 | 12:11 AM
Vegasscion's Avatar
Thanks for the quick response ill go try that
Mark
Old Feb 28, 2004 | 12:32 AM
WeirdStyles_net's Avatar
that little loop in the dead middle of the seat is a biatch to get undone.
............X...........
.____________.
|_____||_____|
.......x...........x....
First, where the two small x's are, lift up really fooking hard. The clips under the seat should release with a satisfying "snap".
Next, if you attempt to pull the seat out, you will notice its still stuck. Where the big X is, where the top and bottom the the seat meet; there is a metal "hook" that the seat attaches too. Push the seat in while coaxing that hoop upwards.
Youll understand when you get there....
Old Mar 22, 2004 | 01:17 PM
Carolina_Guy's Avatar
Default Reattaching
I wasn't trying to remove the rear seats, just messing around, and popped off the drivers side front metal clip securing the seat bottom to the floor. It's a U-shaped metal loop. When I push back down to try to reconnect the seat bottom, it doesn't seem to catch. Anyone have experience with this? Thanks.
Old Mar 24, 2004 | 01:36 AM
ScionRI's Avatar
sIcKsCiOnS
uh oh
you screwed
HotLavaDestiny
Feb 8, 2015 05:25 AM
kleecker
Jan 9, 2015 02:26 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
BlueBox
Mar 14, 2008 08:54 AM
vpkb
Sep 30, 2003 07:48 AM
