Front Tires Rubbing Question
Old May 23, 2005 | 03:35 PM
Guest
Guest
Posts: n/a
Default Front Tires Rubbing Question
I have an 05 Xb with 225x45x17 the front wheels rub when I turn...can I put spacers on..... what size? any other solutions asside from chopping up the box....lol
Thanks
George
Old May 23, 2005 | 04:10 PM
DJ_X_Trodinaire's Avatar
spacer will just push your wheel alot closer to the fender,
more rubbing
where exactly is it rubbing?
if it just rubbing on the rubber shroud you can take that off or trim it.
take pics if you can
Old May 23, 2005 | 04:19 PM
Guest
Guest
Posts: n/a
it seems to be rubbing on the inner part of the wheel well
Old May 24, 2005 | 01:19 AM
Blue_Ra's Avatar
Default Re: Front Tires Rubbing Question
Originally Posted by gmilonas76
I have an 05 Xb with 225x45x17 the front wheels rub when I turn...can I put spacers on..... what size? any other solutions asside from chopping up the box....lol Thanks George
You don't tell us what the wheel width and offset is. It is the Combined wheel and tire that you must consider.
IF the wheel is a 17x7 or 17x7.5 with an ET of 37 to 42 then you shoud have no problems with a 215/40/17 - the 225/40/17 will add only .2" to the Inboard and Outboard and you can probably do some selective cutting to fix that.
IF the wheels are 17X8 and/or an ET outside the 37 to 42 then your probably looking at an increase of over .5" (over the 17x7 fitment) on the Inboard or Outboard.
scionlife
371
Jun 2, 2015 11:00 PM
meowtc
Mar 5, 2015 02:28 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
toyotaisme
Jan 10, 2015 10:24 PM
fur_pig
Dec 5, 2014 12:48 PM
