Question On AIR FUEL gauge
Old May 25, 2005 | 11:18 PM
05Toaster's Avatar
Default Question On AIR FUEL gauge
im puttin an air/fuel gauge in my dash i need to know what wire it is?? anybody?
Old May 26, 2005 | 02:52 AM
italianrelic's Avatar
splice it into your o2 sensor best bet is to peel back a lil wire solder it on and tape it up dont actually cut your wire i did that to my old car and always worked fine! unless anyone else has better but i think no?!?
Old May 26, 2005 | 07:19 AM
SuperCrunchyAction's Avatar
You should really have a bung welded and installl a wide band 02 sensor to take full advantage. Why you want to do this on a stock car is anyone's guess.
Old May 26, 2005 | 07:56 AM
BlueSix's Avatar
Why are you running an AFR gauge?
Just curious.
Old May 26, 2005 | 10:40 AM
Romanova's Avatar
Af gauges are stupid. You wasted your money. Sure, it is pretty eye-candy that chicks love, but it has no value, especially in a xB. If you had data logging software and could actually view your fuel trims, then maybe it would help.
Old May 26, 2005 | 11:12 AM
Thiat302's Avatar
Give him a break- he didnt ask for you to flame him for crying out loud- he asked if anyone knew which wire to splice into-
You think they are stupid, so dont buy one- He on the other hand doesnt think its stupid, so he bought one-
To each his own, no need to be a jerk-
I would go with a wide band o2 sensor-
Old May 26, 2005 | 02:16 PM
grizzly_choppers's Avatar
From a warranty standpoint, you'd get yourself in less trouble (and be less likely to throw a CEL) if you went the welded bung/new sensor route. I'm always very cautious of the "splice".
-Alex
Old May 26, 2005 | 02:37 PM
05Toaster's Avatar
All i ____ing asked was a simple question i dont need to explain to anybody why or what i have it for.
Old May 26, 2005 | 10:01 PM
Romanova's Avatar
Calm down Skip. You want easy? Find the O2 signal wire that goes into your ECU. Use a vampire tap to tap into the wire. Piece of cake. Other wires go to ground and switched 12V. Piece of cake.
And of course you already know that the computer controls how lean or rich the car runs, and the only way you could alter the settings would be if you were running an AFC, in which case, you would need some sort of datalogger to see how your changes were affecting the fuel trims. Just makin' sure...
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
nightfox915
Apr 17, 2015 07:06 PM
TheRedBox
15
Jul 9, 2006 04:08 PM
mattjk
121
Dec 22, 2004 10:49 AM
