View Full Version : How to fit Eu-700 or any 3.5-4" deep speaker in your tC
mandos 05-26-2005, 03:29 PM First of all, need to make some bigger baffles. Mounting depth on the Eu-700 is 3 5/8". Not nearly enough room with the normal 3/4" baffle.
Just traced the outline of the stock speaker on some wood and cut them out:
http://www.icixsound.com/vb/icixnation/images/83_165.jpg
Then, make a circle as big as the woofer(7") with a hole for the speaker cut out and mount it on the baffle:
http://www.icixsound.com/vb/icixnation/images/83_166.jpg
Now, just put the Eu-700 in the hole and attach it to do door:
http://www.icixsound.com/vb/icixnation/images/83_159.jpg
And yes...it fits with the window rolled down:
Driver:
http://www.icixsound.com/vb/icixnation/images/83_158.jpg
Passenger:
http://www.icixsound.com/vb/icixnation/images/83_161.jpg
Now, before putting the door panel on, mod time. Picked up a dremel with the flex-shaft for this, very nice to have around.
Here's a pic of the nicely deadened panel, thanks Jeremy.
http://www.icixsound.com/vb/icixnation/images/83_162.jpg
Before cutting:
http://www.icixsound.com/vb/icixnation/images/83_163.jpg
Notice that big circle that I guess channels the sound from the stock speaker? Bu-bye:
http://www.icixsound.com/vb/icixnation/images/83_164.jpg
And now what you've all been waiting for, PROOF!!
Driver side:
http://www.icixsound.com/vb/icixnation/images/83_157.jpg
Passenger:
http://www.icixsound.com/vb/icixnation/images/83_160.jpg
Pretty simple :)
Forgive the bit of eDead in that last pic, ended up splattering on the grill, haven't removed it yet :(
Any questions/comments, let me hear it :)
Boricua 05-26-2005, 05:16 PM I don't mean to sound ignorant, but what is eDead? Is that the silver tape-looking thing?
What else can you use for the Baffel? I know wood is what you used but I don't have tools to cut wood. Also, did you cut the wires or use a harness? I don't know of anyone that sells them but I might be wrong.
Do you have the stock HU?
failed_ethics 05-26-2005, 05:53 PM eDead is sound deadening, yes, that silver tape looking stuff. There really isn't much else to use as a baffle, you can rent the necessary tools, but they're pretty cheap to buy. And as far as cutting the wires or using a harness, neither. You wouldn't be running this speaker from any HU let alone the stock HU.
SCI_TC_GUY 05-26-2005, 06:09 PM the eDead mandos is speaking of isn't the mat....he's talking about the liquid that's splattered on the grill.....he has both I believe though.....
I"ll bet those sound pretty dang good......
mandos 05-26-2005, 07:01 PM Silver eDead = mat
Grey on back of panel = liquid :)
and no sound yet
SCI_TC_GUY 05-26-2005, 08:05 PM WHY NOT??!?!?!??!?!!!?
you'll have to let us know when you get them going!!
mandos 05-26-2005, 08:57 PM WHY NOT??!?!?!??!?!!!?
Main reason = that one was a prototype we slaughtered...500 watts in a low tuned ported box is not to that little guys liking :)
We have another one here that I'm going to wire up later today. Probably sound like utter crap because it's a sub/midbass paired with a tweeter and no midrange...but I'll try anyway.
Need to figure out how to make stock looking kicks now though :)
cadaver 05-26-2005, 09:24 PM please make this an faq
ndnbolla 05-31-2005, 05:12 AM hey mandos would you need to mod it the same way to fit an eu-600?
and what are you running those 700's off of... a nine.2?
HyperZ 05-31-2005, 05:58 AM I guess a set of those on the doors, with enough sound deadening (or another speaker the can run free air) with a set of 6.5s and tweeters in a kick panel would be pretty sweet. I could run my 12" at a 38Hz or something and all the kicks would be put out through the 7"ers.
mandos 05-31-2005, 02:07 PM HyperZ...exactly what I'm going to try and do...need to seal it just because those huge holes in the door would screw up the sound pretty good.
ndnbolla, for the 600's you'd only need the one baffle, no need to make the extra spacing circle :)
ndnbolla 05-31-2005, 03:39 PM would that part of the grill still need to be trimmed?
mandos 05-31-2005, 03:43 PM would that part of the grill still need to be trimmed?
Nope, it only becomes an issue with the extra 3/4". With a normal sized 6.5" it's fine :)
ndnbolla 05-31-2005, 04:06 PM so all you would need for 600's is that one 3/4" baffle for each?
mandos 05-31-2005, 04:15 PM so all you would need for 600's is that one 3/4" baffle for each?
That is correct. If you take a look at this picture:
That's a 6500 mid attached to a single baffle...and was in my car for 3 months.
TheBigGuyRy 06-01-2005, 02:44 AM So those are 6.5 subwoofers?
Just curious, Chris, but is there a reason a normal person would put little subs in their doors? Where are you gonna get the rest of your sound range from?
And here I thought I wasn't a car audio noob anymore :doh:
ndnbolla 06-01-2005, 02:51 AM those mids take care of the midrange, he probably has aftermarket tweeters that take care of the higher ranges and he might have a sub(s) that take care of the lows.
mandos 06-01-2005, 04:27 AM So those are 6.5 subwoofers?
Well...plan is to get those in the doors and fabricate some kind of kicks for either some CDT 4"ers with the eDi tweeters or my co-workers Iridium 3"s with the eDi tweets.
Probably end up with the 4" CDT's just because they'd extend lower better.
Reason to have the subs in the doors would be to have my sub stage in the back set as low as possible :)
ndnbolla 06-02-2005, 05:23 PM Mandos, this is going a bit off topic but could you use the the eD 15% combo discount in conjuction with the eD 15% scionlife discount?
mandos 06-02-2005, 05:26 PM Mandos, this is going a bit off topic but could you use the the eD 15% combo discount in conjuction with the eD 15% scionlife discount?
nope...the 20% discount is eDead only....so it's actually better just to buy eDead outside of the package to get the larger discount on it :)
acex008 06-03-2005, 01:31 PM I CANT WAIT TO GET MY HANDS ON THOSE MIDSUBS!!!!!!!!!! Mandos? Did I just make up a new term? lol I think we may be in luck putting 3.5" speakers with tweets down in our factory kicks... I looked at it this morning. I'm going to pry into it tonight and maybe even start cutting!!! :-D
Snowsk5054 07-11-2006, 08:49 PM Question.....If I put these into my doors, can I not amp them and have the factory head unit pound on them?
Just a question =)
SCI_TC_GUY 07-12-2006, 12:07 PM ^^ is it possible, yes, anything is possible.
will it work well? not at all... these guys need some juice to them... I don't think the 12-20 watts that the stock HU pushes out will do them ANY justice... it's pretty much required that you put an external amp on them..
mandos 07-12-2006, 02:37 PM Plus, if they're in your doors, you NEED something in kicks. They don't do midrange.
Snowsk5054 07-12-2006, 02:47 PM Gotcha
HyperZ 07-13-2006, 04:01 AM Funny this thread sprung to life after so long, but I wonder if I can get an answer to a question here seeing as how my issue relates to something like this... where I want to install the eu700s in my doors. My question though... how do you remove the grommets attaching the front speakers on the door?
HyperZ 07-13-2006, 04:05 AM Nevermind... search tool works pretty well. FYI - no other way than to drill those biatches out with a 1/8" drill bit, according to mister mandos.
mandos 07-13-2006, 03:32 PM Nevermind... search tool works pretty well. FYI - no other way than to drill those biatches out with a 1/8" drill bit, according to mister mandos.
A vice grip + lotsa bad words work too...but the bit = fastest.
Keeshwah 08-22-2006, 02:09 PM Hopefully, Mandos you can reply to this, but what CDT 4" would you recommend with the eD tweets and eu-700s? Would the CDT Classics sound quality be good enough or would something more expensive be a better match? And how would you do the wiring? Would you need another crossover to seperate the three speakers?
SCI_TC_GUY 08-22-2006, 02:59 PM ^^ about the wiring, I'd get a 4 channel amp that's around 100 watts x4 and wire the mids and tweets to the xover and to front 1 and 2 and then have the 700's ran to the "rear" 3 and 4 and lpf'd around 200Hz. If you use Ysplitters on your RCA's, the 700's and assembled components will all get front channel music.
If the 700's are going into your door, I'd highly recommend sealing that biatch up!! lots of edeadv3 liquid and some mat too..
edit: I'd personally go with the High Definition 4" from CDT if that's the route you choose...
mandos 08-24-2006, 03:33 PM HD's I agree.
davedavetC 08-25-2006, 06:12 AM are the eu-700 subs or speakers? i thought they were subs. :question:
SCI_TC_GUY 08-25-2006, 11:22 AM they're a mid-bass technically.... can me used for low mids (under 250-300Hz) or for sub bass (anything down to like 20Hz or something)
mandos 08-25-2006, 02:08 PM Sub that works well as a midbass up to 500ish Hz.
