Mini Cooper wheels
Old May 27, 2005 | 01:42 PM
Son_of_Microbus's Avatar
Default Mini Cooper wheels
The poll and graphics from Tomas has me thinking of the Mini Cooper wheels for my xB. I like the look. Does anyone know if those wheels will actually work on the xB? With the OEM tires (Goodyear Eagles)?
Old May 27, 2005 | 01:44 PM
dgHotLava's Avatar
moved...
Old May 27, 2005 | 01:48 PM
Sciond's Avatar
yes someone on here has them............he got them as a gift if I recall
Old May 27, 2005 | 03:33 PM
JDMJim's Avatar
Mini wheels will work. You need mad spacers as the wheel use a 48 offset! Seen it done on a Vitz, bB and a few Nissan Cubes. The look is kinda tight.
Old May 27, 2005 | 03:37 PM
Tomas's Avatar
Admin Emeritus
Mini Cooper standard wheels:
Style R81 (7-hole) 5.5Jx15 = 5.45Kg (That's 12 pounds!) Offset = 45mm
Scion is 'hubcentric' with a 54.06 (54.1) diameter hub.
Mini Cooper is 56.1...
Old May 27, 2005 | 04:12 PM
Boxer_Rebellion's Avatar
^^^ Those ones are the only ones I'd consider. The "superlite" ones are way heavy @ 26lbs.
Old May 27, 2005 | 04:34 PM
Blue_Ra's Avatar
I have a MINI Cooper that has aftermarket wheels that are drilled with stock centerbore 56.1mm. I want to keep the wheels for an xb and have found out that there is NO hub Centric adaptor that will go from a 56.1 to 54.1. The wheels that I have may, I am still verifying this, allow reboring to 60mm and I can then use a 60 to 54.1 adaptor. I do not know if the OEM MINI wheels will allow for reboring but that will be what it takes to get a correct hub centric mounting. Without them there will most probably be wheel vibration with associated damage.
I will follow up on this when I know more and when/if I go through with the xb purchase it will be an '06.
Old May 27, 2005 | 05:03 PM
ugly_duck's Avatar
you will need hub spacer to clear the rears. but yes they will fit, some have them here
Old May 28, 2005 | 10:54 PM
sensez's Avatar
i like those wheels. =]
sen-
Old May 29, 2005 | 12:33 AM
Default wheels
Thanks to everyone for the input/info. I've got a few mods ahead of wheels, so I have some time to think about it. Also, sounds like I've got some learnin' to do about wheels an such. Not just a simple swap.
Old Oct 28, 2005 | 06:56 PM
BabelBox's Avatar
So will those Mini Cooper wheels fit to the xB? Does it need to be modified to fit? rebore? adapters? spacers?
I like those Style R81 (7 hole). It's the closest thing I've seen to the OEM bB hubcaps.
Thanks.
ScionLife Editor
Feb 25, 2015 04:40 PM
nastytc
Scion tC 2G Aero & Exterior
Jan 27, 2015 03:50 PM
kahsperr
Regional - Pacific South
Jan 3, 2015 05:09 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
Torokun
21
Sep 25, 2003 03:02 PM
