where do i place the jack, front and rear to lower car??????
Old May 28, 2005 | 09:38 AM
italianrelic's Avatar
Default where do i place the jack, front and rear to lower car??????
i had mine done by toyota when my springs came in so me and my friend are going to lower his xb. ive lowered many cars before but the xb is weird and i dont want to mess anything up any help i would appreciate
Old May 28, 2005 | 09:41 AM
xBino's Avatar
i'd like to know as well...
pics of jack stands and where they go would be swell
Old May 28, 2005 | 12:30 PM
Anyone man all u people on this site dropped ur xb's and no one knows where to put the jack to jack it up front and rear?
Old May 28, 2005 | 12:36 PM
Travst's Avatar
About 10" back from the front wheel, you'll feel a couple of notches... that's your jack point. If you don't have a rubber pad for your floor jack, invest in one to save scratching. The rear is notched the same way. The notches are on the ridge of metal just inside the side skirting.
Did you guys get owner's manuals with your cars?
Old May 28, 2005 | 03:48 PM
yo i have a jack that slides under the car and u pump it up i want to know where u place it to jack it up so both front or rear wheels go up so we can do suspension!!
Old May 28, 2005 | 04:03 PM
Romanova's Avatar
Wow, that sounds like an awesome floor jack. It actually goes UNDER the car? Damn.
You probably want to do the fronts seperate from the rears. The way the rears work, you're going to have to jack it up really high if you want to do one side of the vehicle at a time... and then the wind would hit it and it would roll over. Do the fronts, then the rears.
Old May 28, 2005 | 04:08 PM
FrankenScion's Avatar
Old May 28, 2005 | 05:31 PM
SciFly's Avatar
great tip. thanks!
Old May 28, 2005 | 08:36 PM
Romanova's Avatar
Romanova Posted: Sat May 28, 2005 9:03 am Post subject:
italianrelic wrote:
Calm down friend! Lets handle this Christian-like. Yeah, it was a joke, because seriously, if you don't know where to jack up your car or place your jackstands, then you probably should let someone else work on your car. But I also applaud people who make the effort to do their own work. The money you save on labor helps buy tools so you can do more work on your car. The first thing I would do if I were you would be to read the AWESOME tech writeup on this site about how to do a spring install. It has plenty of pics and some great tips. You failed to mention if you had looked at it already and were looking for supplemental tips. When doing your buddies car, you just need simple hand tools, beer, and about an hour. You don't need a spring compressor, just have your buddy push down on the spring while you tighten the strut nut. Take everything apart slowly so you can see where it goes. Don't forget to trim that bumpstop a bit and install the anti-rattle stuff on the rears if it is supplied (you failed to mention what springs you're going to be using). The rears seriously only take like 10 minutes. The fronts are about 20 a piece. Just take your time and be patient. Use cardboard or something on the jack to protect the underside, and look just past the bodykit on the underside as to where the jack goes. Be gentle!
Old May 28, 2005 | 10:06 PM
Sorry then! u know didnt know?!? but i have a one ton floor jack thats why im askin im not jacking the car up on the sides i am jacking it up from the undercarriage in front so i can do both fronts at same time not side when i do one rear and one front. i dont know when to place the jack front and rear i dont really see any good points u understand now?!?
Old May 29, 2005 | 01:14 AM
firesquare's Avatar
Well said. Long live the TECH section and Beer!!!!!
Old May 29, 2005 | 02:06 AM
Travst's Avatar
There aren't any. The Scion doesn't have a crossmember or any sort of frame in the front to get the jack under. In the rear, you have the torsion beam, but I doubt it's a good idea to use it as a jack point. If you want to work on all four wheels, jack up on side, put in your stands, and then repeat for the other side. Please don't attempt to place your jack under the oil pan or any other engine components.
Old May 29, 2005 | 02:16 AM
twiztidninja's Avatar
I believe I seen something in the owners man on how to jack up the whole front and the whole rear. I will look again and and post.
Old May 29, 2005 | 02:56 AM
on page 192 of the owners man it shows a diagram of jack positions. make sure you will be able to get the jack out after it's lowered.
Old May 29, 2005 | 04:18 AM
Sublimize23's Avatar
you've "lowered many cars before" yet you don't know how to jack up a car? Please, take it to the dealer.
Old May 29, 2005 | 08:17 AM
crayonBOX's Avatar
i agree w/the owners manual tip. i jack up a side at a time and add jack stands. thats IMO the best way, and usu. teh safest (if done right) the scion does pretty much, not have a way to jack up the front. the rear however has that lil "tail" under the spare area. serves well to get two jack stands in at the same time
scionlife
371
Jun 2, 2015 11:00 PM
minter66
Dec 15, 2014 01:45 PM
linlow
Scion tC 1G ICE & Interior
Dec 14, 2014 12:56 AM
2010tc805
Scion tC 1G Wheel & Tire
Dec 12, 2014 06:47 PM
smilygo
Oct 5, 2003 09:51 AM
