GREAT IDEA for Stock Steelie PEOPLE!!!
Old May 29, 2005 | 04:37 PM
saicow's Avatar
Default GREAT IDEA for Stock Steelie PEOPLE!!!
I desperately need the following measurements for making custom chrome center caps for my stock steelies (with chrome rings and chrome bolts already)....I like the simple "old school" look......and saving money and softer ride with stock set up......
a) the diameter of the center hole opening of the wheel
b) the distance of the top of the protruding axle from the surface of the wheel
c) the distance (through the center of the wheel) between the center of two opposite facing bolts
I will make in effect a "top hat" type of cap that goes behind the wheel (and fits over the bolts before placing the wheel on) and sticks out through the center after mounting the wheel- hiding the ugle axle.....
Planning on making a few sets if anyone is interested....with a simple 3 ring bulle eye design on the top (acid etched into the chrome plated brass sheet metal that the caps are to be made in and then th rings are painted with black enamel - clean)
SO....please please get me those measurements immediately...GREATLY appreciate it.....Bradford
Old May 29, 2005 | 07:13 PM
dollar5's Avatar
let me check some pics... i might be interested, as far as the measurements i can t help you... but i would like an answer to my steelies...
Old May 29, 2005 | 08:38 PM
sensez's Avatar
dont know the measurements but i know im interested.
good luck
sen-
Old May 29, 2005 | 10:46 PM
SciFly's Avatar
Great idea. Is a market for this. I think that steel is likely your better bet than brass, for technical reasons only.
Old May 29, 2005 | 11:02 PM
Sciond's Avatar
i'd be interested..........
Old May 29, 2005 | 11:05 PM
jct's Avatar
jct
i wouldn't mind if they were chromed centercaps or polished
but first gonna needs pics of your idea (ala drawings)
Old May 29, 2005 | 11:45 PM
Tomas's Avatar
Admin Emeritus
I see a problem...
With older wheel/hub designs this was a fairly common application. The Scion's, however, are "hubcentric" designs as opposed to, for example, the Land Cruisers which are "lugcentric."
This means that while the Land Cruiser (I choose them 'cause I've had a few) allows that quite easily, a properly fitted Scion wheel (like the stock steelies) fits the center hub very closely and will not allow anything else placed around the hub projection through the hole.
The hub is 54.06 mm outside diameter, and the centerhole in the wheel is allegedly 54.10 mm diameter. That's a two-hundredths clearance all the way around...could be less with standard tolerances...
Something to fit a Scion's stock wheels would have to fit the front of the wheel and not go through its center hole. Perhaps a tophat designed to fit in front of the wheel and held on by the 4 x 100 spaced lug nuts could be designed, but then one is getting into the proper fit and function of the lug nuts against the wheel...
A pretty problem...
Old May 30, 2005 | 01:39 AM
Helporb's Avatar
I would be very interested in a set. How about mounting them to the two screw holes near the 4 bolt holes?
Old May 30, 2005 | 03:44 AM
saicow's Avatar
Default steelies center cap
Tomas is right...and I don't have the wheel in front of me.....the last post was something about 2 screw holes by the lug nuts? Where are they exactly? I am now in a place where I can fabricate these caps cheaply and with high quality....if I could come up with a working design....
always could tap 2 screw holeson the face of the wheel, but that aint that easy (to attach the caps).....
so....any concrete suggestions would be great and helpful and result in a few sets for everybody....maybe a few designs on the top of the cap....plain, bulls eye...Japanese characters???
Help me solve this problem and we all could benefit (Steelie Peeps anyway....)....thanks, Bradford
Old May 30, 2005 | 05:10 AM
Tomas's Avatar
Admin Emeritus
Well, for at least right now I'm a 'steelie peep' so it would be to my advantage to see something like this work.
IIRC there have been some '4 x 100' Toyota cars that HAVE had factory center caps - some of the 'hubcap' places on-line have replacement OEM caps for them.
Thing is I have NO idea how Toyota went about attaching them.
Whatever Toyota did was probably the easiest solution...
For example scroll down on this page...
http://www.hubcaps.org/corolla.html
I really don't have a whole lot I can add.
Heck, if *I* were to "design" it, the solution would probably involve copious amounts of epoxy somewhere along the line.
(BTW, I don't know what happened to Sid's pics, but this was a nice solution, too [later in thread]).
https://www.scionlife.com/forums/vie...ight=fence+cap
Old May 30, 2005 | 06:17 AM
saicow's Avatar
Default center caps
great response....any other ideas? Speciifc solutions? I can fabriacate most anything right now over here with a clear plan.....talk to me.....Steelie Peeps!!
Old May 30, 2005 | 07:22 PM
1epoXyBox's Avatar
http://i4.photobucket.com/albums/y14...5/DSC00491.jpg
From thread:
https://www.scionlife.com/forums/vie...tint&start=225
Old May 30, 2005 | 10:06 PM
Tomas's Avatar
Admin Emeritus
front
rear
(pic size reduced 66% from original)
Old May 30, 2005 | 10:35 PM
Tomas's Avatar
Admin Emeritus
If Toyota can do it in Celicas, we should be able to do it on Scions.
Here's a Scion xB wheel with Celica hubs Photoshopped on...
(Not saying these are especially nice looking, but...)
Old May 31, 2005 | 12:57 AM
2tone_xB's Avatar
Interesting, cause I need some.
Old May 31, 2005 | 02:35 AM
Straylight's Avatar
I'd be interested in this, too. My RS2.0 is riding around on plastic and steel.
Old May 31, 2005 | 02:36 PM
saicow's Avatar
Default center caps
So....anymore ideas out there? Time is running out for me over here to get something fabricated.....all comments welcome...
Old May 31, 2005 | 03:00 PM
DibujoB's Avatar
Way cooler than spinner hubcabs!
Old May 31, 2005 | 03:05 PM
Boxer_Rebellion's Avatar
Actually I think the "bullseye" one is pretty hot. Add those to some painted steelies with trim rings and it would be way old-school (in a good way)
Old May 31, 2005 | 04:31 PM
skitsoKID911's Avatar
good idea. why doesnt sum1 just go out to their car to measure?
