Vibrations coming from wheel/wheel well/engine bay
Old May 30, 2005 | 07:23 AM
pharynx's Avatar
Default Vibrations coming from wheel/wheel well/engine bay
I have not yet diagnosed where these vibrations are coming from, but solely from ear it sounds like its originating from the wheels. I measured the psi settings from each wheel, and they were bot hon their appropriate settings. I also looked underneath the car to see if i was dragging anything, again to no avail. Anyone know if I may have a bent wheel? The vibrations seem to be more of a roll, lump, roll lump, as if a circle now has a straight line in it. This being said, the sound is not constant - it comes and goes seemingly whenever it wants to. I've also heard this same noise while traveling on the freeway about a month and a half ago, only to return tonight. Any help in determing the possible source of this sound would be appreciated. Thanks in advance.
Old May 30, 2005 | 01:14 PM
DJ_X_Trodinaire's Avatar
Default Re: Vibrations coming from wheel/wheel well/engine bay
Originally Posted by pharynx
I also looked underneath the car to see if i was dragging anything, again to no avail. Anyone know if I may have a bent wheel? The vibrations seem to be more of a roll, lump, roll lump, as if a circle now has a straight line in it. .
hmm sounds like youre going over the break (Section) on a road?
or check the inner side of the tire for bubbles or lump on the tire.
Old May 30, 2005 | 05:31 PM
pharynx's Avatar
I dont think its the road, because it happens on regular residential streets as well. I will check, however.
Old May 30, 2005 | 05:35 PM
firesquare's Avatar
do you have alloy wheels?
hit any potholes lately,
what speeds does this happen?
are you lowered?
any stereo boxes or anything?
hows the tire wear? an scalpoing or flaring?
Old May 30, 2005 | 05:47 PM
SciFly's Avatar
good, analytical mindings, fs.
suggest you jack up the wheel. check for any looseness (grasp and shake tire)
then rotate the wheel to look for out of roundness or other defects already mentioned.
if the problem were always present at particular speeds we'd suspect wheel imbalance.
-could be a tire in failure mode, possibly-
Old May 30, 2005 | 06:09 PM
pharynx's Avatar
Its happening anywhere from 40ish(streets) to 70ish(highway). I am lowered.
Old May 30, 2005 | 07:04 PM
pharynx's Avatar
I just took it out for a quick drive and the sound seems to be just a sound, liek a rattle, but it gets worse as i turn either right or left (but moreso right).
PS: it makes a popping sort of noise.. like something is stuck; only If i could pin point where it was coming from. BTW, this sound now seems like it was started yesterday (even though i only drove it once and NOT over a pothole then).
Old May 31, 2005 | 02:25 AM
pharynx's Avatar
Bump.. anyone own a shop that could diagonose this problem?
Old May 31, 2005 | 02:38 AM
wagonbldr's Avatar
The Family
Have you looked at the boots on your CV joints. It doesn't take but a little dirt to ruin a CV joint. It will cause it to pop and crack, more so when turning.
Old May 31, 2005 | 04:06 AM
Frankee_Gee's Avatar
The problem I've found with my xbox (automatic)
I get a strange rattle/noise while on "Drive" with my foot on the Brake. Once I let off the Brake...no noise.
Anyone else notice this problem?
Old May 31, 2005 | 04:10 AM
squirrel's Avatar
alignment? loose lugnuts? something loose for it to shimmy like that.
Old May 31, 2005 | 04:13 AM
It's done it from day one.
I recently up graded to TRD wheels and still have same issue.
Old May 31, 2005 | 04:34 AM
pharynx's Avatar
fixed, looks like my lugs were loose on BOTH wheels
archael666
Mar 19, 2019 11:52 PM
miguelishu
Jul 15, 2017 04:17 PM
brownSys
Feb 27, 2015 04:20 PM
randode
10
Dec 11, 2003 06:05 PM
ChickenAdobo
Oct 16, 2003 03:57 PM
