i need help--- how can i remove the front panel doors
I believe the factory speakers in the XB are rivited into the door. So if you wanna take them out your gonna have to drill out the rivets and replace them either with screws or more rivets. the door panel is two screws on the front by the hinge and then just a yank. Good luck!!
umm one screw by the door handle one screw in the armrest in the compartment and one plastic screw on the side by the hings.....and yes the door speakers are rivited in
These were the easiest door panels to remove. In addition to the above, you will have to remove the wiring harness from the door switches before you can completely remove the panel.
It will take you about an hour or so for each door to change the speakers, or longer if you are making your own adapters. I used Scosche SAT6 adapters for the door speakers with Pioneer Premier 6.5" 4-way speakers. Next on my list is the same speakers in the rear and a Pioneer Premier 60x4 amp. I'm gonna make my own adapters for the rear but Scosche has them for 6.5" speakers in the stock rear location. I'm making my own so I have enough clearance behind the side panel for the tweeters.
Good luck and have fun!!!!
Originally Posted by Grime
ok this is probably a noob question, but how do I drill out the rivets?
When you're done, you can pluck out all the bits and pieces of the old rivets. You're not shooting for drilling new holes in the door, just drilling out the rivet heads.
dockwriter
Oct 29, 2003 10:55 PM
