how do i get the lens off the xb taillight????
i want to try some thing crazy and i need to take off the stock outer lens of the tail light and keep it intact. and than reassemble them so no high quality H2O gets in there
thanks
Is it really computer stupid or lazy?
https://www.scionlife.com/forums/viewtopic.php?t=60677
If you look at the top of this forum there is a :FEATURES" menu, with "TECH" under that. You'll find many interesting articles there.
if you get water in the lamps, its covered under warranty
the water you see in there will never get in the tailight.
and likeTHE DON said, bee freakin careful i cracked both of mine but no leakes, no fog
-Paul
-Paul
thanks for the warnings guys. will it still be under warrenty if i open it up?? hhmmmm they don't really have to know about it do they
. if there painted they'll know though. im thinking out loud sorry
With lots of love!! or you will break the lens. This happened to me on the first try. The second try worked well. Start with the top tab, use one screw driver to pull the grav part away from the tab, then use another to put into the tab hole and push the lens upward. When you get this done put a folded piece of paper inbetween the gray housing and lens to keep it open. Then start at the top-outside corner (if your tail were on this would be the side closer to your back tire or side of tails that don't have tabs) and start to open with your hands, this part opens easy. Once done, use the screwdrivers, CAREFULLY! to open up the other tabs. If you screw up you can always by another set for cheap on ebay for about $30.
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
mischman
Sep 15, 2015 03:38 PM
Btp907
Sep 11, 2015 11:46 PM
