is there a front sway walk thru?
Old Jun 3, 2005 | 01:30 AM
jct's Avatar
jct
Default is there a front sway walk thru?
has/is anybody gonna do a walk thru for a front sway swap i'd like to see what all goes on to do some thing like this
Old Jun 3, 2005 | 01:53 AM
xBHAWK's Avatar
Default Strut Tower Bar DIY Install
Yes, go to the TECH section under 'features' tap. Choose XB 2004-2006. Select Strut Bar Install and VIEW. I used this info to do mine by myself and the information was invaluable. Tricks include: lift the car, unbolt the three bolts then push down on the tire to make clearance to install bar on the bolt in the back that is flush up against the wiper motor wall. Read and see photos.
Old Jun 3, 2005 | 01:56 AM
xBHAWK's Avatar
If you mean the SWAY bars undernith, they are there as well, two down fron strut bar.
Old Jun 3, 2005 | 12:19 PM
jct's Avatar
jct
yes sway bar not strut bar i already have and done the strut bar that was cake walk
Old Jun 3, 2005 | 09:01 PM
squirrel's Avatar
You basically have to lower the whole front frame assembly to do it. A lift helps, as does air tools.
Old Jun 3, 2005 | 10:59 PM
jct's Avatar
jct
well i have any of that...
hand tools jack and jack stands is all i have
Old Jun 6, 2005 | 09:31 AM
Guest
Guest
Posts: n/a
I would highly recomend having a shop install it for you, many of times have I seen and talked to people doing the job on their own and only to have the check engine light on after the install. Just a heads up, that it is a big job.
mark13018
Feb 6, 2015 08:57 AM
JPuehl
Jan 10, 2015 01:01 AM
kleecker
Jan 9, 2015 02:26 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
