What not to add to your xb if you go turbo or S\C?
I was wondering what mods should you not do if you plan to go turbo or S/C. I heard that you shouldn't do headers if you go turbo and stuff like that. Also What mod should you do before you go Turbo or S/C. THanks Big D
i would also like to know what to get and not to get i was thinking of getting a turbo, i know that you shouldnt get a cold air intake because most of the time they cannot be used with the supercharger or turbo setup
the turbo relies on a new exhaust manifold (headers) to power the
turbo so the stock one is useless.
if you super charge it then you can buy headers. the supercharger is belt driven
and doesnt rely on the exhaust gases to power it.
Supercharger = instant power but little top end
Turbocharger = turbo lag but great top end power (depending on the turbo size)
seeing how this is a 1.5L motor you might want to opt for the S/C. more streetable
power on tap.
Go with the suspension parts first. Then go with the engine parts. If you go S/C, get a header & exhaust. If you go turbo just get a exhaust. Dont really go for a CAI. Seeing that the air is going to go through something that compresses it any ways, there is no real point + the S/C or Turbo come with its own intake set up. You could do Flywheels also + upgrade clutch for the added power. Do light weight wheels. Carbon Fiber hood to lose some weight. For about every 20Lb you drop from the car its like adding 1hp. Also do a short shifter. I would suggest a oil cooler. A tranny cooler if your a auto. Spark plugs + wires. Unless they have rods, cranks & pistons for the 1.5L engine now, then thats about all I can think of. Also upgrade your brakes so you can slow down your new found speed. Also get the light weight crank pulley. Thats about all I can think of. Good luck with your future building.
Originally Posted by hotbox05
it takes power to make power with the turbo too.
About what to add or not add: Dont get a header if you are going turbo. You dont want to buy parts twice. Convert over to a return style fuel system so you can run a regulator. Get the Perrin fuel rail and the 2zz injectors. Also, it wouldnt hurt to get the perrin lightweight pulley, a lightened flywheel and a heavier clutch. Also, if you go turbo, you may want to upgrade the exhaust to a larger diameter and lose the cat. I know I know, its not legal. But is anything we do legal??
Yeah, dont get header if you're going turbo. It really sucks to see your "kinda new header" in your garage the whole time after you add a turbo.
and ... heh
Its NOT legal if someone knows.
Its Legal if no one knows :-P
and ... heh
There is barely resistance. With a properly sized turbo, there is minimal lag. About maintenance, it may require more in the future as in seals and such. One of my turbo cars has 120K on it, runs at 18psi of boost regularly with still no shaft play or oil anywhere....
you cant buy a header if you have turbo. the manifold is made for the turbine and so on and so on
i would like a supercharger just for my personal liking and from what ive personally seen.
turbos are cool also but with any forced induction you gotta know what your gettin into and what parts you need
injectors, custom exhaust (at times but recomended), fuel pump, spark plugs, etc etc
Im planning on going with the S/C. So far i have TRD Clutch kit, Perrin pulleyand Short Shifter, DC Header and Exhaust, AEM Intake, and Groundfusion ground kit. Will i have to swap out any parts when i get the S/C? Because so far the pulley, clutch, and header are not installed. Also would the Blitz Compressor be an easy install?
how is the clutch kit? im in need of a clutch soon (mines slipping).
the blitz supercharger from what i hear will take a good saturday to complete with good technicial knowledge and a few pair of hands.
i dont know about the clutch kit. It just sits on my bedroom floor along with the pulley and headers. Does it have to be multiple people? Hopefully not because a friend is a Toyota mechanic and im gunna have him do the install
i've always thought of a supercharger as a bolt on item....not that it's the easiest thing to install, but as far as it working with everything else already there. i would say you probably wouldn't want to put an exhaust on your car before the turbo, cause you'd probably want a turbo exhaust set up, not a N/A setup. i'd say the clutch is a must do, from what i've heard.....and the suspension also.
