Offsets for 17's
Old Jun 6, 2005 | 05:57 PM
Dakine's Avatar
Concept in Motion Crew
Default Offsets for 17's
I have some rims that i havent installed yet. 17 x 7.5. what would be a perfect spacer offset that would line with the wheel fender?
Old Jun 6, 2005 | 06:26 PM
hahajoey's Avatar
whats the offset on them right now?
the front u're gonna run at least a +30
and in rear u wanna run a +10
Old Jun 6, 2005 | 06:46 PM
Dakine's Avatar
the wheel's offsets stock are at 45 mm.
Old Jun 6, 2005 | 09:04 PM
hahajoey's Avatar
so i would run a 15 mm in front
and at least a 35mm in rear. if not
Old Jun 7, 2005 | 04:52 AM
O5_TRD_tC's Avatar
so will this be the same as for the stock wheels?
Old Jun 7, 2005 | 07:03 AM
hahajoey's Avatar
i think our stocks are 15x6.5 and they are +35 offset.
i can be wrong
Old Jun 7, 2005 | 07:20 AM
hawaiiguy's Avatar
Default according to tirerack.com, the offset on stock rims is 38mm
n/t
Old Jun 7, 2005 | 04:18 PM
Subcompact Culture's Avatar
I'm a n00b when it comes to spacers ... would you need longer lugs fro the spcers, or are the OEM ones just fine? Are there any wear-and-tear problem when running a spacer?
Old Jun 7, 2005 | 05:34 PM
hahajoey's Avatar
u will need longer ones.
h&r recommends 7-8 complete rotations for your nuts to go
into the studs.
u can get longer toyota ones.. or if they are 1" spacers. they will give u new studs.. check out H&R.. and onetongarage.com
van over at one ton has nice quality 10mm spacers i think for the rear. they're called spacer shims and they add 10mm
without losing any stud,, they go behind the hub. i have a set on
my car and i love them! great quality..
Old Jun 7, 2005 | 05:39 PM
Sid_xBicious's Avatar
is this thread for tC or xB?
Old Jun 7, 2005 | 06:28 PM
hahajoey's Avatar
whoops. if its for a tC.. shims won't work.
but he does have universal spacers. and they're constructed of super good quality.
as for fitment. u should be able to go like down to a 30 offset.
im thinking a 10mm spacer all around.. maybe even a 15 will bring your rims FLUSH.. u might wanna run a 205/40 to stretch it a lil.
Old Jun 7, 2005 | 11:20 PM
O5_TRD_tC's Avatar
did anyone do this to stock rims?
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
