Kaeon
06-07-2005, 07:26 AM
In this tutorial I will show you how to install some Auto Meter Gauges. The Three types of gauges we will be working with today are, Boost/Vac, Pyrometer, Oil Pressure.
The Boost Gauge "Kit" comes with MAP Sensor, Plug & Play wire for the MAP Sensor to the Gauge, Hose, Misc Plugs, "T" fitting, And Light Bulb.
The Pyrometer Gauge "Kit" comes with the Probe, Shrink Wrap, Misc Bolts and Screws, Signal wire for the Probe, Light Bulb, And a Clamp.
The Oil Pressure Gauge "Kit" comes with the Oil Pressure reader, Misc Bolts and Screws, Light Bulb,
Tools Needed:
Allen Key Set.
Socket Set
Wire Stripers/Crimper’s
9/16th Openhead Wrench
Jack
Jack Stands
Supplies Needed:
(2) Mini Add A Circuit Fuse Taps by Little Fuse(Or any other brand)
18 Gauge Wire
16 Gauge Wire
18 Gauge Butt Connectors
16 Gauge Butt Connectors
18 Gauge O-Ends
16 Gauge O- Ends
Electrical Tape
14 Gauge Wire Connectors
Universal "T" Fitting. ( Picture below under "Boost Gauge/ "T" Fitting:")
Optional:
*ENGINE OIL FILTER BLOCK ADAPTER* (Link below in tutorial)
Depending on your what type of gauges your installing you may need some other things.
CF Cups:
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1010.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1012.jpg
First Start off with the package that comes with your cups.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1014.jpg
Now grab your center brace
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1016.jpg
Slide your clamp over the cup
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1017.jpg
Place your clamp on the mount
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1018.jpg
Get your screws
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1019.jpg
Put your washer over it
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1020.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1021.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1022.jpg
Now place your center brace in the center of the clamp and mount and insert the screws tighten them and BAM! You have a CF Gauge Cup :)
Boost Gauge:
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1023.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1025.jpg
Run your power/ MAP Plug threw the Cup
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1027.jpg
Plug it into the gauge
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1029.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1031.jpg
Run your Lights Power and Ground outside the back of the cup
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1033.jpg
Make sure you put the black rubber band around this end of the gauge
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1034.jpg
Close it up and your done!
Pyrometer:
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1036.jpg
Ok so now grab your Pyrometer sender wire (Its the big yellow one :wink:)
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1037.jpg
Feed it threw the back of the cup and onto the correct terminals. Auto Meter Lables the Yellow and Red Terminals for you, So place the Right color on the right terminal
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1038.jpg
Tighten down the Nuts using a 7mm socket and your done with that. Feed the Power/Ground for the Gauge (Red/Black) and the Power/Ground for the Light(White/Black) threw the back of the cup.
Now its time to get down and dirty, This is the point where you take a deep breath, Eat A sandwich, Get some Iced tea and relax. Why you ask? Well because this part is crucial One mixed up wire could mean *BOOM* Bye Bye tC! Heh not really but miswiring something could have some serious results.
Mini Fuse Taps
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1167.jpg
Get your Mini Fuse Taps
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1165.jpg
http://www.scionlife.com/tech/gaugeinstall_tc/100_1166.jpg
Cut 5 inches of 16 Gauge Wire and connect it to the Mini Fuse Tap
Power/Ground for Light Bulbs: Do this for all the Gauges.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1168.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1169.jpg
Connect your 18 Gauge Butt Connectors to the Power & Ground wires and crimp them.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1171.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1172.jpg
Now connect your extension to the other end of the butt connectors I would say cut 5-6 foot if your not to sure where you want to put the gauges, I myself am putting the Boost over my steering wheel, And the Oil Pressure, Pyrometer in the cubby hole under the clock.
But Hey What about the Oil Pressure?
I left the Oil Pressure out till now because it requires you to do all the wiring.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1174.jpg
Now on the Auto Meter Oil Gauge (Check User Guide if using another brand), The Power Is on the bottom Right, The Ground is on the Top, And the Sender Wire from the Pressure Reader goes on the left bottom.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1173.jpg
Now time to fab up some wires! Cut once again a 5-6 foot wire(If your not using speaker wire as I did, Mark the Negative wire with something you will remember)
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1175.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1176.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1177.jpg
Using your 16 Gauge O-Clamps crimp them on to your wire and co
nnect the wires to the proper location. I had to bend these up so they would fit in the cup.
Pyrometer/Pyrometer Probe
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1039.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1040.jpg
This is where Auto Meter recommends the Probe (Two Inches from the Head), They supply the fitting that needs to be welded to your manifold for this type of install. Being I am not using this method I’m going to show you the easier method.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1042.jpg
Unscrew your 1/8th NPT Fitting and remove it.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1043.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1044.jpg
Remove this nut
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1045.jpg
Grab your Screw Collar
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1046.jpg
Place the Clamp on to the probe.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1048.jpg
Then place the screw collar on
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1049.jpg
Tighten the screw collar using an Allen key.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1267.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1234.jpg
Now your going to run your yellow sender wire for the Pyrometer down to one of the two bushings The first picture shows the main bushing under the steering wheel, The second one is behind the glove box on the passenger side.
But wait How do I get to the second one?
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1274.jpg
Push Both sides of the glove box in at the same time and pull forward
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1273.jpg
Unhook this mini shock
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1272.jpg
Remove the glove box from these clips
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1270.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1233.jpg
Behind the ECU is the bushing I have small hands so I got the wire in with a little effort, those with big hands might want to remove the bolts for the ECU and move it out of the way (There are two 10mm bolts)
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1281.jpg
Your wire will exit here, Its your choice how you want to run the wire (Being some of you may want to relocate a gauge or just like to do things your way), Make sure your wire is ran in a way that will not conflict with any other parts (Moving Parts, etc)
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1231.jpg
You have this much wire to work with.
Installing Probes, Senders etc
*First your going to need to jack the car up using a floor jack and place it on jack stands from there carry on to the next step.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1236.jpg
Drill your 1/4th size hole 6 inches from where the Manifold and S.Pipe Meet. (There is a shell around the S.Pipe so you will actually drive threw two pipes)
*You would want to place this probe in the hottest pipe on the header/manifold before the turbo. Being there is DC headers on the car the pipe work is very small. If you want to install it in the header you will need to take it to a weld shop and have them weld on a spacer or two.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1237.jpg
Grab your Ceramic Washer
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1238.jpg
Place it on the probe
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1239.jpg
Place the probe in the hole
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1240.jpg
And tighten your clamp
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1241.jpg
Place the shrink-wrap over your wires if you haven’t already.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1242.jpg
Unscrew the screws from the nuts.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1244.jpg
Place the O-Ends together and place the screw in them both and tighten down using the nuts. Place the shrink wrap over these joined wires, Get a hair dryer to shrink the wrap (Or if you live in The Fla like me and its 100 degrees already just leave it the exhaust pipe heat and natural heat should shrink it up.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1180.jpg
Here is your T fitting. Depending on how your installing this Boost/Vac. Will determine how you want to cut your fitting depending on the lines your using, In my case I want to Cut 2 pegs off the Left & Right, And one peg off the Top.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1181.jpg
It should look like this when your done.
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0550.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0551.jpg
Remove this to access your vac line. Its under this plug.
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0552.jpg
Remove the line from the bottom of the plug
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0554.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0557.jpg
Place the T Fitting in the vac line and cut about an inche off the vac tube off
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0559.jpg
Flip the T around and plug it into the vac line you just cut.
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0560.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0561.jpg
Plug your Vac line into the plug.
Run your Plug for the MAP sensor threw your bushing choice I ran mine threw the Main bushing under the Steering wheel.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1249.jpg
Plug the "Plug n' Play" wire from the gauge into the MAP sensor
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1250.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1251.jpg
Plug your line into the MAP sensor
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0563.jpg
And plug the other end of the line to the T fitting
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1254.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1255.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1280.jpg
I zip tied my MAP sensor here, If you have a serious race setup or extreme hp I would mount this in the fender wall, Or against the firewall to save it from extreme vibration that could cause it to give a inaccurate reading. *Note Vac lines may differ depending on setup (NA F/I)
Oil Pressure
For the oil pressure sensor you are going to need a Engine Oil filter block adapter. (If you want to make it easy on yourself)
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1529.jpg
http://www.importparts.com/shop/product_info.php?products_id=1641
(Please note* That this adapter didnt work out to well for me I was unable to tight in down without it coming loose, Im currently looking for a better adapter)
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1534.jpg
There are four (4) port holes 2 on the front one on each side. Choose one that best works for you.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1536.jpg
Using your hand unscrew the port plug
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1538.jpg
And plug this end of your sensor into the port, tighten it down using a 9/16th Open head wrench. You may want to use some teflon tape on the sensor.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1540.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1542.jpg
Perfect fit! Remember this adaptor can be used to run a oil feed line to a turbo if your car is F/I
Now your going to have to remove your cars oil filter, Time for an early oil change! Drain your oil, get yourself a new filter *Note the stock filter will not work anymore I had to use a filter from a Acura Integra its Mobil One # 104*. Place the Engine Oil filter block adapter on first using the supplied threaded bolt tighten down, Now screw on your oil filter hand tight. Hook up your sensor wire from the gauge to the back of the sensor using a O-End. (Pictured in blue). *Note you may need a 90 degree elbow to make the sensor fit depending on the mounting choice, Auto Meter sends you some with each gauge. I myself used 1 elbow and 2 extensions.
Wiring
This part is pretty straightforward, I take it that if your trying to install gauges you have wired some things before.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1257.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1258.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1259.jpg
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1278.jpg
Basically Your going to strip about 1/2 incheS off each of the power wire in this case there would be six (6) of them, Two (2) each Gauge One (1) to Power the Gauge One (1) to power the light in the Gauge. So being we have Three (3) Gauges there will be Three (3) to power the Gauges, and Three (3) to power the lights. Grab your Add A-Circuit Tap and the Three (3) power wires from the lights put them all together twist on your wire connector and crimp. Grab a new Add A-Circuit Tap and the Three (3) power wires from the Gauges put them all together twist on your wire connector and crimp.
http://www.scionlife.com/tech/images/gaugeinstall_tc/100_1260.jpg
Now take your Three (3) ground wires from the Gauges put them all together using your O-End and crimp. Then take your other Three (3) ground wires from the Lights put them all together using a new O-End. Then mount these two O-End's to this bolt (Under the steering wheel (10mm bolt). Nows the time to clean up your wires, I used Clear Zip Ties, If you would like a picture of this please let me know. Basicly clear your wires up the way you like.
http://www.scionlife.com/tech/images/gaugeinstall_tc/000_0548.jpg
*Note the copper wire in the fuse is my REM wire for my amps.
Plug in your Add A-Circuit taps and plug in the appropriate fuse. (The OEM fuses will not work because their legs are to short, But the Add-A-Circuit kit comes with some) Being these are full sweep gauges, they require at least 8volts or more during engine cranking (aka starting the car) When you start your car it requires a lot of power so most cars (Yes Our tC's) will grab power from other sources, this is why you might notice your radio and gauges dim during a start up, So what I did and what you should do is hook up the Gauges power to the ECU fuse, Your going to take out the OEM fuse plug the holder in and place the FUSES in. Notice I said FUSES? You need to put 2 Fuses in each holder, one to make the connection to the Add-A-Circuit wire and one to make the connection witch you just removed (In this case ECU) The fuse I used for the lights power is the Panel fuse (Or any fuse that shuts off with the car) And your all done!
All Done!:
Review:
The Auto Meter Gauges are good quality for sure. I myself got the full sweep Gauges that calibrate at every engine start up. The install was done with simple hand tools and wire connectors. The instructions Auto Meter supply could be a little bit more informative. They miss some key steps and suggestions, Other then that it was a good, easy install. Install time for me was about 2-3 days, You could probably do it in one day but I like to take my time. I took the first day to wire and preplan and the second day to install (Of course stoping to take a photo everystep of the way). Be it that the instructions were unclear In certain areas, I contacted one of Auto Meters Techs, He was very helpful and got me the information I needed. As for the Boost Gauge, I will be putting a Turbo on my car soon (I hope) The Boost gauge was installed in this tutorial for Informational use only. The oil Gauge needed a Engine Oil filter block adapter for it to work on the tC (Without removing the stock sensor or drilling holes in the oil pan). All and good product could use better instructions for new installers.
Update: For a while now my pyrometer has been going crazy. The needle would just move all around here and there, I noticed when I would go over a bump it would do this. So I took the gauge out a noticed that one of the pegs are loose in the gauge so its not making a good connection. Now the pyrometer doesnt want to work at all it clicks in whenever it touches down where its supposed to. Im going to check today to see if it can be fixed.
I was told to contact the tech/service department about getting the gauge looked at to be replaced. I talked to a nice lady named Sherry, She said to send it back and they will look at it and replace it for me. I sent it back Friday August 12th.
Tools Needed:
Allen Key Set.
Socket Set
Jack
Jack Stands
Supplies Needed:
18 Gauge Wire
16 Gauge Wire
18 Gauge O-Ends
16 Gauge O- Ends
Electrical Tape
Optional:
CF Cups:
Get your screws
Boost Gauge:
Pyrometer:
Mini Fuse Taps
Remove this nut
Oil Pressure
Wiring
All Done!:
Review:
