matty-tC
06-08-2005, 03:53 PM
Does anyone know of a site with a visual explanation of offset and rim size?
When I pick up my new rims I'm trying to make sure they're flush with the side of the car after the suspension is on. The stock 17 inch wheels use a 45 mm offset. I think they're 7.5" wide? (am i correct??)
I want to get 20mm farther to the outside of the car. I'm guessing a 8" wide rim with (0.5" farther out.. 12.7 mm) with 35 mm offset would be 22.7 mm.. Is this right? or am I backwards?
thanks in advance to anyone with some knowledge :)
raamaudio
06-08-2005, 04:22 PM
8"with 35mm offset it perfect, as flush as you can get without having to roll the fenders, etc, which you probably do not want to do.
I have 17x8's with 35mm, 235/40/17 Hankook R-S2's and it looks great lowered:)
The same thing will apply with 18x8, 19x8, etc, as long as you do not try to use to wide a tire, 235 is the max I would even condsider on an 8" wide wheel.
Rick
matty-tC
06-08-2005, 04:28 PM
thanks
i was thinking that was about right i just didn't want to make a $1300 mistake LOL
got any pics online of your car?
hahaitzskippy
06-08-2005, 05:05 PM
ya im running 17x8 +35. and the front is flush with teh rear almost flush. i have 5mm spacers that i need to install.
check my car out
http://pg.photos.yahoo.com/ph/aznskip96/album?.dir=f9a6&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos
hahaitzskippy
06-08-2005, 05:08 PM
check my car out
http://pg.photos.yahoo.com/ph/aznskip96/detail?.dir=f9a6&.dnm=c03c.jpg&.src=ph
http://pg.photos.yahoo.com/ph/aznskip96/detail?.dir=f9a6&.dnm=2e64.jpg&.src=ph
http://pg.photos.yahoo.com/ph/aznskip96/detail?.dir=f9a6&.dnm=efdb.jpg&.src=ph
http://pg.photos.yahoo.com/ph/aznskip96/detail?.dir=f9a6&.dnm=dfd7.jpg&.src=ph
http://pg.photos.yahoo.com/ph/aznskip96/detail?.dir=f9a6&.dnm=12cd.jpg&.src=ph
hope that satisfies you :D
matty-tC
06-08-2005, 06:02 PM
lol the photos aren't close up enough and you have your wheel turned in all of them. but looks good from what i can tell.
05silvertC-
06-08-2005, 06:18 PM
I was rocking a set of 18in volk gtn's with 35mm offset 8.5in rim and perfectly flush with the fenders..my car is not to low it just has a set of TRD lowering springs on it but the fittment of the wheels was perfect..
matty-tC
06-08-2005, 06:22 PM
why did you get rid of the volks??!?
