Stock tweets are 13 ohms ?!
I am ready to swap out my stock tweeters and notice they are 13 ohms... If this is wired in parallel with the front door speakers, that makes this combo 3.05 ohms...
When I put my new 4ohm speaker in there it will now become 2ohms. Does anyone know if this will cause any problem with the stock HU?
ooooooh......I give you a pat on the back for checking into this.....I can't be of any help, but it would seem like it may pose a problem....hopefully someone on here can clarify your situation.....good luck!!!
Originally Posted by mandos
You are swapping out your speakers but not using a crossover on them?
When you hook the HU up to the new x-over...then x-over to your 4 ohm comp set, it'll work fine.
I just swapped out all my speakers in my xb, 4" Pioneers, 2 way, in the dash. 6.5" Pioneer 2 way in the front doors. 5.25" Sony 3 way in the rear (they were free so why the change in brand).
I have not installed bass blockers and a couple of knowledgable folks listened and said not to as they wern't needed.
All of this with the stock HU.
I would say try it first with no blockers and go from there. The dash units are super easy to get to and make changes if you decide later that you have to have them.
Walt
Walt
so then how are the factory speakers wired? if not a crossover? just in parallel? so any of us who just replace the woofer part, are going to have to use a crossover? otherwise we run the risk of burning out the amp in the stock headunit?
B_Real45
Feb 23, 2015 07:33 PM
CONCRETETC
Feb 9, 2015 08:05 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
