I installed the TOY03-AUX adapter on my stock radio today so I could connect my iPod to the HU, because im sick of making CD's. I took pictures while I was doing it to post here.
Things you need:
- First off, what you need is your TOY03-AUX adapter. I got mine from discountcarstereo. If you dont already have one, here is the link :
http://www.discountcarstereo.com/detail.aspx?ID=548
- Then you need to have a RCA to 3.5mm cable, which you can find at Best Buy, or any other audio/video store.
- Phillips head screwdriver
- Pliers of some sort
- Twist tie or something to hold your excess audio cable
- Double-sided tape
Here is a picture of my AUX adapter, it has two cables, male and female 12-pin plugs, but you'll only need the male.
http://www.scionlife.com/tech/images/ipod_tc/001.jpg
Next, you have to pull apart your dash. If you dont already know how to do this, remove your shift knob and pull on the sides of the silver trim by the cubby hole gently until it begins to come out. Be careful, the cigarette lighter wires are attached to this piece. You might have to turn on the car and change the gear to drive in order to get it all the way off. Just set it to the side. Next, pull on the silver trim for the AC/Radio Cover part, being sure that the radio door is closed before you try this. Then, hold down the little tab on the cable connected to the AC controls, and remove it so you can move the console out of your way.
Here is the mess you'll have once you've removed the center console:
http://www.scionlife.com/tech/images/ipod_tc/002.jpg
Remove the two screws on the bottom of the radio harness:
http://www.scionlife.com/tech/images/ipod_tc/003.jpg
Then, remove the two nuts on the top of the radio harness:
http://www.scionlife.com/tech/images/ipod_tc/004.jpg
Once you pull out the radio and harness, you will see this. The white plastic is where we are going to mount the AUX adapter, behind the radio:
http://www.scionlife.com/tech/images/ipod_tc/005.jpg
I used double sided tape to mount it to the plastic, because drilling holes doesn't make any sense, then connected my RCA to 3.5mm cable in the side of the adapter:
http://www.scionlife.com/tech/images/ipod_tc/008.jpg
The 12-pin socket that you will attach the AUX cable to is on the back of the radio. Here it is empty:
http://www.scionlife.com/tech/images/ipod_tc/006.jpg
And here it is with the AUX plug:
http://www.scionlife.com/tech/images/ipod_tc/007.jpg
I then dropped my RCA to 3.5mm cable down behind the cubby hole and ran it under the cup holders so I could bring it out the side in a small hole that was already there. You can put it wherever you want, but this one seemed to be the easiest spot to me:
Now, place the radio harness back in its spot, replace the screws, reattach the AC control plug and put the console back on, and then put on the cigarette lighter section.
In order to use the AUX device you plug in, hit the DISC button twice on your radio, it should look something like this:
Here is a look at my final product:
http://www.scionlife.com/tech/images/ipod_tc/010.jpg
The End.
XBman
06-09-2005, 02:19 AM
Brilliant!! Yo add dis to the tech section
dctennis10
06-09-2005, 02:34 AM
If the mods want to add it, I dont mind.
ack154
06-09-2005, 02:38 AM
I ran my cable up under my ebrake, so you don't see so much of it (just be careful of keeping it out of the way of the gearing of the lever - mine runs around the cup holder).
And I have the 90 degree angled plug so it doesn't stick out so much. You can get one with the angle at Radio Shack or any other electronics store as well.
Other than that, I have the same setup. Same adapter, mounted in the exact same spot.
See pic:
http://files.allankintz.com/albums/tc/IMG_0549.sized.jpg
mrbridge
06-10-2005, 03:23 AM
Both of you might want to consider this (http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Section_Id=201526&pcount=&Product_Id=149006) item. I purchased it with the intent of cleaning the entire set up and it works like a charm. You'd have to make a small incision on the inside bottom of the glove box though, which might be somewhat of a deterrent for some.
dctennis10
06-10-2005, 03:26 AM
what item are you talking about?
Hyghgynx
06-10-2005, 04:03 AM
This may sound like a dumb ?, but by hooking up your iPod this way does your iPod sound better? I have mine hooked up by iCarPlay adapter by Monster. I'm assuming since mine is wireless, the sound quality isn't great. I hear ya on making cds, no thanks. Custom Playlists rock! :clap: BTW- VERY informative post! great pics and descriptions! GOOD JOB! :P
ack154
06-10-2005, 04:09 AM
This will make it sound a LOT better than any FM Transmitter.
MrBridge... I really don't think I'd have a use for that. I don't want any more wires cluttering up more than I have to. I don't really need to charge my iPod in my car b/c if it gets even close to dead, I just take it out and leave it in the dock overnight and then take it back to my car the next morning for work.
dctennis10
06-10-2005, 04:21 AM
The only advantage of having the car adapter is that it has the 3.5mm jack and it gets the audio from the dock connector so the audio is unamplified, unlike the headphone jack. im guessing this would just save you from jacking up the volume past 20 to hear it.
Tomas
06-10-2005, 04:49 AM
Speaking of Monster, I haven't seem mention, yet, of the iCruze (http://www.monstercable.com/icruze/) from them...
It does the same connection of the iPod to the head unit, but ALSO allows the head unit to control the iPod.
Anybody tried one of these yet?
mrbridge
06-10-2005, 06:37 AM
What clutter? You plug into the power adapter and the adapter plus into the ipod. Still only one cord, just with power capabilities. I use my ipod all over the place so keeping it charged is always a must.
Shrug, different purposes and applications, but I didn't know about these until someone pointed them out to me.
mikochu
06-10-2005, 06:49 AM
Looks good. I suggest using the line-out via the dock connector for the best quality sound. SiK, Inc. makes a dock connector line-out adapter: http://www.sik.com/din.php
I added this to the tech section.
ack154
06-10-2005, 12:08 PM
No... that's two cords. B/c your audio is still plugging into the power adapter, plus you have the power adapter cord. I'd prefer to stick to just one. Plus... I have a 4th gen iPod, so I get my full 8 hours, easily.
NewSpectraBlue
06-10-2005, 05:17 PM
You have to mouse-over mrbridge's post to see the link. Here it is with added underlining & bolding to help identify the hyperlink
dctennis10
06-11-2005, 09:11 PM
hah I just skimmed over it that day, thank you and sorry about that .
mrbridge
06-12-2005, 04:03 AM
Yeah, my sneaky url droppin ways boggle the mind! Sorry folks.
Ack, specifically, I was referring to this (http://www.scionlife.com/forums/viewtopic.php?t=60391&highlight=ipod+installation) setup.
I was also considering the
Griffin AirClick (http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1337363&Sku=G600-1040&SRCCODE=GOOPROD&CMP=OTC-FROOGLE) as an option to keep the ipod hidden from view.
That price is the cheapest froogle has shown so far.
Review of said part here. (http://www.ipodlounge.com/index.php/reviews/comments/griffin-airclick-wireless-rf-remote-control-ipod/)
Box916
06-20-2005, 09:39 PM
Here's my set-up. I drive an xB so I just put it in that little cubby in the dash. In the picture I have the i-trip for my ipod mini, but I used the TOY03-AUX with the RCA to 3.5mm cable output and I just drilled into my glovebox and up into that cubby, but you can kinda see from this angle how easy it is to just go through the glovebox and into the cup...it looks clean. :lalala:
I don't know. It doesn't seem too far to reach the iPod from where it's situated. Perhaps you guys just have short arms?
Clean install, will post when mine is completed.
Also ordered the AirClick will give review as well
miamibusta69
06-22-2005, 03:33 AM
I bet it suxs cuz i have the monster and its not all that great...
dctennis10
06-22-2005, 02:57 PM
It just looks like a long way to reach across while youre trying to switch songs while driving... I like the setup though.
Box916
06-24-2005, 10:40 PM
I've never had any problems changing the songs, there are also two cup holders in front of my stick, but I didn't want a passenger to goof around down there while I'm driving, so I put it in that cubbie. I'm tall so I have long arms, anyone under 5'10" might have trouble? So should I say there is a height requirement for this mod? :rofl: But anyways, I've never had any problems, the problems I used to have is carting around my collection of cd's, now I don't have that problem! :lalala:
dctennis10
06-25-2005, 02:52 AM
i just havent sat in an xB lately...its been a while since i've seen my friend who has one...i feel your pain with the CDs. thats the main reason i setup my iPod too.
rs1_0newprtbeach
06-26-2005, 06:02 AM
So, isn't that the same connector used for the XM tuner? I have XM, but would like an AUX input.
help :)
dctennis10
06-27-2005, 02:53 AM
I'm pretty sure its the same one.. I dont know what you'd have to do to get both AUX and XM.. However, I wonder what the other plug on the AUX adapter is for?? Anyone?
but if you have the factory XM option, two AUX inputs wont work, the only controls for it are in the HU.
cods
06-27-2005, 03:19 PM
two questions:
where is the disc botton? do you have to install this thing before you can get to the point where you can get to the disc button? i've pressed cd, am, fm, and xm(nothing happens when i press xm, is something messed up?) and i don't seem the button.
where is another website where i can get that device from? the website that is posted says it's on back order.
dctennis10
06-27-2005, 03:48 PM
its the CD button hit twice, it doesnt work until you have the adapter in.
and you can try www.crutchfield.com
cods
06-28-2005, 02:00 AM
can i buy one of these/have one ordered at a toyota dealer, or a car audio store?
i can do the exact same thing with my xb, right?
dctennis10
06-28-2005, 03:50 AM
Car audio store...and yes you can do the same thing with an xB
cods
06-28-2005, 04:13 AM
i can't get one from the dealer?
dctennis10
06-28-2005, 04:18 AM
nope. Try www.discountcarstereo.com or www.crutchfield.com or anything else you know of.
tanlogic
06-28-2005, 04:44 AM
Where can you get the cup-holder thingy for the ipod...I have an ipod mini. Same places (Crutchfield, Discountcarstereo)?
dctennis10
06-28-2005, 03:17 PM
THere or Best Buy...thats where I got mine, its prolly a bit more expensive there, but I had a gift card :)
Hoeney
07-05-2005, 09:33 AM
you know what's great about the 2006 tC. the upgraded stereo with steering wheel controls and an auxilary input so you don't have to add one yourself. *glote* but on my lebaron i used to drive i added a wired FM modulator to play the music from my PSP. the quality will always be less, unless you have an aftermarket stereo with built in aux input or ipod controls.
dctennis10
07-05-2005, 04:05 PM
someone is quite boastful.
mrbridge
07-05-2005, 08:32 PM
Just a followup within this thread. I purchased and installed the USA Spec piece and, aside from a minor electrical issue, have been pleased with the performance of the unit.
Most will be pleased to know that the Griffin AirClick has worked as expected without issue. I first mounted it to the steering wheel but it interfered with where I place my hands on the wheel. I have since relocated it to the emergency brake (turned so the buttons face the side of the seat) and it's fairly inconspicuous (despite its colour).
I'd definitely recommend it to those who want a RF remote to control their iPod while keeping it hidden from view.
slowpoke
07-09-2005, 03:07 PM
what is that cupholder peice,
mikochu
07-09-2005, 03:37 PM
That's the Belkin TuneDok (link (http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Section_Id=201526&pcount=&Product_Id=153999)). I personally got a Griffin iSqueez (link (http://www.griffintechnology.com/products/isqueez/)). I like it.
McoTC
07-10-2005, 01:27 PM
If you type in 12345 on the belkin site for coupons or discounts it will give you 50% off.
DarkLighter
07-14-2005, 04:38 PM
Does the TOY03-AUX require you to have the disc changer HU? Sounds like you guys are using the single disc HU. I have a single disc and I want to make sure it will work with it. Thanks!
dctennis10
07-15-2005, 03:12 AM
It works with single disk, thats what I have.
custom2k1
07-24-2005, 01:23 PM
Get the metra Axxess piece. You can pick it up at Circuit City for $59. It will work if you have xm radio because there is an input and output for the aux bus. It also has 2 aux inputs which both can be used even if you have xm. It uses disc 6 track 1 for aux 1 and disc 6 track 2 for aux 2. XM will still work fine.
It's similar to the PIE in this thread, but it had the ability to charge the ipod at the sametime. Any info or reviews would be helpful...
birdman
08-02-2005, 10:14 PM
How hard is to get your dashboard apart. I read the first part of the thread and it seemed easy. Is it really?
Has anyone else did this themselves?
dctennis10
08-02-2005, 10:36 PM
Its really really easy. Lots of people, not just me, have done it. I just figured it out myself.
Random6
08-04-2005, 02:25 AM
Thanks a ton for this! Did this tonight, was super easy.
t_d
08-29-2005, 04:03 AM
This post was a great help but I have one problem, I get a weird whine when my cars' RPM's go up. Its not too bad when I'm cruising, but it does get annoying. Is there anything you guys can think of that would help ? BTW I'm using a Dell Axim x50v if it helps. Thanks.
edit: I have a 05 tC.
wndctyboy
09-05-2005, 02:54 AM
How much does it cost the adaptor? I notice it will not charge the iPod!
Mmartin_47
09-26-2005, 03:10 PM
I have a 2006 scion tC. When you remove the trim and all there is another connector that is not in use. What is that for?
wnsham
09-27-2005, 02:45 PM
The USA Spec box I put in my xB only worked once. I installed it at night, and it worked OK, but the volume was only about half of what I get from the CD or radio. When I got in the car the next morning it didn't work at all. Crutchfield was good about taking it back, as they always are. But I'm not getting a replacement. I ordered the PIE model, and I'll let you know how it sounds. Might even post a pic of the panel mount mini-jack I'm using.
Update: The PIE thing sucked, too. It would work in the morning, but not later in the day, and vice-versa. Very unreliable. And when it did work, I could only get 1/2 volume from it, compared to CD or radio. These are not the way to go.
Ordered a whole new receiver with a front panel Aux input. I'll let you know how that goes. One of these days I'll get it right...
I have that 2 aux one and i love it i have my xm raido and my ipod hooked up when i started useing it i was confused on how to use the second one but i found out if you push the random buttion it will switch over to the second aux push the buttion twice and it will switch back to the first one i am really pleased with it
Bluechualappa
09-28-2005, 10:32 PM
My AUX adapter is suppose to be here on Fri. My question is though, how is the sound from the device? Is it CD quality or almost CD quality?
FASTER345
10-05-2005, 07:57 PM
I'm amazed that anyone has the time and energy (and $$$) to need an iPod and sat radio (and regualar radio and CDs?) in their car. You people just have way too much time on your hands! J/K :p
frday13
10-17-2005, 08:46 PM
i have a dell jukebox will this setup work for that also?
dctennis10
10-19-2005, 02:11 AM
I'd say its CD quality if you balance the volumes correctly. Just use common sense and put the iPod on 1/2 to 3/4 volume and then put your stereo on 30+ and it'll be great quality with no feedback or anything.
wnsham
10-30-2005, 06:26 AM
How could you possibly get feedback?
wnsham
10-30-2005, 06:34 AM
I custom built a panel-mount minijack to dual RCA cable for the AUX input. It is mounted in one of the removable blank switch covers that are just above the ashtray.
It looks really clean cuz when your .mp3 player is not in use, there's no wire hanging around; just a small 1/8" hole.
But with my new HU, I won't need it anymore, so if anyone wants it, you can have it for $10. And you have to send me the switch cover you take out, so my dash won't have a hole in it.
O5_TRD_tC
11-25-2005, 08:40 AM
can you still do this if you have the factory sub?
dctennis10
11-25-2005, 03:21 PM
Yeah you can, it shouldn't make a difference.
chipmOnk
11-27-2005, 04:54 AM
Is it possible to connect it to the SAT button instead of hitting the CD button twice?
lriicelboy
02-17-2006, 04:28 AM
does this adaptor work with the 6-cd changer in 05 tCs?
Moose411
09-21-2006, 12:14 AM
hey, have any off you heard of the iPod Drive+Play (http://www.harmankardon.com/drive-1/)?
saw an ad for it in a MotorTrend and figured it might be worth looking at, but i havent heard anythig about it. it looks pretty cool though, it controls the iPod with a little remote thing that has the same layout of the iPod.
mesterlk
11-26-2006, 11:20 PM
I prefer to use I trip for a connection-less use of the Ipod over the radio. No instillation required and will work on any radio.
Dakine
11-30-2006, 05:19 PM
I have a wired subplug installed on my 6 cd changer. Will the PIE work with this plug as well?
ADRdesignCo
12-01-2006, 03:33 AM
by the looks of it... yes paul. is there a plug there already? if there is, the set up will look like this deck < PIE Aux-in < sub harness.. thats why there is both a male and a female end.. at least my best guess. . lol
gdapache
12-29-2006, 05:39 AM
Hey there every one, First car I have ever had, First Mod of 3 planned. I have had my car since Dec. 04 and I love it! This was my first mod ever on any car and due to this post, it went off without a hitch!
First I didn't get the TOY03-AUX adapter, I looked at the bottom and got USASpec DF-TOY. It has 2 inputs for about the same price, but you CAN NOT USE AN EXISTING 6 CD CHANGER OR ANY KIND OF AUX DEVICE. Since I got my car stock, I didn't have to worry about this. After installing the USASpec DF-TOY, I made 2 cords, I took two a 12 foot long RCA to RCA cord from radioshak, and cut it in half. I then got two 3.5mm or 1/8th inch Female Chassis Mount connectors.
After I cut the cord in half, I soldered the 1/8th inch connectors by tying the ground leads together and then there should be a diagram that tells you on the chassis mount connector which pins on the back are Ground, Left, Right. OR 1,2,3. Usually 1 would be Left, 2 would be Right, 3 would be Ground, I just plugged in my cord and used my multimeter to determine which was which.
After you make the cords, all you need to do is drill a 1/4 inch hole somewhere in your console where you want to put it. I put mine on each side under the cigarette lighter adapter. You might have to use an exacto knife to clear away some of the shavings.
CLICK ON THE PIC FOR LARGER IMAGE
http://thumb4.webshots.net/t/59/459/3/44/81/2054344810011128044UJvJyo_th.jpg (http://rides.webshots.com/photo/2054344810011128044UJvJyo)
The 2 input adapter I got
http://thumb4.webshots.net/t/20/20/9/57/30/2491957300011128044qYVHZD_th.jpg (http://rides.webshots.com/photo/2491957300011128044qYVHZD)[/img][/u]
The first one I installed below the cigarette lighter adapter
http://thumb4.webshots.net/t/54/54/5/88/85/2264588850011128044LocAyg_th.jpg (http://rides.webshots.com/photo/2264588850011128044LocAyg)
The left side, had to cut into the wall to make room, simple exacto knife cut
http://thumb4.webshots.net/t/57/657/4/36/4/2762436040011128044igXfda_th.jpg (http://rides.webshots.com/photo/2762436040011128044igXfda)
what it looks like from the bottom
http://thumb4.webshots.net/t/59/759/6/86/28/2421686280011128044fcNlOS_th.jpg (http://rides.webshots.com/photo/2421686280011128044fcNlOS)
Finished product, I circled the two inputs on each side
http://thumb4.webshots.net/t/57/557/2/72/27/2753272270011128044OIQgEJ_th.jpg (http://rides.webshots.com/photo/2753272270011128044OIQgEJ)
After the install, i plugged in a 1/8th inch male to 1/8th inch male cord from radioshak into my ipod and worked great! you have to turn your ipod up all the way and the radio to about 35 for a good sound.
Just wanted to Thank Everyone who posted and helped, I hope I can do the same!
romper145
04-13-2007, 06:51 PM
any recommendations on a shop in south oc where i can have this installed for me?
thanks!
Daskid
04-13-2007, 09:06 PM
Holy cheesecrap resurrection!!! :D
Dude, try and DIY. Learn and save yourself some money.
romper145
04-13-2007, 10:56 PM
haha...i know the benefits of doing it myself. i'm just prone to breaking things when i try.
Bluechualappa
04-13-2007, 10:59 PM
This mod is pretty much just plug and play, I installed mine so lomng ago I don't even remember how I did it lol. But I use it daily on my 05 tC
Adeel
05-31-2007, 07:31 PM
dctennis thanks for the awesome walkthrough! I did this a few months ago and it works like a charm. Only problem is the radio cover squeeks a bit now when opened but that's probably my fault.
beamer0821
10-10-2007, 05:43 PM
these directions worked out awesome and were really east to follow, i had it installed, put back together and working in about 30 minutes.
A couple of things to note, my tc is an 05 but has the SAT option on the stereo so make sure you buy the righ auxiliary input piece with the /s
second thing I found it easier to connect the RCA cables and run them out side the dash before mounting the input device.
I have an iphone, so you need an extra part that fits into the recessed jack, so make sure you purchase that, about $10. I have Belkin and its great sound.
Thanks again!
April
beamer0821
10-10-2007, 05:51 PM
one more note, when i turn my car off and my iphone was on and plugged into the stereo the speakers make a litte pop noise. is this bad? wondering if its b/c i have my iphone volume all the way up and control the volume mainly through my stereo speakers. seems to sound the best this way.
but im concerned with this little pop when i turn off my car without shutting off the radio or disconnecting my ipod first
Tecrun19
10-10-2007, 09:25 PM
Its fine mine makes a pop if I disconnect my MP3 while its playing
someone was asking about it earlier and no one really responded. =x
JRod_TC
10-02-2008, 05:27 PM
I'm confuesd bc i have an 05 tc that doenst have ipod jacks or anything on it but i also have the same head unit as u... it has the button that says SAT on it. It says theres 2 options .. one with sat and one with out sat and different moduals for both :( which do i use??
showcasezf
06-19-2009, 04:48 AM
whats up!? Well I ordered the part.. for the aux input.. when I installed it.. I hooked everything up.. correct, but for some reason the music sounded very distorted. I took everything apart.. trying to diagnose the prob, but could not find the answer! It was fine sometimes, but when I hooked everything back up, the music level went down considerably! (you know how it sounds when you dont have your headphone jack in the mp3 player all the way?) you still hear music, faintly? thats what it sounds like.. but sometimes.. it worked again..? my question... finally, LOL is, could I be getting feedback from my radio? or is it a wire prob ya think? also, the part that was shipped to me looks a little diff. Ill try and get some pics.. does that matter?
http://img188.imageshack.us/img188/3990/0618092213.th.jpg (http://img188.imageshack.us/my.php?image=0618092213.jpg)
http://img221.imageshack.us/img221/2785/0618092212b.th.jpg (http://img221.imageshack.us/my.php?image=0618092212b.jpg)
http://img197.imageshack.us/img197/4146/0618092212a.th.jpg (http://img197.imageshack.us/my.php?image=0618092212a.jpg)
http://img4.imageshack.us/img4/4453/0618092212.th.jpg (http://img4.imageshack.us/my.php?image=0618092212.jpg)
thanks for any feedback or help! I just dont know what else could be the problem!
tvdang7
11-21-2009, 10:56 PM
just isntalled mine. mine sounds great but i got the aux/s satellite version. so your might be messed up.
note to some people trying to do it. you might need a socket wrench.
