Check out this cool cd/md player =D
I wonder why it's not listed on the Eclipse website. Eclipse doesn't have any Authorized Internet Retailers, store only.
I'm wondering if maybe this is a knock off since they don't list all the specs.
-Z
-Z
-Z
-Z
Its the new Eclipse NNC-1925, releases in Japan and UK only. Thats why its not on US site i guess, maybe not even on many sites yet. This is the newest 2005 unit. Very cool indeed!
Spec as below:
Eclipse's all new 2005 hottest CD/MD receiver features a advance MOS-FET 50W×4ch power amplifier that supports high quality sound as well as strong and powerful bass. Features an ultra stylish acrylic panel face design build-in with a high-resolution display. Comes in 2 classical colors.
CD-R/RW
MDLP
MP3
EasyTime Alignment
Sound Field Control
2Way X-cover
2Mode SoundControl
13Band GEQ
Specifications
CD section
Wow flutter: Below measurement limit
Frequency characteristic: 20Hz - 20kHz
Signal-noise ratio (JIS-A): 100dB
Dynamic range: 98dB
Distortion factor ratio: 0.02% (1kHz,0dB)
MD section
Signal-noise ratio (IHF-A): 100dB
Dynamic range: 98dB
FM tuner section
Frequency characteristic: 30Hz - 15kHz
Practical speed: 13dBf (new IHF)
Reception frequency: 76.0 - 90.0MHz
AM tuner section
Practical speed: 22 µ V (Signal-noise ratio 20dB)
Reception frequency: 522 - 1629kHz
Audio section
Installed capacity 50W×4
Conformity load impedance: 4 O
DSP section
Signal-noise ratio (IHF - A): 108dB
Time alignment: Only simple time alignment
Channel devider cross point frequency 63Hz - 200Hz (1/3oct step)
-Advance Mode ON: Slope -6, -12, -18, -24dB/oct
-Advance Mode OFF: Slope -6, -12dB/oct
Adjustment frequency: -Advance Mode ON:
63Hz,100Hz,160Hz,250Hz,400Hz,
630Hz,1kHz,1.6kHz,2.5kHz,4kHz,
6.3kHz,10kHz,16kHz
(Tone change quantity) ±10dB -Advance Mode OFF:
BASS (80Hz) ±12dB
MID (630Hz) ±12dB
TREBLE (10kHz) ±12dB
Common section
Size: 178 (W) ×100 (H) ×160 (D) mm
Mass: Approximately 2.2kg
Power supply voltage: 13.2V (11 - 16V)
Largest consumed electric current: 12 A
Accessories
Main unit, manual, warranty card
Colors available: Black / Blue
MD is the greatest fromat.... I miss my sony unit i had inmy civic... stolen ( bastards )
whats the price on that thing?>
I saw a sony unit on ebay thats a japan unit for like 449.00
It looked crazy... Ill have to find that link
as Eiso said, yes this is a japan/uk only, maybe even ONLY japan. you can check out audiocubes and other fine import retailers for more of these kewl toys.
btw if you happen to find yourself on the edge of buying one, make sure you get an FM modulator or whatever they were called to change the frequency for fm/am channels.
mischman
Mar 31, 2015 03:16 AM
Scionic
199
Jan 8, 2006 11:09 AM
arinvolvo
Jan 21, 2004 11:40 PM
Inazuma
14
Jan 8, 2004 01:36 AM
Carson_Scion_TRD_Parts
Dec 30, 2003 09:29 AM
