Tach needle stuck
Old Jun 13, 2005 | 12:30 AM
Bicepeak's Avatar
Default Tach needle stuck
The tach needle on my xB rests at 2000 after I shut it off. The needle then shows an extra 2000 rpm when it is running. What can I do to fix this?
Old Jun 13, 2005 | 12:32 AM
Rivulent's Avatar
Did you touch your needle? This happens when you dismantel the dash and forget to rest the needles where they need to be rested.
Old Jun 13, 2005 | 12:51 AM
Bicepeak's Avatar
No, I have never taking apart my dash. Just started sticking. I did change the air filter and disconnected a couple of hoses to do that. Would I have disturbed something there?
Old Jun 13, 2005 | 02:07 AM
uber-xA-RS2's Avatar
There is a cure for this. A Smith & Wesson 357 Magnum.
Sounds fishey to me. Changing the air filter should have had no effect on the tach at all. Sounds like something you may want to have a service tech take a look see to diagnose the problem.
Old Jun 13, 2005 | 02:44 AM
Bicepeak's Avatar
[quote="über-xA-RS2"
Sounds fishey to me. Changing the air filter should have had no effect on the tach at all. Sounds like something you may want to have a service tech take a look see to diagnose the problem.[/quote]
I really didn't think it did.....I believe it is in the guage. I am so leary of a dealer screwing something else up or leaving me with a dash rattle, that I am afraid to let them touch it. But that may be my only choice.
By the way, is there an easier way to change the air filter? Did I have to disconnect a couple of hoses to change it?
Old Jun 13, 2005 | 02:51 AM
That's another use for a 357 magnum. Kill the bad technicians.
Old Jun 13, 2005 | 03:06 AM
Bicepeak's Avatar
Don't give me any ideas
Old Jun 13, 2005 | 03:12 AM
miamibusta69's Avatar
Old Jun 13, 2005 | 04:05 AM
Grime's Avatar
You can probably easily fix this yourself, I did after screwing with the speedo a few times. THe needle gets a little loose, and you have to turn it COUNTER-clockwise to the right location. If you twist it CLOCKWISE, it just gets loose and goes back to its original location. SO just dismantle it easily, and then twist the needle back down to 0 when the car is off.
Old Jun 13, 2005 | 04:25 AM
Bicepeak's Avatar
How exactly do I take it apart?
Old Jun 13, 2005 | 02:46 PM
jmiller20874's Avatar
If you've never taken it apart, my advice would be to take it to the dealer because if you go taking this apart and end up breaking something, the dealer could refuse to help if they find you tampered with it.
Old Jun 13, 2005 | 02:59 PM
Joehnn's Avatar
Yep, take it to the dealer.
Old Jun 13, 2005 | 04:58 PM
Grime's Avatar
Very easily. First you have to pop off the fake screw located above the clock, and then pop off the frame around the clock/speedo. Then you just push in three little black tabs snapping the glass onto the speedo (one on the top left, one on the top right, and one on the bottom, hidden), and the glass pops right off. You are then face to face with your bare speedo.
Old Jun 13, 2005 | 07:48 PM
Bicepeak's Avatar
hmmmm....I may just try that. Not any more scary that having some dealer klutz scratch up the dash and introduce some fun new rattles.
Thanks Grime!
Old Jun 14, 2005 | 04:21 AM
Grime's Avatar
no problem, and its a lot easier than going all the way to the dealer and waiting for hours.
Old Jun 14, 2005 | 07:18 AM
Bicepeak's Avatar
Hey, I just took a drive and guess what?......the tach is fine now. I didn't do anything to it and it is back to normal.
I suppose it will happen again sometime, but as long as it works right most of the time, I am going to leave well enough alone.
Thanks for all the good advice.
Sean
Old Jun 14, 2005 | 07:49 AM
Tomas's Avatar
Admin Emeritus
Things like this is why we have warranties... :D
Old Jun 14, 2005 | 02:19 PM
Bicepeak's Avatar
Yeah, but the catch is you have to let some stranger who may or may not have the ablity to do the work without screwing it up or messing something else up on the car. Really more hassle than it is worth. Now if it were some major mechanical problem, I would of course take it to the dealer.
I am grateful that the xB has had such high quality that I haven't had the need to go to the dealer
yhwhdesign
Jun 11, 2021 03:34 PM
MrMeanor
Sep 28, 2019 04:37 PM
SJMiller
Sep 12, 2015 06:33 PM
BlingSlade
Sep 5, 2015 08:52 AM
paisatronix
Sep 5, 2015 04:13 AM
