View Full Version : Amp/Component Help : am i at 2 or 4 Ohm ?
markritch
06-22-2005, 02:50 AM
hey i have a pair of infinity perfect 6.1 in the front doors...i have them hooked to a elemental designs nine.2 amp... its rated at
100 x 2 at 4ohm
150 X 2 at 2 ohm
400 X 1 at 2 ohm
my question is, my comps are 4 ohm inpedance, how do i put them to a 2 ohm load, this ____tey pic shows how i have it set up ( 1 cross to channel 1, 1 cross to channel 2) that is 4ohm load right ? i just dont think im gettin the full potential
... and i dont want to bridge to 1 channel and push over 400 w to the comps ( thats there max)
someone please let me know if i can make this a 2 ohm load
thankshttp://image44.webshots.com/44/5/41/14/375854114AKFwmp_ph.jpg
markritch
06-22-2005, 02:56 AM
i dont think the god damn pic is workin sorry
chadfo
06-22-2005, 03:01 AM
You can't configure them as a 2 ohm load unless you run both in parallel to one channel and that defeats the purpose. You'll get plenty of output from the 100 Watts you'll get at 4 Ohms.
SCI_TC_GUY
06-23-2005, 03:09 PM
if you put a 4 ohm resistor in parallel with the crossovers, that would give you 2ohm load at the amp, but I don't know how the resistors would act with the extra power..(they might take half of the power going to the components per side and turn it into heat)
toastbox
06-23-2005, 03:29 PM
Keep in mind, that if you run an amp at a 2ohm load, instead of a 4ohm, you're going to see more power, but also increased distortion. there is always a trade off.
If you want to get that amp to run at 2 ohms, buy another set of the same comps. Remember, ohms are determined at a given frequency. That's why a set of comp's sees a four ohm load: the woofer and tweeter are operating at seperate freq's.
SuperCrunchyAction
06-23-2005, 03:33 PM
You can't wire them for a 2ohm load. I'd suggest getting a different amp that gives you the power you want at 4 ohms. I have a nine.2 and a set of edi 6000s and at 4 ohms they're getting over 100 watts because the amp is underrated. You'd probably want to go with a nine.4 and bridge the channels to get 150 watts @ 4 ohms.
mandos
06-23-2005, 03:41 PM
Nine.4 bridged at 4 actually gets a bit over 200...we had to bench one the other day.
Or...wait for a Nine.2X...200x2 at 4ohms, 400x2 at 2 ohms, chassis of the Nine.1..probably around August.
SuperCrunchyAction
06-23-2005, 03:43 PM
Yah I mentioned they're underrated so with the nine.2 he's getting 150 or close to that anyway. I really don't see the need for more power for his applications.
mandos
06-23-2005, 03:45 PM
I would have to agree completely.
Bridged Nine.4 on a set of 6500s is unbearable at high volumes...but horribly clear ;)
SuperCrunchyAction
06-23-2005, 03:48 PM
I only have the edi 6000s and just with the nine.2, they can get extremely loud and I can't say I heard any distortion. Very happy with them
SCI_TC_GUY
06-23-2005, 08:24 PM
yes, you can...from an electrical standpoint....wiring a 4 ohm resistor in parallel with the component will show the amp a 2ohm load....though probably not a good idea...as I said, the resistor would probably take half of the power just like another component would do...but since the resistor can't put out any noise like a speaker would, it would possibly take the electrical energy and turn it into heat and probably damage something....
