Does anyone know if 18X7 rims with a offset of 40 will fit
Old Jun 22, 2005 | 06:22 PM
mindgrind's Avatar
Default Does anyone know if 18X7 rims with a offset of 40 will fit
Does anyone know if 18X7 rims with a offset of 40 will fit on an XB without using spacers. I'm sure there would be no problem on the front, but I'm not sure about the rear.
Also what size spacers are needed to bring the wheel out flush.
Old Jun 22, 2005 | 06:52 PM
squirrel's Avatar
You should be fine. If you want the rear wheels to be flush, then the OTG rear shims are the ones to get.
Old Jun 22, 2005 | 06:55 PM
JdMBboFSD's Avatar
amen to that...
Old Jun 22, 2005 | 07:02 PM
bBism's Avatar
what they said
Old Jun 22, 2005 | 11:56 PM
violent_b's Avatar
I'm running 7.5" wide with a +45 offset, the OTG shims are just enough to miss the arm in the back. so you shoud be good.
Old Jun 23, 2005 | 12:25 AM
mindgrind's Avatar
would you suggest the 5 or 10 mm shims?
Old Jun 23, 2005 | 10:39 PM
RogerTTR's Avatar
FYI, we carry wheels with those specifications and no spacers are required, however, it's always best to double check with the wheels manufacturer to be sure!
Old Jun 24, 2005 | 05:05 AM
formula02's Avatar
with a 18x7 +40 to get it flush you would need at least a 20mm spacer, maybe even 25mm. I know a 18x8 +20 fits in the front and a 18x9 +20 fits in the rear. But that is super flush. I would run a 20mm up front and 25mm in the rear. It should be pretty flush with that.
Old Jul 14, 2005 | 12:09 AM
ttn0000's Avatar
DeepSouth Scions
I have 18x8 with 42 offset 225/40/18 pirelli tires . had to do minimal grinding in rear
front tires rub plastic fenderwells at full turning
Old Jul 21, 2005 | 04:31 AM
JDMJim's Avatar
How will they fit? Like the game Battleship--- wheels sunk under the fenders!!
Old Jul 21, 2005 | 09:30 PM
eXciteBox's Avatar
Signature Visions
8" wide and +25 offset = flush in the rear
7" wide and +25 offset = flush in the front
thats what work wheels usa told me. like thses guys said, your wheels will fit but they will be sunken in. OTG shims are the way to go.
scionlife
371
Jun 2, 2015 11:00 PM
mvez
Scion tC 2G Wheel & Tire
Apr 1, 2015 12:37 AM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
DR_xB
Jul 20, 2004 08:31 PM
TJ
Sep 29, 2003 06:52 PM
