amp / stock radio quwstions??
Old Mar 8, 2004 | 12:26 AM
xb_slowon's Avatar
Default amp / stock radio quwstions??
I have an amplifier, i belive it is a cruch it says it can be a 300x2amp@4ohms bridged?
can i usr this with the stock radio to power a small 8" or 10" sub??does the stock radio have any pre-outs if so how many??
Old Mar 8, 2004 | 12:34 AM
Munch's Avatar
The stock radio dosen't have pre outs.
Old Mar 8, 2004 | 12:35 AM
PandaIst's Avatar
If you want to use your stock cd player, you need a line output converter to run an amp and subs.
Old Mar 8, 2004 | 02:44 AM
KingLou's Avatar
Ok....there are no pre-outs on the stock head unit. If your amp has "high level" inputs.....then you DO NOT need a line out converter. Just splice some wires with the rear speaker wires from the stock head unit, and run them to your amp.
If your amp does not have high level inputs, and only has RCA inputs, then you will have to run a line out converter. I still just tapped the wires for the rear speakers and hooked them up to the line out converter. Then ran RCA cable from the converter to the amp.
As far as running a sub from that amp......you should be fine if its not a sub that requires a ton of power (anything you get in 8" or 10" will probably be absolutely fine with your 600 watt amp). And make sure its a 4 ohm sub........and bridge the channels of the amp into the one speaker.
KiL
clickclickw00t
Feb 18, 2015 08:57 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Dmscomp8892
Scion tC 2G ICE & Interior
Nov 22, 2014 02:55 AM
TJ
Nov 6, 2003 01:16 AM
