How long does your "low engine coolant light" stay
Old Jun 27, 2005 | 01:41 AM
NewSpectraBlue's Avatar
Default How long does your "low engine coolant light" stay
The manual says:
"The high engine coolant temperature warning light (red) will come on with the ignition keyy is turned to the "ON" position. After a few seconds, the light will go off.
If your engine coolant temperature is cool with the ignition switch on, the low engine coolant temperature indicator light (blue) comes on. If it keeps lighting on with the engine fully warmed, contact your Scion dealer as soon as possible to service the vehicle"
For the first week I had my car, I never saw the blue version of the coolant temperature light. Then I started noticing it would come on when I first started driving my car. It sometimes stays on for a few minutes. I checked my fluid levels and they're fine, and I know the manual says it will come on if the coolant temperature is cool, but I'm just curious about this.
Does yours come on every time you start your car? Does it stay on?
Thanks
Old Jun 27, 2005 | 01:47 AM
mad-sciontist's Avatar
Scion Dynasty
It comes on everytime you start your car because obviously your motors gonna be cool when you first start it up, but down here in FL mine usually goes off after about a minute or so..
Old Jun 27, 2005 | 02:00 AM
FosBox's Avatar
Default x
xx
Old Jun 27, 2005 | 02:04 AM
BakerRage's Avatar
Mine comes on and stays on for like a minish but then goes out and ive had mine for 1 week 2 days :D
Old Jun 27, 2005 | 03:10 AM
Thanks y'all. I just thought it was odd because (1) I didn't notice it when I first got the car and (2) it sometimes seems to stay on 'too long' (whatever that means inside my brain) so I just wanted to see what other people were seeing.
Cheers!
Old Jun 27, 2005 | 06:36 PM
CrimsonO2's Avatar
Cheers!
I'm less than 24 hours into my RS 1.0 and I've had that "quirk" happen where the blue coolant light stays on for a good 3 minutes. Oh well, as long as the durned thing turns off. We wait to drive until the light goes away. Is it okay to drive while the thing is on?
CrimonO2
Old Jun 27, 2005 | 09:15 PM
xAwahl's Avatar
Scion Corps
yea you should drive it easy when the light is on, so it properly warms the engine...dont rev over 3000, that was my instructions from the Scion rep when i bought my car
Old Jun 27, 2005 | 10:13 PM
uber-xA-RS2's Avatar
Mine comes on when it's started. I generally wait until it goes out to start driving. (about 2-3 minutes) Just a habit.
Old Jun 28, 2005 | 07:16 AM
Kremtok's Avatar
Up here, it takes as long as 10 minutes for the light to go off in the winter.
I don't drive mine until the light goes off. I know the manual says that you should warm the car up while driving it, but that's just against everything I have been taught. Besides, I don't want to drive in the car without the heater, you know?
Old Jun 28, 2005 | 08:34 AM
Styalz's Avatar
Will something break or go wroing when I drive before the blue light goes off?
Old Jun 28, 2005 | 09:58 AM
boilerman's Avatar
I follow the rule of idle twenty to thirty seconds after start for oil to circulate before driving off. I then limit my RPM to under 4000 or so until the confounded computer decides that the engine has reached sufficient temp to run at normal settings. High speed idle at start has been around for a while. But it is a stupid thing to have increased engine speed to warm an engine when one is driving at normal speeds. But engineers must have something to ruin or they are not happy.
Old Jun 28, 2005 | 04:22 PM
CrimsonO2's Avatar
Dude!!! ex-Juneau-ite here. I know what you mean. I've had a few people here in So Cali look at my Toyota truck funny when they saw the plug for the engine block heater sticking out of my grill. Kept asking me, "You have to plug your truck in?"
Nice to know the xA can handle Alaskan winters if need be.
CrimsonO2
Old Jun 29, 2005 | 07:33 AM
Kremtok's Avatar
That's funny! Yes, the xA handles Alaskan winters like a champ! Last winter, my boss got her Hummer H2 stuck three times. My xA: Zero. It doesn't get very cold where I am -- only down into single digits a few weeks out of the year -- but I have considered getting a block heater. What do you think?
Old Jun 30, 2005 | 01:27 AM
CrimsonO2's Avatar
I think the bigger question would be, would it fit?
CrimsonO2
Old Jun 30, 2005 | 02:54 PM
BCS's Avatar
BCS
That light doesn't mean that your fluid levels are low. All it is is the engine temperature gauge. In most cars, it's a gauge that looks like the fuel gauge. In these cars, it's only on when the engine is cold. When the engine reaches normal opperating temperatures, it turns off. The only time you really should worry about it is if you are driving and it comes on red. Then you need to pull over because your engine is over-heating.
I've had the light stay on for 15 minutes before. It all depends on how cold it is outside and how hard you are driving. Just like any other car, it's not a good idea to drive hard on a cold engine. But you can still drive around with the light on. In the summer, I usually just go and not worry to much about it. In the winter, I'll let the car warm up and go finish a cup of juice/coffee/water inside where it's warm.
Old Aug 1, 2006 | 04:34 PM
allielopez's Avatar
So 1 minute for Florida isn't bad?
I was in my garage and another driver glared at me because he wanted me to get out from my spot but I didn't want to go until the light turned off
Old Aug 1, 2006 | 04:50 PM
pooder's Avatar
Do NOT wait for the light to go off before you start driving. The best way to warm up your engine is to drive it gently as soon as it is running. And, for those of you who live in colder climates, that means to start driving as soon as you can even when it's COLD (like below zero). Your car will like you for it . . . .
Old Aug 1, 2006 | 04:55 PM
allielopez's Avatar
What happens if I wait for the light o go off? That's what I have been doing...Did I damage anything?
Old Aug 1, 2006 | 05:19 PM
snuppy's Avatar
^ nope you won't damage anything... just wasting a little bit of gas is all...
Old Aug 1, 2006 | 05:23 PM
allielopez's Avatar
Oohhhh....Thanks!! I'm totally new at this car thing.
