rim sizes???
Old Jun 28, 2005 | 06:13 PM
06bsp's Avatar
Default rim sizes???
im waiting for my tc to come in and when it dose i plan on getting rims but my question is...
if i ran 18 x 8.0 and 18 x 9.0 with 235/40R18 and 265/35R18 would i have rubbing issues? if anyone has a similar set up or could suggest a better rim wif a nice lip post up
Old Jun 28, 2005 | 06:22 PM
eXciteBox's Avatar
Signature Visions
depends on the offset
Old Jun 28, 2005 | 06:49 PM
06bsp's Avatar
WHEEL SIZE - FRONT 18 x 8.0 ET38
WHEEL SIZE - REAR 18 x 9.0 ET38
im guessing the "ET38" would b the offset
Old Jun 28, 2005 | 07:03 PM
eXciteBox's Avatar
Signature Visions
for the tC:
Bolt Pattern: 5x100
Offset Range: 35 to 42
Wheel Size Range: 17x7.0 to 19x8.0
OEM Tire Size (Front): 215/45-17 (215x626 mm)
Max Tire Dimensions: 235x646.0
Old Jun 28, 2005 | 07:09 PM
HKSpeed's Avatar
I would think you'd have rubbing issues with the fenders if youre lowered. There is a guy on SL with 20mm H&R spacers on stock wheels (which makes it a 25mm offset), and it looks really clean.
Compared to the stock wheel (7" wide, 45mm offset):
The front wheels would extend 19mm to the outside, and 3mm to the inside.
The rear wheels would extend 31mm to the outside, and 15mm to the inside.
This is just the wheel width. The width of your tires will also matter. You'll probably have to buy slightly narrower tires and have them stretched.
24mm=1inch (roughly).
"et" is offset in mm.
lower the number, the more the wheel sticks out.
I'm currently shopping around for wheels. For the fronts I'm looking for 8" wide, et35. For the rears I want 8.5", et35. The more your wheels stick out, the less you can lower your car (unless you enjoy rubbing). If you dont have the adjustability of coilovers, then you may get screwed.
Old Jun 28, 2005 | 07:16 PM
06bsp's Avatar
ok i understand so 18x8.0 wif say a +42 should work
Old Jun 28, 2005 | 07:52 PM
Vas_Finest's Avatar
U should be straight
There are a few people here running 19x8's, 19x9's, and one guy is running 19x9.5's w/ i think a 40mm offset in the rear. None of them have any rubbing issues.
Old Jun 28, 2005 | 08:01 PM
dgHotLava's Avatar
moved.............
Old Jun 28, 2005 | 09:15 PM
joolie's Avatar
omg i'm looking into buying some wheels, but honestly, I have no friggin clue what you guys are talking about! Ok on webpages like wheelsnext.com, they list dimensions like: (225/35/19)... (again, this means nada to me) can anyone tell me what dimensions the 18'' enkeis are that come stock on the RS1.0 tC's? I lowered my car, I don't want my new wheels to rub if they're too big...soomebody help!
Old Jul 1, 2005 | 06:53 AM
ScionxR's Avatar
IM getting some 18 x 7.5's and considering 215/40/ZR18's. Will these tires fit the rims, and will they rub?
Old Jul 1, 2005 | 05:34 PM
eXciteBox's Avatar
Signature Visions
Old Jul 2, 2005 | 05:54 AM
ScionxR's Avatar
what i dont understand is when the rim is 7" wide and others are 9" wide yet they both run 215 for the width. How do you know what width tire, to get for what rim?
rain7905643
Mar 14, 2015 12:48 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
Genesis
64
Jan 22, 2005 01:02 PM
