New ED Amp, Edi Components, and a couple problems
Old Jun 30, 2005 | 05:02 AM
Greg2385's Avatar
Default New ED Amp, Edi Components, and a couple problems
I recieved my Edi 6000's and Nine.2 Amplifier today. While doing the install i came across some problems.
1) Speakers are a little to big (depth) and the windows will not go all the way down.
Tomorrw i have to make custom wood fillers to make the speaker sit alittle more out.
2) I couldn't find a place to run my power wire from the cargo to the battery. I read somewhere that there are grommets behind the steering well or something?
So far all i did was run the signal wires and the speaker cables. And i connectd everything to the head unit. Tommorow i will run the power wire (if i figure out how to get to the battery) and install my new speakers with the custom wood fillers.
Any suggestions?
Thanks in advance.
Greg.
Old Jun 30, 2005 | 01:29 PM
mandos's Avatar
Hey Greg,
Check out my walk through
3/4" MDF baffles will work fine.
To run the power wire, look up behind the steering wheel, there's a huge cluster of wires coming in, carefully cut a hole in there and run your power wire through, then down the driver's side.
Old Jun 30, 2005 | 04:41 PM
Greg2385's Avatar
I've seen your walkthrough. I'm justnot sure how i'm gonna make a hole back there yet. Its kinda tight back there.
Old Jun 30, 2005 | 05:03 PM
mandos's Avatar
It should be a gigantic boot...was pretty easy...once you crammed your arm up there w/ a paring knife.
Old Jun 30, 2005 | 05:09 PM
toastbox's Avatar
I seem to recall reading on here someplace that there was grommet on the passenger side as well, and that 4 gauge power cables could be pushed through that, without cutting.
I *know* the pass side grommet part was correct, just not sure about the cutting.
anyhow, good luck!
Old Jun 30, 2005 | 05:15 PM
SCI_TC_GUY's Avatar
just make sure the wire is running INSIDE the grommet and not between the edge of the grommet and the firewall......
on the pass. side, you have to remove the glove box I believe..... The drivers side doesn't require removal of any components and you'd already be on the battery side of the engine compartment......
Old Jun 30, 2005 | 05:18 PM
toastbox's Avatar
I knew about the Glove box, but I'm glad you mentioned the battery....I totally forgot about that part.
Old Jun 30, 2005 | 05:33 PM
mandos's Avatar
AND, 2 runs of 0 awg will fit
Old Jun 30, 2005 | 05:38 PM
SCI_TC_GUY's Avatar
only you mandos.....only you...haha
Old Jun 30, 2005 | 06:24 PM
Greg2385's Avatar
From what i see... there isn't even room for speaker wire to pass through that grommet. When i look from inside the hood, the grommet is completely full of wires with no space around them. Am i looking at the wrong grommet? I'm looking behind the steering wheel.
Old Jun 30, 2005 | 06:40 PM
HyperZ's Avatar
I ran my power wire through the grommet used by the A/C spillover tube. It's located on the lower left hand side of the passenger space. You can see it by pulling the carpet back. There's a small, black tube leading out, which probably just drains water from the A/C unit. I split the grommet to open it and ran my power wire through there, up the firewall and over to the battery terminal.
Old Jun 30, 2005 | 06:47 PM
madhouse247's Avatar
I have drilled a few holes for customers with Xb's through the fire wall with a right angle Makita drill and a step bit, but to do it cleanly will take some time and a lot of people would rather not permanelty put unneccesary holes in there new vehicle but with 2 or 0 ga you might not have a choice. There is some thick sound damping material on both sides of the firewall.
Old Jun 30, 2005 | 06:54 PM
SCI_TC_GUY's Avatar
greg, there should be some room between the wires and the edge of the grommet.....you won't be able to push the wire through WITH the other wires....but make another hole in the grommet beside the factory wires....
Old Jun 30, 2005 | 07:03 PM
English's Avatar
You can easily use the passenger side grommet, that's what I did, there are 2 nipples on each side of the main hole, cut then tip of one nipple off, lube your wire really well with wd-40 or soapy water, and then stick 'er through!
It's like a hotdog in a hallway!
Old Jun 30, 2005 | 07:07 PM
SCI_TC_GUY's Avatar
but as I said before....on the pass. side, you have to take the glove box out, and it's farther away from the battery which gives more electrical resistance to power....
Old Jun 30, 2005 | 07:21 PM
Greg2385's Avatar
I don't want to use the passenger side for 2 reasons.
1) its the opposite side of the battery
2) i already ran my signal wire from the passenger sid.
As far as making a hole in the grommet:
I see where i can make a hole and the wire would fit in. I just don't see how its gonna come out from the other side. Am i gonna have to drill through the firewall?
Old Jun 30, 2005 | 07:30 PM
English's Avatar
The grommet goes all the way through the firewall, so the wire will come through the grommet into the engine bay, or into the passenger compartment. Honestly I think it would be easier to run the wire from inside out.
Old Jun 30, 2005 | 08:35 PM
mandos's Avatar
Inside out for sure....outside in you need to run 14 feet into the car =
Old Jul 1, 2005 | 06:29 AM
Greg2385's Avatar
Finally completed the install! Woohoo Sounds GREAT.
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
EvalEvan66
Jan 27, 2015 02:26 AM
corbmonster
Jan 24, 2015 06:13 PM
Erickdimas7
Jan 16, 2015 03:41 AM
cwong1001
Dec 3, 2014 03:30 AM
