battery voltage question
Old Jul 6, 2005 | 05:36 PM
240SXtoTC's Avatar
Default battery voltage question
i just had a new pioneer cd player installed and it has a battery voltage meter on it.
when i'm driving it usually reads between 13.1 and 13.7.
A friend told me that it should be at 14 and something is wrong but I don't know if he really knows what he's talking about as my car starts and runs just fine...
the only other mod i have done is a viper security system (no subs or anything yet)
just curious to see what you guys think.
Old Jul 6, 2005 | 06:00 PM
ScionDad's Avatar
You're fine. The accuracy of that meter is at least +/- a few mv. I have 3 stinger meters on mine....13.8v at the battery, 13.6v at the amps and 13.4v at the cap. 16 feet of wire along with the accuracy of the meters is my difference and it varies all the time.
Old Jul 6, 2005 | 06:43 PM
engifineer's Avatar
Yep, no issue. If it reads 12V, then start checking I believe (and I am digging into my memory here) that it takes around .2 V per cell to create the reverse current to charge a lead acid battery. I think these are 6 cell batteries, so technically it should charge at 13.2V (.2 * 6 + 12). I usually go with 13.5 - 14.5 or so to be ok.
Old Jul 6, 2005 | 06:54 PM
mandos's Avatar
My battery sits at a constant 13.4V almost always. With the car running usually about 14.1 to 14.2. With the 2 Nine.1's running at full tilt, I sucked it down to 11
Old Jul 6, 2005 | 07:10 PM
RanmaP's Avatar
Default Its good.
I would agree, if your alternater isn't charging then upper 13 is good, when your car is on and the alternater is working then it should be over 14.
Old Jul 6, 2005 | 08:35 PM
Newtmaker's Avatar
I think probably 99% of auto's out there call for a charging rate of 13.6 to 14.2 . If you are in that range you are fine. If you are consistantly high or low then you can expect problems down the road. Too high and you cook your battery, too low and you cook your alternator/regulator.
Walt
Old Jul 6, 2005 | 08:55 PM
engifineer's Avatar
Default Re: Its good.
No, it should sit at 12V without the car running. It may read a little over due to meter discrepencies and overcharge, but the minute you add a load you should see 12V. 13.4 and up are the charging voltages.
If you are seeing it drop to 12V or below while running (for longer than a couple of seconds at a time), then plan on an alternator soon, because you are running yours past its capacity. The alternator is burdened with supplying the system loads plus charging load while running, so if it is not holding battery voltage to proper levels then you are overworking it.
Old Jul 6, 2005 | 09:05 PM
Lonely_Raven's Avatar
These guys are so smart!
I like when things are laid out so clear and concise!
Old Jul 7, 2005 | 04:34 AM
240SXtoTC's Avatar
my thoughts exactly... thanks everyone for all the info
Old Jul 7, 2005 | 12:45 PM
sciontc_mich's Avatar
yeah mine is reading 13.1-13.4 volts.. a/c kicks on it goes down to 13.1v. just my $0.02
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
