springs and 225/40/zr18 tires
Old Jul 12, 2005 | 04:22 AM
eric1645's Avatar
Default springs and 225/40/zr18 tires
my tires are slightly bigger and rub at full lock. but i want to drop my box 2''. will this work? if not, how low/what springs
Old Jul 12, 2005 | 05:00 AM
hotbox05's Avatar
they are WAY bigger. you will rub all over the place on a 2 inch drop. what width wheels ? what offset?
Old Jul 12, 2005 | 02:59 PM
eggie's Avatar
If you are rubbing now, you WILL rub even with a 1" TRD or Tein H Tech springs.
Old Jul 18, 2005 | 03:41 AM
Prototype_xB's Avatar
I've never looked into it, but what about stoping into a machine shop and get a quote on getting them to make you some spacers. Nothing fancy like oh the OTG shims, just something to go between the rim and rotor.
I wouldn't know if that would even be safe, but i've seen things of the sort being sold. Couldn't hurt to check out.
Old Jul 18, 2005 | 02:51 PM
THE_DON's Avatar
It WILL rub, take it from me...
I have 225/40/18 and they rubbed with stock springs. I dropped it 1.6" on Hotchkis springs and the rubbing got MUCH worse. If you plan to drop it (especially 2 inches) you should get slimmer tires.
-THE DON
Old Jul 24, 2005 | 07:07 AM
eric1645's Avatar
if i cut the plastic out from behind the front wheels they wont rub? dont know the off set but theres a but theres a #42 on the inside of the rim in the center is that it? sorry, i dont know much about wheel/suspention mods
Old Jul 26, 2005 | 06:52 PM
dfwaltima's Avatar
OK since i was going to ask the same question, ill join the thread..
I also have 225\40\18 on a 18x7.5, +45offset, i was looking at the Eibach Pro-Kit, right now the only rubbing i get is when i turn, you guys are saying that is going to be a lot worse?? im confused.
Old Jul 26, 2005 | 08:29 PM
hotbox05's Avatar
rubbing will be alot worse on a 225 tire.
just so everyone knows 215/35/18 is exact same size as stock ( virtually) 215/40/18 will be larger and rub more but is significantly smaller than 225/40
just buy the correct tires guys.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
terrye
Jul 11, 2015 11:54 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
STCxB
11
Jan 9, 2015 04:30 PM
ScionVan
11
Dec 2, 2003 09:37 PM
